Question about Kodak EasyShare V705 Digital Camera
Need to replace lcd screen does anyone have the instructions on to do this?
I need to replace my LCD Screen. Are there any instructions on how to do this?
The following websites give step by step instructions on how to replace the LCD screen:
http://camerarepair.blogspot.com/2007/11/fixing-or-replacing-broken-lcd-screen.html
Jan 14, 2011 | Pentax Optio A40 Digital Camera
Nikon Coolpix S210 lcd broken - need step by step instructions
Most cameras are not that hard, if you are careful and willing to make notes of where each screw came from.
Be sure to get the correct screwdriver to fit the screws correctly and use enough pressure directly to loosen each screw...this is quite important, because if you strip the screw's head, it can be messy.
Most LCD screens are directly under the back cover, and can be replaced usually, once the back is off, remove three or four screw which will hold the LCD frame on. Once that is loosened, then you can carefully remove the screen and see if you need to remove anything else before loosening the cable plug. Take care here, because there are a few different ways these cables may be connected. Some are simply pushed into a connector. Some have a socket which has locks which must be loosened to remove the cable. These little sliding plug connectors are delicate, so you must take it slow and not rush the job. Some of these fold up to loosen, some simply slide away a bit to loosen the plug lock.
Most anyone who has done any delicate work on anything electronic will understand what I am talking about here.
A repair manual may be able to be downloaded for free, but you may have to be a member (usually free) in order to download manuals. Some may charge a small fee for the pdf file.
Hope it all works okay.
Sep 11, 2009 | Nikon Coolpix S210 Digital Camera
Replacing the screen on an HP DV2040TX notebook computer
http://www.lcds4less.com/laptop-lcd-removal-instructions.shtml
Jan 01, 2009 | HP Pavilion dv2000t Notebook
Nokia 6101 Cellular Phone
I think you can't do it alone!! It needs professional service. Bring it to the nearest cellphone service shop and let them replace or do it.
Sep 24, 2008 | Nokia 6101 Cellular Phone
N76 lcd screen replacement
take the phone to a mobile service center to have them replaced the lcd for you.
Jul 08, 2008 | Nokia N76 Cellular Phone
Kodak EasyShare V705 Digital Camera Logo
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
