Question about Maytag Washing Machines
My washing machine feels level(doesn't wobble) but
My washing machine feels level (doesn't wobble) but tends to "walk" and move alot during the spin cycle. What can I do to stop this?
    Problem Solver:
  • 3 Answers
I fastened my wife's washer to the wall with heavy wire inserted into 4 pieces of rubber attached to the wall and the wash machine. Rubber stoppers about one inch in diameter are held in place on the back of the washer about four inches below the top with copper pipe fasteners used to attach pipe to wood. These are on the back near each side and the ones on the wall are in matching locations. I used a 4" wide board on the wall so the screws could go into the studs and the stoppers could go where they were needed without concern about studs. The two pieces of heavy wire (not easily bent by hand) is bent into a U shape with a flat bottom and short legs. The width of the U depends on how far your machine is from the wall.The wire legs 2 - 4" long are then inserted down into the rubber with the bottom of the U upwards. Wherever you drill to attach the stoppers on the machine be sure to avoid any wires or mechanical components and I attached them near the top for ease of removal for maintenance-- which should be seldom. This solution has held my machine in place quietly for the last seven + years.
Posted on Jun 26, 2009
My whirlpool top load washer vibrates bad and will walk across the floor during the spin cycle even with no clothes in it. I replaced all the springs, the unit is level. I don't know what else to do.
Check the giant flywheel on the back of the drum. Sometimes, the legs that make it up start to corrode and break. When they do, the drum will wobble.
Feb 08, 2017 | Whirlpool Washing Machines
Samsung washing machine wobbles on spin.
The feet of the machine have to to be leveled. When reading the instructions, leveling is important for the very reason you are having difficulties.
Sep 19, 2014 | Samsung 3.5 cu. ft. High Efficiency VRT...
Top loading washing machine tub wobbles a lot during spin cycle.
The top lifts off, then you can see the area around the drum and tank. There are springs and dampers that hold the frame and the drum steady. Check to see if they are broken or loose.
Feb 26, 2018 | Maytag Washing Machines
The machine is level but the drum spins as if it were not. loud and the machine moves forward
These new front load machines are much heavier and spin much faster than the top load machines. If you have old wood floors in your home or you live in a mobile home, the machine may tend to "walk" or vibrate on the floor. You can try putting something under the machine to help prevent it from walking as it is spinning.
Feb 23, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
VIBRATION DURING SPIN CYCLE
i would check the drum screws for tight fit. they might be a bit lose.
Mar 11, 2009 | Washing Machines
The machine does not spin properly. The tub
it sounds like the unit is not sitting on level ground sometimes there are feet that can be adjusted to raise and lower the unit on the front left and right side go to a department store and by a level for a couple of dollars and put it on the top exterior of the unit and check it left to right and front to back
Feb 21, 2009 | Maytag Performa PAV2200
Washing machine drum is very wobbly
* General tips
* Balance the load
* Level the machine
* Inspect the water pump for a blockage
* Inspect the coupling
* Inspect the transmission
* Adjust the drive belt tension
* Check the motor bearings
* Check the drum brakes
The above are possibly the general remedies for this problem.But possible if the problem still persists after this, possibly the drum bearings might have been damaged during the previous heavy vibrations.Please do post comments.Will be glad to help you out.Good luck.
Jan 16, 2009 | GE Washing Machines
Brand new front load kenmore wobbles and moves across floor
Unless your front loader is set firmly on concrete and leveled to perfection, the force of a heavy wash load spinning in excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Also due to the earlier movements during the spin cycle, the shocks that are used to dampen the spin cycle might have been broken or damaged.
If the problem persists inspite of proper levelling, please do check for the shocks or might have them replaced them for good.
Dec 09, 2008 | Kenmore 24032\24036 Top Load Washer
LG Front Load Washer Problem
The washer is not leveled correctly.  You will need to adjust the front feet to level the machine.  Run a load of clothes in the washer.  When it gets to the spin mode, check the level of the machine by pushing the front left corner and the front right corner.  If the noise quiets down on either corner of the machine, adjust the legs on that side.
Jul 22, 2008 | LG WM-1832C Front Load Washer
Washing Machines Logo
62 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
