Question about Troy Garden
Is the nut for blade removal left handed or right
On a Troy Bilt triple blade edger is the nut for blade removal left handed or right handed?
  • 181 Answers
It is right handed.......
Posted on Jun 26, 2009
How to put on new belt
https://www.partstree.com/parts/troy-bilt/edgers/tb516ec-25a-516-966-troy-bilt-edger-2011/general-assembly/
Zoom into the diagram, remove (item 45) belt cover to expose the belt and pulleys. Take note of how the belt is routed.! you will need to follow the same route with the new belt. You may need to remove the Blade guard (item 40) if the belt doesn't fit over the head of the guard. There may also be a sprung idle tension pulley, which will take up the slack in the belt once replaced. Looks pretty straight forward.
Apr 19, 2016 | Troy-Bilt Troy-built Tb516ec 4-cycle Gas...
Starter rope is loose on lawn edger
remove the recoil housing and wrap the chord round the spool more to take up the slack
Feb 11, 2016 | Troy-Bilt Troy-built Tb516ec 4-cycle Gas...
Cant get the heas off trou-bilt weedeater on a 4 cycle # TB 525-ec
the bolt on the end has left hand threads not right hand the most bolts have
Apr 07, 2012 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
How do you keep the blade from moving while you loosen the nut to change the blade on a Troy-Built 9" lawn edger?
stick a block of wood inbetween blade and sheild or spacer behind blade may have a hole to put a punch or nail to keep from turning. hope this helps
Aug 14, 2010 | Garden
Troy Bilt 34073 mower - stripped spindle-shaft?
Bet on it- you might try adding an additional nut of the right size/thread or several washers to utilize the remaining healthy threads.
May 14, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Are the nuts holding on the blades reverse threaded?
If a blade, when viewed from above, rotates clockwise, it will have right-handed threads. This is because the shaft is turning to the right, and the resistance imparted on the blade will tend to tighten a right-handed fastener. If a blade rotates counter-clockwise it will have a left-handed fastener. I don't know this mower, but this is a universal thing.
Apr 23, 2010 | Husqvarna 26 Hp 54" Deck Zero Turn Riding...
How to replace air filter on Troy-bilt TB20CS?
May be air filter but sounds more like your muffler is stopped up. First take the muffler off and see if it runs better without it. If so, burn the carbon out of the muffler and clean the muffler port on the engine. If not, then remove the four screw at the very end and disassemble. The ait filter is in that area. Diagram is located at
www.stollerlawnandgarden.com/.
Click on parts lookup in left hand column.
Jun 24, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Can not remove troy bilt weedeater head
Once all the bolts are removed, tap all the way around, (with a rubber mallet), where the head meets the bottom portion of the motor. It should come right off with a little coaxing.
Jim
Jun 08, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Homelight MightyLite 17" Straight Shaft Trimmer
a lot of times there is a hole in the side of the head to insert a rod into so the head doesnt spin..now all you have to do is figure whitch way it turns as some a left hand thread
Aug 06, 2008 | Troy Bilt 17 Inch 29 Cc Gas Powered...
Garden Logo
365 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
