Question about Refrigerators
FRIGIDAIRE GLRT13TEB3 FREEZER WORKS BUT FRIG DOESN'T.HAVE COMPLETELY DRFROSTED FRIG/FREEZER AND CLEANED COILS.HAVEN'T HEARD FAN IN FREEZER WORK YET.CAN'T FIND DEFROST TIMER ANYWHERE TO CHECK IT.ANY SUGGESTIONS ON WHERE IT IS OR ANYTHING ELSE I CAN DO? ICEMAKER AND FAN IN BACK ON BOTTOM OF FRIG STILL WORKS.
  • kdnewman79 Jun 27, 2009
    OK NOW WHAT? I HAVE FOUND ATHE DEFROST TIMER AND TURNED IT,ALL I HEARD WAS THE FAN ON THE BACK/BOTTOM OF THE FRIG KICK ON.MY FAN IN MY FREEZER HASN'T WORKED YET , AND EVERYTIME THE EVAP COILS FREEZE UP.SUGGESTIONS?
  • 351 Answers
U have a defrost problem and should have not really defrosted in till you tested the parts...
Posted on Jun 26, 2009
  • Mark Nichols Jun 27, 2009
    if you can visit my site at whirlpoolpartssurplus.com and get the phone number off of there i can help you on the phone in no time FREE!
Why is freezer/Frig at 51/59 degrees with both fans running?
Good Morning Friend,
I understand your Frigidaire refrigerator, model# FRT18G6JB6, is not cooling well. I also see that you have checked the gaskets, cleaned the condenser coil, and manually defrosted your refrigerator. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine why it is not cooling. Hope this is helpful,
-Best Regards-
WP
Jun 23, 2014 | Frigidaire Refrigerators
Freezer works, frig doesn't
there is a fan on many newer units that blows cold air from the freezer side to the frig. If that fan is not working, the frig will be cool, but not 34° like you want it.
Nov 25, 2009 | Frigidaire Refrigerators
Frigidaire refrigerator does not seem to be cooling or freezing completely. Frigidaire refrigerator does not make any noise and does not seem to be cooling or freezing. I have checked the back of the unit...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
nmnm
Sep 24, 2009 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire Side By Side Not Cooling
That sounds like the start relay is buzzing. Unplug and lets check the compressor to see how hot and if too hot to hold your hand on the top of compressor we need to leave it unplugged until we find out if the start relay, start capacitor, overload or if the condenser fan stops after running a short while. Sea Breeze
Sep 13, 2009 | Frigidaire FRS3R5EMB Side by Side...
Freezer cold but not frig. section
Switch off frig and let it completely defrost.
Jun 27, 2008 | Maytag MTF2155GRQ Top Freezer Refrigerator
Dead Upright Frigidaire Freezer
YOU MOST LIKELY HAVE A FREON LEAK AND RUNNING THE FREEZER WITHOUT FREON IN IT WILL KILL THE COMPRESSOR UNLESS YOU UNPLUG IT AND GET IT FIXED,THE COILS ON MOST FREEZERS ARE IN THE SIDE WALLS SO YOU DON'T HAVE TO CLEAN THEM LIKE ON YOUR FRIG.HOPE THIS HELPS-MIKE
Jun 16, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
Kenmore refrigerator model #106.53502300
Clean the coils.
If you have then there is a small fan that blows air across these coils, it is on when your freezer turns on. This would allow you to see if fan works. (usually when the fan fails you loose your freezer, bad repair people won't tell you to check fan)
Seals are a big issue. A good test put dollar bill into the door and try to pull out with door closed. It should be hard to remove. Seals are cheaper than new frig. A small air leak will lower cooling
Dec 01, 2007 | Frigidaire PLRS267ZAB Side by Side...
My frigerator
This will get warm. If very hot check and clean coils in front, underneath. Also check fan behind rear panel. It should be turning when the unit is running. Also check for door not closing properly.
Nov 12, 2007 | Frigidaire FRS3R5EMB Side by Side...
Freezer not freezing
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, controls should be in the middle setting, you can try turning freezer to Warmer freezer allowing MORE air to refrigertor side.
Sep 05, 2007 | Frigidaire FRT17G4B Top Freezer...
Refrigerators Logo
114 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
