Question about Philips SoundBar DVD Home Theater with Ambisound
Have surround sound only when play dvd..
Want to have surround sound all the time
    Habit-Forming:
  • 108 Answers
If you have a sat/cable box it may have audio outputs that you can connect to the input of the surround unit or if your tv has an audio uotput it can be connected to the surround unit. The audio outs of the tv may or may not adjust with the tv volume. This will not produce a true surround signal because th tv does not output a true surround signal. But yo can adjust the surround unit to get a nice sound.
Posted on Jun 26, 2009
3 Suggested Answers
SOURCE: the surround sound only plays on dvd not tv
most tv shows will only be broadcast in 2.0 not 5.1 or higher. if you have a converter box, that may also be the problem.
Posted on Apr 14, 2009
enoch_cog80
  • 33 Answers
SOURCE: no sound through surround
this is because the home theater receives 5.1 channel... change it it will work...
Posted on May 18, 2009
Hi all, I'm using a Sony BDVE 280 surround sound
no u will not be able to because you would have two seperate sources like to listen to ur iphone ud have to put ur surround sound on auxilary while for xbox ud have to have it on something else which ever port ur xbox is pluged into ur surround sound at or whereever ur tv is pluged on ur surround sound
Apr 17, 2013 | Audio Players & Recorders
What is the time delay switch for on a sa 5760 receiver
Hi,here is the basic info for your question..
Take care and please
Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Surround Sound System Settings ---- Correct Time Delay Setting in Multi-channel Audio
A correctly set surround sound system can yield dramatic improvements to your
home theater sound or multi-channel music listening experience. In particular,
a correctly set time delay setting between the different channels is essential
for a realistic and unified surround soundfield.
Luckily, most of today's surround processors make setting the time delays
between the rear and the fronts a matter of a few entries in the setup menu.
Yet having a proper understanding of the principles behind correct time delay
settings is essential for the best results.
In this guide, we explain the principles behind time delay settings in surround
sound and show you how to adjust your surround processor or AV receiver for the
best surround sound field.
Time Delay Setting in Multi-channel Surround Sound Systems
Correct home theater speaker placement and properly balanced sound levels
between the different channels in multi-channel audio, while crucial, are not
enough to sustain a unified soundfield in a surround sound setup. A correctly
set surround sound system requires that sound from all the different speakers
reach the listener at exactly the same instant.
This explains why all fronts, left, right and center channel speakers, should
be set at exactly the same distance from the listening position. At the same
time, in a typical home theater setup, the surround speakers are closer to the
viewer than the fronts.
To compensate for this distance discrepancy, surround sound playback systems
apply a split-second delay to the surround sound channels.
Jun 22, 2011 | Technics Audio Players & Recorders
How do u get surround sound out of all the speakers when watchen tv
Most of the time, you will only get surround sound out of all the speakers when the Soure (ie Cable, Satellite etc.) puts out surround sound. The receiver can only give what it gets (unless it has a simulated surround function, in which case it wouldn't be true surround sound). If you can check the info from the source, see if it shows you Dolby 5.1 or DTS as an option. If these aren't available, then you won't get surround sound. Hope this helps!
Mar 01, 2011 | Samsung HTC550 Theater System
No sound output from Center and Surround speakers
the only time the center and surround speakers put out sound is when it has a surround sound source such as a dvd etc. and only certain sounds come from them as well.
May 23, 2009 | Kenwood VR615 Receiver
Unable to get surround in dvd mode but can hear thru tv speakers?
Is your DVD player hooked up to a surround sound receiver, or directly to your television?
Mar 18, 2009 | Mitsubishi M-VR600 Receiver
Kenwood VR6070 speaker/amp problems
unit needs repair. Look at the b speakers. Conect a speaker or two to the B position. If you have no sound than your surrond sound is ok and the unit is bad. Sound comes directly into the b speaker and not threw the surrond system. My 6070 has a cold start up problem. no sound. time to purchase a new one. to costly to repair.
Dec 30, 2008 | Kenwood VR-6070 Receiver
Set up the Panasonic SC-PT450 and followed all the various instructions. Am using the surround sound in conjunction with a Panasonic TV bought at same time (50" plasma) but can't seem to get sound out...
Are you sure you're using a source material that is surround sound? Most TV broadcasts are still only stereo.
Also with surround programmes, the rear speakers are only used for the surround effect so will only make sound when the sound source is supposed to be behind you.
Jun 25, 2008 | Panasonic Televison & Video
Tv sound & surround sound
Go to Settings/SoundSettings/AudioOutputSettings/AudioInputConnector or DigitalOut depending on type of input you are using for surround.
Jan 02, 2008 | Sony Playstation 3 (PS3) Console
Surround sound
1. have you got a surround sound recorded media ?
2. what input are you inputting ? digital or analogue LR
3. is auto surround on or off in the setup.?
4. is your dvd player dts and dolby digital ready?
answer me the questions ... in the process you will solve your problems.
regards
david174@gmail.com
Dec 27, 2007 | Yamaha RX-V661 Receiver
Philips SoundBar DVD Home Theater with Ambisound Logo
493 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
