HP Photosmart d7368 ink system has failed" errer 0xc18a0401
  • 3,600 Answers
If you want a good printer get a HP all in one very reliable your ink cartrdge print head burned out and you have to buy a replacement head about $50.00 US plush shipping.
Posted on Jun 26, 2009
Wrong code c18a0001
That is a Ink System Failure Code. The best you can try what is offered below from HP. You cannot remove the printhead so if the reset does not work, you will need to take it to get serviced.
Fault code on the printer is 0xc18a0401
Jan 29, 2015 | HP Photosmart C5180 All-In-One InkJet...
Error 0xc18a0401 on HP 3310
Get together with HP on this problem. The software in the printer may be corrupt and may need to be flashed into it again.
Oct 01, 2012 | HP Photosmart 3310 All-in-One Printer...
Ink system failure error no. 0xc18a0401 Won't let me print or anything.
Hello
Have a look at the link below, it should assist you in solving your problem.
Click HERE.
Kind regards
Michel
Nov 19, 2010 | HP Photosmart 3110 All-In-One InkJet...
0xc18a0401 ink system failure error on hp C6180 printer
Check out this link.
http://www.out-of-warranty.com/ink-system-failure-error-0xc18a-hp/
Apr 28, 2010 | HP Photosmart C6180 All-In-One InkJet...
Error ink system has failed,error 0xc18a0401. this is the second time this week this has come up HELP
try a power reset of the printer if that fails try pressing and holding #6 on the printer as you reconnect the power cord... if this fails to clear the error message
you will have to purchase a new printer
Mar 27, 2010 | HP Photosmart C6180 All-In-One InkJet...
HP ERROR CODE 0XC18A0401
There is one fix for the 0x errors and it doesn't always work but this is the only option.
Press and hold the "*" key. Press the "#" key and release both keys.
Display should say "Enter Special Key Combo"
Press and release in sequence the "1", "2" and "3" buttons.
Display should say "Support" and display the FW rev (something like R0631R)
Mine reads R0631M
. Press and release the right arrow button until the display says "System Configuration Menu".
Press and release the "OK" button.
Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",
Display should say "Hardware failure status: Clear. Press OK to clear".
Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer.
Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK. The Printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page. Good Luck!
Sep 22, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart d7368
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print.
Solution
Press the On button to turn the printer off.
Unplug the power cord from the back of the printer.
Remove all the ink cartridges.
Wait two minutes.
Plug the power cord into the back of the printer.
Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Jul 16, 2008 | HP Photosmart 3210 Printer
HP Photosmart d7368
Here is the document that i want you to follow correctly inorder to solve your issue.
CLICK HERE TO VIEW==>> DOCUMENT
Please let me know the outcome after following the document.
Thank you so much.
adonscott
Jul 16, 2008 | HP Photosmart C6180 All-In-One InkJet...
229 people viewed this question
jasbo
jasbo
