I turn on my MP3 player and it makes a funny noise and doesn't load and then gives me an error message that says "FAT error plz connect UMS device format." I have MAC so I can't mess around with F drives and D drives or anything like that. When it charges it doesn't show up on system.
it goes to the main screen but has nothing under any of it.
42 Other Users Have The Same Problem
Comment by SamanthaReyy, posted on Jul 20, 2008
When I turn it on, A buzzing noice (accasionally) come on, but it only
ever l;oads upto one bar, then it freezes and won't do anything. I even
have to let it sit there and die just to shut it off.
Comment by Guest, posted on Jun 13, 2008
does it have to be on or off
Comment by Guest, posted on Jun 12, 2008
k u guys r tards dropping it doesnt work
Comment by Guest, posted on May 25, 2008
FAT error
Comment by fuckedfaces, posted on May 16, 2008
RCA H100 MP3 Player
Rating: 0%, 0 votes
Was this solution helpful? Show your Appreciation by rating it:
Rating: 0%, 0 votes
Comment by Mr Help, posted on Nov 12, 2007
FOLLOW DIRECTIONS CAREFULLY;
1. TAKE DEVICE IN RIGHT HAND
2. FIND SURFACE WITH HARDNESS OF WOOD
3. HOLD DEVICE APPX. 2 FEET ABOVE SURFACE.
4. DROP DEVICE.
5. ENJOY MUSIC
6 .REPEAT STEPS 3 AND 4 IF NECESSARY
Rating: 0%, 0 votes
Rating: 0%, 0 votes
Rating: 0%, 0 votes
Rating: 0%, 0 votes
Rating: 0%, 0 votes
Those of you that are saying this only breaks it even more are obviously slamming it way too hard, if you drop it from two feet up there should be no issue with breaking it.
Anyway, here's what I did:
I went into my kitchen and bent over a bit, I lowered my MP3 player so that it was about 2 - 3 feet off of the ground. I proceeded to drop it straight onto it's back and when I picked it up, it was working flawlessly. I honestly didn't think it was going to work, otherwise I would have made a video. I hope this helps you guys!
Rating: 0%, 0 votes
Good luck
Rating: 0%, 0 votes
Post a New problem for RCA H100 MP3 Player
Email this problem
Can you Help with these MP3 and Digital Media Players problems?
The phono jack on my son's H100...
42 Other Users Have The Same Problem - Continued
Comment by SWATCOP8, posted on May 02, 2008
MY H100A ONLY LOADS ONE BAR THEN IT SAYS I HAVE A FAT ERROR AND TO CONNECT TOUMS DEVICE. HOWDO I FIX THIS PROBLEM
Comment by Guest, posted on Apr 12, 2008
I have the same problem. I cant get mine to work for the life of me.
Comment by Madamegigi, posted on Apr 12, 2008
my RCA H100A is only loading one bar, then to fat error, then to connect some ums whatever, then to a screen that has 4 different icons and stays there. my computer is not recognizing the unit all of a sudden. F5 will not refresh the player.
have already tired the bus cables,
forcing the disk app,
holding the play button while plugging in,
holding the off button for 10 sec's
Comment by kendra05g, posted on Apr 11, 2008
I plug in my device and it takes a while to load and when it finally get to the connected screen it doesnt say transferring or connected like it did before...and when its pluged in it doesnt show up on my system...i know there is stuff on it but nothing appears when i turn it on.
Comment by jeremeyk, posted on Apr 06, 2008
im havin the same problem wear i turn on the mp3 and it only loads 1 bar then says(FAT error plz connect ums device format)then it says HDD.I have tried what somebody sayed and it was pluggin in the mp3 to my computer then got to the folder called my computer and then right click on the object that says h100a but on mine instead of it saying h100a it says MTP device.Dose aney body now how to fix it?
Comment by zeeke, posted on Mar 30, 2008
Comment by Guest, posted on Mar 22, 2008
i need help it wont fix
Comment by thecow, posted on Mar 21, 2008
well i got my RCA for Christmas and it worked fine except the freken screen cracked but i tryed to delete the music from it and it says ATE error PLZ connet UMS Device Format, then it goes and says HDD and there are icons but no words
Comment by fireside, posted on Mar 18, 2008
SAME PROBLEM
Comment by Moo2u2, posted on Mar 10, 2008
i had to call RCA 11 times and wait 4 months to get a replacement, and after 3 days of having it, it's also dysfunctional. i'm freaking ******. >: L
Comment by Guest, posted on Feb 17, 2008
My mp3 player is having a error coming up saying "FAT error plz connect UMS device format." how do i fix it???
Comment by skeptic45, posted on Feb 12, 2008
I have the same problem as everyone else. FAT ERROR PLZ CONNECT UMS HDD.
This is my third one. RCA has replaced 2 already. I'm out of my warranty period now.
While I save up for an IPOD I'll just keep dropping it - nothing to loose now,
I feel better knowing it's not just me, these are crap.
Comment by hacked, posted on Feb 08, 2008
When i turn on my mp3 player it says FAT error plez connect UMS device then goes blank. I've called RCA customer service 3x and they're no help!!! Can any one help with this?
Comment by LILMILES, posted on Jan 17, 2008
I have the same problem with my mp3 player. it only loads one bar and then makes some kind of funny noise then says FAT ERROR...... but the funny thing is,is that i dropped it on the floor and now it works.Who in this world would ever want a mp3 player that you have to drop on the floor to get it to work.Something is seriously wrong with these mp3's and i think RCA should refund all the people who has ever bought one because as you can see these mp3 players are CRAPPY!!!!!
Comment by blazz, posted on Jan 13, 2008
Comment by supernova92, posted on Jan 08, 2008
when i turn it on it makes these clicking noise then after about a min it goes to the normal screen but with only the pictures and it keeps making clicking noises.
i've tried charging it and looking on my comp. to see if it even connected but it didn't work.
Comment by showstopper, posted on Jan 07, 2008
i have the same problem but i used it as a harddrive and now nothing works and it doesnt let me do anything
Comment by wwefanclh813, posted on Jan 05, 2008
I Bought The RCA H100A From Walmart and it worked pretty good for about 5 or 6 months and somehow some information on it got deleted and now I cant download any music on it.....WTF? when I turn it on it has some chinese symbols and it ses something about an error and whenever i try to charge it it doesnt do anything but just set there on the charger. Please I spent about 150 dollors on this thing and now it wont work....so if anyone has any information on how to fix it please tell me much appreciated.
Comment by Guest, posted on Dec 28, 2007
i turn my mp3 on and doesn't load, making a funny sound. after a while, it gives me an error message that says... fat error: plz connect ums device format! after that it shows an hdd screen and then it shows the keys but it doesn't show the letters next to them as they did before.
Comment by nadowe, posted on Dec 19, 2007
Comment by Guest, posted on Dec 18, 2007
We have same problem, one bar lights up, then same message--fat error. We tried dropping it. Didn't work. Any other suggestions? I have the h106a though.
Comment by maby, posted on Dec 16, 2007
my mp3 does the same thing ..... but how to fix it?????
Comment by Guest, posted on Dec 14, 2007
it don't show up on the system
Comment by candy1234, posted on Dec 10, 2007
i have the same problem has anyone found out how to fix it mine is pretty much brand new barley used it stupid thing
Comment by D-Nickel, posted on Dec 09, 2007
i turn it on and it does nothing.....then it freezes thensays "FAT error connct ums drive or sumthing like that"
i really need it to work soon!
HELP ME NOW
Comment by Xavier426, posted on Dec 09, 2007
When i turn it on only one bar of four comes up and it makes this clicking noise. Then no words come up on the main menu.Dropping the rca did not work.
Comment by Beauty Queen, posted on Dec 08, 2007
iT DOESNT EVEN LOAD UP IT COMES ON AND ONLY ONE OF THE LINES COME ON THEN IT FREEZES UP AND SAYS ERROR
Comment by anisa, posted on Dec 02, 2007
no file
Comment by euraldo, posted on Dec 01, 2007
Comment by chettos, posted on Nov 26, 2007
i turn on my mp3 and it says something i cant remember and it dosent shoe the letter and it wont let me hear anything
Comment by victorct, posted on Nov 26, 2007
Comment by Guest, posted on Nov 26, 2007
Comment by gzootman, posted on Nov 23, 2007
I Have the same problem
Comment by Guest, posted on Nov 12, 2007
Comment by jbrookeb, posted on Nov 10, 2007
I have a RCA H100A and it gives me an error sign. It gets stuck and won't play. Now it goes to the start up screen and won't go any further. Is there a recall on this product? If not how do or can I fix this problem?
Comment by Totsie, posted on Nov 08, 2007
Mines Make A Funny Noise and it says error plz connect UMS Device Format and i dont know why
