Question about Gem Sound GEMSOUND EXA-3800 POWER AMPLIFIER 1600 WATTS Car Audio Amplifier
Gem sound exa-3950
Unable to get sound from amplifier. receiving signal but no output . the amp is a gemsound exa-3950. i have the speakers hooked up with wires
  • 113 Answers
Check the rca's for a short
Posted on Jul 04, 2009
The amp doesn't output anything. When it is turned on the power light, left signal, and left clip light light up immediately. A few seconds later both Fault lights light up. I unplugged ever thing...
What is the make and model, it sounds like its going into overload protection, if the speakers aren't hooked up you have some bad components in the output section.
Jan 31, 2018 | Gem Sound EXA 3955 2Channel Amplifier
Gem sound exa-3950
You could check the 115/230 switch. If you are getting power to the unit no fuse or circuit breakers tripped, and you have 8 ohm speakers connected, and a signal in you should get a signal out. Level controls should be up. If all of those things are true, then the amp is broke and needs an electronic technician to repair it.
Jan 01, 2018 | Gem Sound GemSound PA-585 2-Channel...
PyLE PT2000 Power Amplifier' { is it worth it??}
People talk alot of **** about Pyle amps, all I can say is that,
I have two PT-2000 & PT-1800 power amps that I have set in bridge mode, one for each speaker and they are powering two Altec-Lansing 18" inch subs, one amp per speaker, no hiss, line noise or anything and the system kicks. I tried the Pyles on a whim because I got tired the trouble I was having with the QSC and Crown power amps, could not go a year without having something go wrong always sending back to dealer for some kind of fix! So now I have 2, QSCs, 2 Crowns & 4 Pyles driving my system
Apr 27, 2009 | Pyle PT-2000 Amplifier
Gem sound exa 3950 amp
Hi...
If it's a straight-up power switch then it will need to be replaced if it works off a relay then the relay is gone.
website
http://www.gemsound.com/contact.html#
Mar 24, 2009 | Gem Sound GemSound PA-585 2-Channel...
Gem sound 3950
Dc problem in amplifier (short circuit) needs to be serviced
Jan 05, 2009 | Gem Sound GemSound PA-585 2-Channel...
Boost volume of computer
HI...
Connect the "line-out" of the sound card to the "Line-in" of the GEM amp
Dec 26, 2008 | Gem Sound GemSound PA-585 2-Channel...
Gem Sound clipping problem
First of all the EXA-3940 is rated at 350watts per channel in to 8 ohms. The 1400 watts is bridged into a 4 ohm load. Second, the speakers can handle 1000Wats peak with an average of 600 continuous (i'm guessing). That tells me that the amp is underpowered for the speakers. The sensitivity of the amp is such that the mixer is overdriving the input stage. That is what is causing the clipping. If you are looking for more volume, you are probably better off purchasing another amp and running them in bridge mode, 1 per speaker cab. Be careful though, not to overdrive the speaker cabinets either.
Dan
Sep 21, 2008 | Gem Sound GemSound PA-585 2-Channel...
Manual
Contact Gemsound thru their email.
Sep 04, 2008 | Gem Sound GemSound PA-585 2-Channel...
Very low sound
It looks like you are taking your output off of a line level source, being that it isn't amplified.. Try the speakers on a known amplified source, if the work then just add a powered source to your system...
john
Aug 20, 2008 | Gem Sound GemSound TR-8 Speaker
Car Audio & Video Logo
191 people viewed this question
Top Gem Sound Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Gem Sound Car Audio and Video Expert? Answer questions, earn points and help others
