Dell Ethernet Card Network Adapter
Problem for Dell Ethernet Card Network Adapter
When I install XP on my dell and try to create a
By oddmund_penn on Jun 26, 2009
When I install XP on my dell and try to create a network connection, it says I have no network adapter. But my LAN cable is plugged into my computer and modem etc. What's my problem?
Clarification Request
Posted by pshinde23 on Jun 26, 2009
You need to install the lan/ethernet drivers to use the network connections, SO install the driver first.
Solution #1
posted on Jun 26, 2009
Not Rated)
efs_perpends
Rank: Guru  Dell Expert
Rating: 89%, 730 votes
Did you reformat the hard drive? You may not have loaded the drivers for your network adapter. (In that case, your sound probably won't work either, and possibly other devices.)
If you check in the device manager (see here), you'll see it is disabled or not installed.
You need to locate your Drivers cd, or download them from Dell and install the drivers for your network adapter, reboot your system, and it should appear in the device manager and function. Here's a basic troubleshooter that will help you to sort this out, and here's a more advanced version in case you run into other problems. This excellent tutorial will help you to update the drivers for your system.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Was this helpful?
Yes
No
Popular Solutions for Dell Ethernet Card Network
Questions and Unsolved Problems for Dell Ethernet Card Network
Do you recommend Dell Ethernet Card Network Adapter?
Answer
Answer
lost connection to Internet. ISP says its IP4V, but is it a coincidence it happened on the day my... (More)
Answer
ethernet card not detected while installing pro e
Answer
ethernet card not detected while istalling pro e
Answer
cannot connect Dell desktop to ether net (from comcast modem); i connected my laptop and am able to... (More)
Answer
dell, wen turn on the power only the liht lit for second but bthe monitor and the lap top dont work
Describe your Network Adapters problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Network Adapter Experts
Top Computer & Laptop Repairmen
in Newport, KY
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
