Question about HP LaserJet 3055 All-In-One Printer
HP laserjet 3055 beeps loudly when printing. Would like it to stop!!! Otherwise printer is just fine.
    President:
  • 3,278 Answers
If it's a grinding or squeaking problem, it's a pickup roller assembly problem. Would need to be serviced, or returned if still under warranty.
Posted on Jul 03, 2009
The HP 3055 network printer, connected to 3 dell inspiron laptops doesn't print...it says it's offline, even though the screen on the printer says "ready." I tried adding a printer profile and...
Check the IP of the printer, it should be manually assigned, if you are not confirmed,
  1. Press menu/enter .
  2. Use the or the > button to select Reports , and then press menu/enter .
  3. Use the or the > button to select Config report , and then pressmenu/enter .
  4. The printer exits the menu settings and prints the report.
Try re installing the printer software from the cd, or download the full version from the links below for your area
HP LaserJet 3050/3052/3055/3390/3392 Asia Pacific Full Software Solution
HP LaserJet 3050/3052/3055/3390/3392 Eastern Europe Full Software Solution
HP LaserJet 3050/3052/3055/3390/3392 North America/Western Europe Full Software Solution
(The full software solution provides print, fax and scan functionality. This software solution is the same solution as the Version 4.0 in-box CD that came with your HP LaserJet 3050/3052/3055/3390/3392.)
You can download Printer manual from the link below
Printer Manual
If you require more assistance in this regard feel free to reply to this post
Best regards-BA
Jan 20, 2011 | HP LaserJet 3055 All-In-One Printer
HP 3055 All In One laserjet prints all black pages
Odds are that you have a bad toner cartridge; especially common when using remanufactured cartridges. (Staples, Corporate Express, etc.) Replace your cartridge with an OEM HP cartridge and you should be OK.
Feb 22, 2010 | HP LaserJet 3055 All-In-One Printer
White line
White lines are generally caused by clogged print nozzles. I assume that you have a printer with the print heads built into the cartridge. Are you using high quality cartridges or cheap refills? If cheap refills, try a better/different brand of cartridges and see if that helps. I would also check the printer manufacturers website and try their recommended printer nozzle cleaning procedure.
Jun 03, 2009 | HP LaserJet 3055 All-In-One Printer
Can't print to old applications
The issue your having is with the Operating system compatability. The HP 3055 is compatible with 98, ME, XP, Window 2000 and forward. It won't do windows 3.1 or 95 well even if your computer will, the disconnect comes when the software is sending old print commands to a new style print driver.
Your best hope is to download and install the HP Printdriver for Windows 98 and try it as it's the most tolerant of old gear. Download the PCL 5 as the PCL6 is too new and probably not going to work.
As an alternate try to download each of the printdrivers for the differnt era windows and try them. It's a hard problem that may not have a solution other than upgrading the accounting software.
If it's simply a connection problem, they do make a USB to Parallel addaptor which may help you with the physical connection issue.
Here's a link:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=1140780&taskId=135&prodTypeId=18972&prodSeriesId=1161389&submit.y=4&submit.x=3&lang=en&cc=us
Hope that helps you.
Aug 24, 2008 | HP LaserJet 3055 All-In-One Printer
How to install Hp laserjet 3055
If the connection is ethernet. Print configuration from Printer.
Manually install printer.
Select computer is on local port
Local port to select is TCP/IP
then type in the network address to the printer.
Driver will still be inside computer.
Mar 03, 2008 | HP LaserJet 3055 All-In-One Printer
Only prints black& white
The HP Laserjet 3055 is a mono only printer but can scan in B&W and colour.
Dec 19, 2007 | HP LaserJet 3055 All-In-One Printer
3055 scanner not working
My HP 3055 cannot scan but can print & fax.
Nov 02, 2007 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 3055 All-In-One Printer Logo
356 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
