Question about CMT Saws
I have a 20 year old table saw of unknown manufacturer (but all machne parts are metric). The spindle pulley (mounted on motor spindle - it accepts v-belt from motor pulley) keeps coming loose. i think the socket screw holding it in place is close too loose to prevent it from loosening with use. Any ideas of how to re-tap the pulley? find the manufacturer (if still around?)
    Sergeant:
  • 384 Answers
Simple, there are two options:
1) buy a new pulley from any hardware or home improvement store.
2) If threads are stripped from pulley, either retap with next larger size tap, or redrill new hole and tap with same size as the current size. Note the best way to keep pulley on is to have a set screw over the key and another at 90 degrees from keyway. Note 2 - Are you sure current pulley does have two set screws?
Posted on Jun 26, 2009
Craftsman model 137.415030 10 in portable table saw won't turn on. It is getting power the switch sounds like it is working ok but it won't turn on. The reset button ,does not appear to do anything.
My table saw motor just stopped.. What do I do? - The WoodenBoat ...
forum.woodenboat.com/showthread.php?...table-saw...I...
WoodenBoat
Apr 6, 2013 - 23 posts - ‎20 authors
Does the motor have an internal thermal cutoff switch? ... Auto reset on a table saw, now that would be scary. ... A Craftsman, I think. ... The saw is a Grizzly 1022Z contractor-style saw about 10 years old. .... After the motor cools down the switchneeds to be pressed to restart the motor, it won't start suddenly ...
My table saw stopped, the reset button won't reset. What ...
www.shopyourway.com > Manage My Life > Questions
It is a Craftsman Table Saw Model 137.248880. ... I pressed the reset button and the saw restarted. I continued ... My table saw stopped, the reset button won't reset. ... One was just the switch the other the rocker switch, identical except in cost.
Craftsman 10 table saw motor stalled - Yesterday's Tractors
www.yesterdaystractors.com > Discussion Forums > Tool Talk
Dec 25, 2015 | Craftsman 21802 10-inch 13-amp Portable...
I have rehabilitated an old Craftsman model 113.22411 10 inch bench saw, but I'm missing the guard unit -- can you suggest a guard unit available today that would fit this saw?
Use the first part of the model number to fid who the manufacture of the saw/ motor is. Example: 110.123456- 110 is Whilpool. Then cal the manufacture direct.
Jan 24, 2014 | Craftsman Sears Table Saw Manual Model...
I was recently given and older Craftsman 10" table sawa. It worked great for cuttin some 2x4 and now all of a sudden it will only cut part way7 and than stops, and it smokes--Help!!
The problem could be one of the following:
1) dull blade, in which case replace with a carbide-toothed blade
2) underpowered or old/faulty electric motor
3) faulty/worn belt, in which case replace with new belt
4) The pulley on either the motor or the saw arbor (where the pulley attaches underneath the saw near blade) could be loose. Tighten down set screw.
5) The saw fence isn't set straight causing the wood to jam as you push it into the blade. Check this with a framing square and readjust so it is at a 90-degree angle to the front of the saw table.
Sep 13, 2011 | Craftsman 10" Table Saw
The alumiun cast mount that supports the motor for my table saw is badly broken, can't find a part, it is a sear 10" and it attaches to table by sliding in two rod them secured in place with allan...
You could post your request at this link, but most likely you'll have to search ebay or the like to find one. Try to look for a manual there (or try www.managemylife.com) and get the part #, then search google for that part #. I suspect they are common to many different saws and a universal replacement could work...
Maybe someone who welds aluminum could repair it?
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 16, 2011 | Saws
I have an old craftsman table saw that I inherited and need a part that is no longer available from sears. It is a motor mount bracket at that how i describe it any clue on how to get one of these? ...
Dan, Take pictures of the area of your saw where the motor mount would be mounted, and any other mating parts (like the motor). Measure a few things like the distances between some of the holes. Go to Sears and look at the saws they have on display. You will probably find something similar that you would be able to use with little or no adaptations. Write down the model number, go to this link and look up the part. http://www.searspartsdirect.com/partsdirect/index.action Please vote if this is helpful. Good luck, Al K
Jan 29, 2011 | Craftsman 10" Table Saw
Pulley on motor tilted to left and belt keeps coming off
jim, Yes. The motor should be mounted to a bracket with 4 bolts. Loosen these, align the pulleys, then tighten the bolts. You can see the four elongated holes in the base of the motor at the following page. Scroll down until you see the 9 product diagrams. The one labeled "Motor" shows the four holes in the base of the motor.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=315.228390&pathTaken=partSearch
Mar 22, 2010 | Craftsman 10" Table Saw
I have recently replaced my 29 year old craftsman 10" table saw with a new switch. In trying to turn it on, the motor hummed, slightly oscilated and tripped out the wall breaker. I checked the Sears parts...
You may find a replacement motor on ebay. I deal in Craftsman Belt drive table saws, yours looks to be a direct drive. Sorry I wouldn't be much help with those, Jim
Oct 21, 2009 | Craftsman 10" Table Saw
Motor base needed for 10" table saw
My 10" Craftsman saw started life with a 1 hp motor. I'm on number 3 motor which is 1 1/2 or 2 hp. 1 hp seems to weak. The pulley diameter is about 2". The motor needs to rotate as the blade is moved from vertical. Mine is mounted to back of the blade arbor. The mounts needs to be adjustable for adjusting tension to the belt. McMaster Carr would have the start of a motor and base.
Sep 11, 2009 | Craftsman 10" Table Saw
Rear pulley arbor to short
Got bad news from Sears on this one, they say there are no serviceable parts for this tool and to contact them. Sorry I couldn't help more.
Jun 22, 2009 | Craftsman Saws
Blade doesn't stay straight. bent spindle?
if the blade is mounted on the motor shaft? if it is, then you need to replace the motor bearing.
Apr 12, 2009 | Saws
Saws Logo
100 people viewed this question
Top CMT Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a CMT Saw Expert? Answer questions, earn points and help others
