Question about Kenwood KAC-7202 Car Audio Amplifier
Kac-7202 with flickering power light
I have a kenwood kac-7202 amplifier with a flickering power light. I also nodiced that the fan speed goes along with the flickering light. I picked it up from a friend and the only thing I knew about it is that it powered up and didn't put out sound. So, I opened her up and I nodiced that the ground trace for the speaker terminal was blown. So, I made the fix, I hooked it up and still no audio. Strangely after hooking up the speakers the power light started to flicker. What I'm thinking is that there is a short some where that is bringing the power supply down but I'm not able to find it. So far I have checked all of the transistors for a short and out of circuit I've checked the zeners that every one is talking about, the supply diodes, a couple of the output transistors and I haven't been able to find anything. Does anyone have a suggestion?
  • Andrew Hawkins
    Andrew Hawkins Jul 04, 2009
    I have checked pretty much all components for any type of visual defect and even tested them out of circut. I'm still at a dead end here but maybe some time next week I will do more digging into it but it would be great if someone familiar with the problem could lend some advice as to where to start instead of wandering in the dark on the circuit. Thanks for your reply nnowak277
  • 113 Answers
Did u start simple with checking your connections and after that you have gone in pretty far so did you check the heat sinks and mosfets look for small dents or divits and those ane the bad ones
Posted on Jul 04, 2009
Kenwoood kac-7202 redlight/no output
you blew the output Ic's (amps one or more ) you can fix this by replacing the output IC's
Jan 29, 2014 | Kenwood KAC-7202 Car Audio Amplifier
Red light comes on for a second then the fan comes on , but no sound
If the red light is the normal power-on indicator and it goes off, there is a problem with the power supply
Nov 14, 2012 | Kenwood KAC-7202 Car Audio Amplifier
I have a kenwood kac-7202 and it keeps blowing the in-line fuse
Are all the wires hooked in right? On the bare parts of the wires, are there any 2 wires touching? Most importantly, do you have the correct fuse for the stereo?
Oct 11, 2009 | Kenwood KAC-7202 Car Audio Amplifier
Keep popping fuse
you got short in the curcuit
Apr 03, 2009 | Kenwood KAC-7202 Car Audio Amplifier
KAC-7202 will not put out sound. Put in other amp works.
When you switch on the amp did the main amp ic produce heat. If does not change the main amp ic.
Feb 13, 2009 | Kenwood KAC-7202 Car Audio Amplifier
Kac-7201
Check the zener diodes over by the fuses, where the 2 chokes or load coils are. TThere are 3 or 4 Of the diodes, they are zener diodes. I had the same problem and found it to be one bad zener diode. Check my solution out on the 7202, same thing.
Sep 17, 2008 | Kenwood KAC-7202 Car Audio Amplifier
Kenwood kac-7202
Nope it's not a high-to-low level converter problem, it's most likely a problem with one of two things. 1) either you've blown the output stage in the amplifier, or 2) you've hooked up your subs wrong and your amp is seeing to low of an impedance. The amp is supposed to be 1ohm stable, but we had the same problem. When the indicator light goes red it means that the amp has gone into protection mode, now you have to figure out why. If something in the amp goes bad or just disconnects from the board it will cause power protection mode. If you fry something on the board because you are running the amp to hard or at the wrong impedance it will go into thermal protection mode, however there's no simple way to figure out which has happened.
Have you tried hooking up some different subs to see if the problem remains? try this. If the problem no longer happens then you know it's your subs, if it does still happen then you'll know it's an internal problem.
Years ago I had a Kenwood KAC-821; long story short, I melted the main power wire right off of the board, everytime I turned the system up the amp would shut down.
Take you amp to an authorized dealer and have them bench test it for you.
Let me know what you find out.
Jul 14, 2008 | Kenwood KAC-7202 Car Audio Amplifier
Kenwood kac-7202 amp
150/ch into 4 ohms
230/ch into 2 ohms
Spec Sheet
Jan 11, 2008 | Jensen XA2150 Car Audio Amplifier
Kenwood KAC-7202 Car Audio Amplifier Logo
252 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
