Question about Kenmore Dryers
The dryer heats up initially but a few minutes later it goes cool .i have cleaned out the vent amd the screen but nothing has changed. natural gas dryer.
  • 351 Answers
Change the gas valve coils they are getting weak can send them free shipping today if you vis whirlpoolpartssurplus.com Mark
Posted on Jun 26, 2009
What causes my gas dryer to heat and the flame goes out
Try using timed dry insted of sensor dry if runs ok you need aew sensor strips. also make sure dryer vent is clean.
Aug 10, 2014 | Whirlpool Dryers
My Kenmore gas dryer only heats for short time. The burner comes on initially for about 1-2 minutes then cycles off. Later, the igniter turns on, but the burner does not come on. I have cleaned the...
if the dryer runs and heats for a short time and then no flame you have bad gas coils,when they are failing they work until they heat up and cut out,when they cool down the heat will work again for like the first 10 to 20 minutes and then cut out again.take out the two phillips screws on top of the gas valve,remove the top cover and change out the coils,check the coil with the three prongs on it or check the post you pull it off of,there should be a spacer on the post,if you don't see it on the post look in the hole of the coil,if it's in the coil poke it out and slide it back on the post,easy fix
Jun 12, 2010 | Kenmore Dryers
Gas Dryer lights but not drying. I have a White Westinghouse gas dryer on natural gas. It has a new vent hose and the filter screen is very clean and the vent area in the door is very clean. I even...
Sounds like the dryer coils are failing. The dryer may heat up in the beginning but once it runs for a few minutes the coils fail to open and let gas in. Check to see if you can hear the flame ignite after it has been running for a little while.
for a free video on this got to www.appliancehelponline.com/servicemanual.html
Feb 26, 2010 | Dryers
Mdg 4000aww turns on and heats when started. runs for 5 five minutes then flame goes out. ignitor glows but no flame. one minute later dryer still running ignitor glows, no flame. this repaets until turned...
Either the venting needs cleaned or the coils on the gas valve are bad. Unhook the venting from the back of the unit and run. If works ok then clean venting. If you still have the problem, replace the two coils on top of the gas valve.
Sep 29, 2009 | Maytag Neptune MDG5500AW Gas Dryer
I have whirlpool dryer that the heat seems to kick on and off it is gas dryer
If heats for a few minutes then cuts off (heat) , then the 2 coils on the burner valve are probably bad . OR check the vent hose to the outside for good air flow . Sometimes , a dryer is pushed too far back , and it kinks the vent hose . If coils are bad , when dryer cools down , then restarting , cool coils will heat again for a few minutes , then stop heating till they cool off again .
Aug 01, 2009 | Dryers
My kenmore model 70 wont heat. I replaced the coils, and gas sensor. the unit has been thoroughly cleaned. the igniter is heating up, the gas will light, then goes out a few seconds later. the unit is a...
Hi, Make sure the 4" vent is clean al the way outside. Make sure the vent hood in the wall is open. It sounds like the heat is short cycling do to poor air flow.
If the vent does not appear to be an issue, Watch the ignition while running and see if the ignitor glows later in the cycle and shuts down before the flame ignites. If this happens, you will need to change the coils on top of the gas valve. Please let me know if this helps you at all or if I can assist you further.
Thanks
Vic
Jul 27, 2009 | Kenmore 63942 Dryer
GE Profile Gas Dryer - Heat goes on and off
The operating coils get hot and quit. They only cost 20 bucks. Read more about it here:
Gas dryer works then quits then works some more
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 31, 2009 | KitchenAid KGYS850LT Gas Dryer
Maytag Atlantis MDG7600AWW Not Heating
the gas coils have a problem. as the dryer heats p the coils on the gas valve are failing causing the dryer not to heat. replace the coils and you should have no problem
Oct 22, 2007 | Dryers
Dryers Logo
43 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
