Question about Samsung RS2630SH Side by Side Refrigerator
Overheating The freezer side of the fridge is overheating along with the divider of the freezer/ fridge. what shall I do....
  • weide Nov 12, 2007
    Our freezer side of the fridge is overheating too. It started a couple of days ago, The outside of the freezer is getting hot, as well as the divider strip between the fridge and freezer. I pulled everything out of the freezer, unplugged it, and let it defrost overnight. It heated right up again when I plugged it in. If you have a solution, my e-mail is
  • rbs1961 Dec 04, 2007
    Mine is doing the same thing too. It's about 2 yrs old. I'll check out the fan, I have had a problem with having to defrost his fridge though, too.
I finally discovered that the problem was because of a malfunctioning fan in the back of the fridge. It is supposed to cool the condenser, and is located behind the panel near the bottom of the unit. The fan unit was easy to remove, I ordered another from Samsung, and had a small portable fan blowing on the condenser until the new fan unit arrived a couple of days later.
Posted on Nov 18, 2007
  • 55 Answers
The inreasion of heat is normal if you recently add food to froze.Let it work for some hours without open it and check it again
My Vitrifrigo DP2600 fridge now gets very hot along the front divide between the fridge and freezer. What could cause this? How can it be fixed?
Seems like your self defrost mechanism is fubar. Check the defrost element and make sure that it is not open and that the timer is working. I parts needed go here Search Over 2 1 Million Appliance Parts
Sep 11, 2017 | Frost Refrigerators
Have fridge freezer 8 years old , lights work but warm inside and all food defrosted , is it worth getting fixed or shall I get knew one?
My advice would be to go for a new one as the product you are holding is more than 8 years old. Although, obviously new is going to be a little on the expensive side as compared to getting this one fixed but technology has moved a long way in the last 8 years. Thus, your current Freezer is going to consume more electricity and even after being repaired, the performance shall not be optimal. While, the new Refrigerator not only is going to be Lessen your electricity bill but shall be a better choice both in terms of Style, Structure, Optimization and Performance.
Oct 30, 2012 | Refrigerators
Hi, my Hotpoint ff200e fridge freezer is cooling but not freezing, compressor wires are warm and compressor itself is quite warm, top fridge is not cooling enough, then the lights on control panel start...
Hi.. feel the dividing rdge between fridge and freezer.. is it warm?.. chances are that the little fan at the back of the fridge freezer that helps cool the compressor, has snagged own it's own wire... it's a weak fan, like you get in a computer, but it does a lot of work.. without it, the coolent does not do it's job, which results in your device not cooling things properly
Apr 24, 2017 | Hotpoint HTM17BBSSA Top Freezer...
Water dripping insie the fridge
Water accumulating on the ceiling of the refrigerator is usually caused by a clogged drain in the freezer section beneath the evaporator. The clogged drain will cause water from the self defrost cycle to leak into the divider between the freezer and refrigerator. This water may then freeze and cause condensation build-up on the refrigerator ceiling. The solution to this problem begins with unclogging the drain. It may also be necessary to remove the entire freezer/refrigerator divider to thoroughly dry the insulation in the divider. Occasionally the insulation needs to be replaced to prevent a recurrence of the problem. This can be a big job – you may want to hire a qualified appliance repair technician.
Jul 28, 2010 | Frigidaire FRS26R4A Side by Side...
Divider between the fridge and freezer is hot to the touch, only from the outside the inside walls of both the freezer and fridge is cold, but the outside facing you as you open the door divider is very...
This is usually normal for these units it can depen on how long the unit is running in a cooling mode.
the other thing to check is the condensor fan in the bottom back side of the fridge and make sure it is running if it is not the it needs to be replaced this will also cause alot of heat on the fromt of the unit
Jun 03, 2010 | Kenmore 53642 / 53644 Side by Side...
Side by side. Front edge of divider between fridg
There is a heater there that reduces condensation. If you have a switch that has energy saver mode, that would turn it off
Sep 04, 2009 | Refrigerators
The divider between the side by side frigerator/freezer where the door closes and seals is extremely hot- too hot to touch. Is something wrong with my refrigerator
The divider between the side by side frigerator/freezer where the door closes and seals is extremely hot- too hot to touch. Is something wrong with my refrigerator, should i unplug it?
Aug 25, 2009 | Kenmore 53642 / 53644 Side by Side...
Door frame is always hot on freexer side
Is it hot all the way around, or just on the face of the divider between the freezer and fridge? If it's just the divider, then it's probably not a defrost problem. When that divider gets hot, it usually means there is inadequate air flow over the condenser coils outside the unit.
When the compressor is running, check for air blowing under the unit. If no air is moving, then you probably have a failed condenser fan. If the fan is running, then use your vacuum cleaner to clean the coils, and make sure there is space behind the fridge for air to flow.
Jul 21, 2009 | Maytag MSD2756G Side by Side Refrigerator
Divider red hot
I'm not familiar with the Samsung refrigerators, but on most side-by-sides the evaporator (cooling) coils are located within the divider partition between the two sides.... along with the defroster 'heater' coils. During the defrost cycle, this panel may feel warm/hot to the touch. Are the freezer/refrigerator sections staying as cold as they should be otherwise? If they are also TOO WARM, then you may have a 'defrost cycle' relay or timer motor malfunctioning.
also see if the fan works properly.
Good luck..
Aug 09, 2008 | Samsung RS2630SH Side by Side Refrigerator
Samsung side by side center divider front extremely hot
That sounds like you may have something in your condenser fan motor.. piece of bag, paper and may have stopped your fan altogther.. that would be the first place to check.. right by your compressor in the back of frig.
Aug 21, 2007 | Samsung RS2630SH Side by Side Refrigerator
Samsung RS2630SH Side by Side Refrigerator Logo
236 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
