Tivoli Kloss Model One AM/FM Radio Logo
A
Anonymous Posted on Jun 15, 2014
"tivoli model one" - Tivoli Kloss Model One AM/FM Radio
1helpful
How do you remove the speaker balance knob on a tivoli model dab radio situated on the rear panel.
Usually they pull right off. Unless you see a hole in the side with a hex key screw, it will pull off. Just pull gently and steadily and it should merely pop off.
Transformer to old PAL Tivoli been eaten by rats. Where to find another for this old model
Try radio shack in States, Maplin in the UKand other similar retailers elsewhere. Also, if you can identify it try ebay, they carry a lot of these parts
Hello, I purchased a Tivoli Model One few months ago and I noticed that after tuning a radio station (strong signal, amber light on), the signal will fade out in ten minutes or so and I need to tune it...
hi,
it looks like its got a hookup for an external antenna on the back, hook a wire to it or better yet hook it up to a pair of rabbit ears, look at the back and make sure your hooking it up to the right connector am/fm
rabbit ears at walmart
..jm
Tivoli Audio Frequently Asked Questions Tivoli Audio
8260f424-51e7-404b-8aad-55d32a5ee6ab_1.c6ade34e7d92de1dbfde961d78f8c87b-2mys2t2nr3la4vnxyourkcko-2-0.jpeg
Hello, my Tivoli radio was brought to Australia after an overseas trip to America. After adapting the plug I connected it to the power point. As I now know- the different (higher) voltage in Australia...
Hopefully this is just something simple like a blown fuse but here is a link to some recommendations on how to repair the radios
https://www.techwalla.com/articles/how-to-repair-a-tivoli-radio
Tivoli model Satellite will not turn on. Had intermittant power issues. Moved the radio and it will no longer power on
The power control problem is easy to fix.
It can as simple as a fuse (I'm sure you check it already) or a switch that is piggy back on the volume control.
Radio Shack has a similar one HERE
Disconnect the AC outlet and open the main Tivoli unit.
Look at the back side of the volume switch and you will see a power switch piggy back onto the volume control.
You can bypass it or get the correct value Potentiometer + SPST switch.
Use an ohm meter to meter the both end of the potentiometer and if it's 10,000 ohm or 10k then just go to Radio Shack and ask for
10K-Ohm Audio Control Potentiometer with SPST Switch Model: 271-215 | Catalog #: 271-215
It's a direct replacement.
If the ohm read is other then 10K then you will need to order it for an electronic supply house.
Tivoli makes great radio.....if you want to sell it I want the first dip.
When I insert a disc into the Tivoli CD player - it immediately shows a message "no disc" and rejects the CD
Ah yes, very annoying problem. I am still searching for the solution and trying not to have nervous break down in the meantime.
1helpful
Tivoli Model One Radio Humming only, no reception
The fuse would cause a total absence of power. Your problem is likely a blown filter capacitor in the power supply. Unless you have electrical/electronic skills, the radio will require professional repair.
2helpful
Tivoli model two - low/no sound in base unit
I have exactly the same problem but found two work arounds, either one that I am completely satisfied. 1. unplug and replug the AC.
2. I have a subwoofer, when I plug the subwoofer cable half way in, the sounds of the base speak goes back to normal (but not all the way in)
2answers
Tivoli Radio,
Does your radio have a sleep button or option? If so, check to make sure that you did not set it on accident or with out knowing. Or if it has batteries, check them to make sure they aren't dead or mixed with old or new.
Top Tivoli Audio Players & Recorders Experts
John
John
Ngoro
Are you a Tivoli Audio Player and Recorder Expert? Answer questions, earn points and help others
