Question about IBM ThinkPad A31 Notebook
2nd hdd how do i install a 2nd hard drive in the ultrabay 2000.i bought a hdd caddy for the ultrabay and put a 20 gig hdd in for extra storage.but when i turned my laptop on it wouldnt bootup. said operating system not found etc. what do i do?i have a ibm a31
Re: 2nd hdd
You probably accidentally loostened the other harddrive. check.
Posted on Dec 28, 2007
  • 117 Answers
Re: 2nd hdd
This is os problem
reinstll or repair os
harddisk problm
Posted on Nov 06, 2007
0 characters
3 Points
Hi guys, how important is the hard drive caddy? my father bought a presario v5000 from a garage sale. i found out that the hard drive caddy was missing and the hard drive in it was broken as well. will a...
OK look any drive, that's is the format, ie: STA or IDE? and that will fit will work, that 320GB will be OK. Simply install the HDD in the bay, and then use a windows installation disk, or similar to format it, just format it as ONE big partition, that should be fine, IF you find that it will not "See" the HDD, then partition it into smaller partitions. However you should be OK. You need to FIRST test to see if the actual PC is OK, try a HDD before you buy a new one, make sure that it is actually working.
Oct 11, 2011 | PC Laptops
What size of hdd is supported by this laptop?
This is part of the A31 specification.
Hard drive features
  • A31 standard 2.5 inch 30GB
  • A31 standard 2.5 inch 40GB
  • A31p standard 2.5 inch 60GB
  • Supports two additional hard drives which can be used concurrently to offer expanded storage
  • S.M.A.R.T technology to issue an alert if a hardware failure is pending
  • ATA Bus Interface
  • 5400 rpm
  • Although you can upgrade the hard drive, it is not designed to be removed and reinserted on a regular basis. Repeated and frequent removal, for purposes other than to upgrade for greater capacity, can cause damage to the system. The Ultrabay 2000 hard drive adapter is designed to provide this flexibility with a second hard drive in the Ultrabay 2000
Dec 06, 2010 | IBM ThinkPad A31 Notebook
  • Supported HDD thickness:
    • 12.5 mm for systems without the touch pad
    • 9.5mm for systems with the touch pad
  • Standard 20GB, 40GB, 60GB HDD sizes.
    • The 60GB HDD orderable as marketing option part number 08K9688 has a height of 12.5mm and will not fit in the HDD slot of the systems with the touch pad installed. For these systems, it is only supported via the ThinkPad 2nd HDD Adapter for the Ultrabay 2000.
    • The 60GB HDD orderable as replacement service part number 08K9833 is 9.5mm.
  • Supports one additional HDD which can be used concurrently to offer expanded storage utilizing the Ultrabay 2000
  • ATA Bus Interface
  • 4200 or 5400 rpm
  • Although you can upgrade the HDD, it is not designed to be removed and reinserted on a regular basis. Repeated and frequent removal, for purposes other than to upgrade for greater capacity, can cause damage to the system. The Ultrabay 2000 HDD adapter is designed to provide this flexibility with a second HDD in the Ultrabay 2000 IBM says. I say if the OS recognises it and so does the BIOS, you're good. good luck, hope this helps.-jmattes p.s. I found this info on:
Oct 17, 2009 | IBM ThinkPad T30 2366 Notebook
I have windows vista just had a new hard drive installed the data off the old drive has been put onto an hdd caddy how do I load it back onto the new hard drive of my computer, the caddy is a plug in via a...
When you insert the usb cable from the caddy into a USB port on your notebook, Vista will automatically recognize it and open a dialog box. Choose to view files and folders.
Open another Window using Explorer and resize it so you can see the contents of your C: drive.
Then simply drag your files and folders from the caddy to the C: drive where you want them.
Remember that transferring program files will NOT help you as many of the files needed to run a program are located in other folders such as yours Windows directory. You will need to reinstall any software you wish to use.
This method is strictly for data transfer, as an example all your pictures, documents, spreadsheets, etc.
Sep 24, 2009 | Dell Studio 15 Laptop
I have a Compaq presario V2000. Right now I have 60gig internal hard drive. Is there a max internal hardrive I should purchase? I can buy up to 250 gigs? How much would you recommend I purhcase?
Usually, the more storage the better. You can go up to 260 gig total with a primary 100 gig drive and a secondary 160 gig drive. Note that with the extra drive, the unit will use more power so think about that first.
Mar 28, 2009 | HP Compaq Presario V2000 Notebook
I just bought a Compaq Armada 7400 (made in 1998) and it has a WIN 2000 on 10 GB HDD How do I remove the HDD from the caddy to install WIN XP PRO on a 100 GB HDD Thank you
Here is the drive removal instructions. Make sure you have enough memory for XP and that Compaq has drivers for your model.
Mar 01, 2009 | Compaq PC Laptops
Broken dell inspiron 2650, what do I need to do,
If you "accidently" can repair this laptop, then you get a reasonable good computer.
you will find the price for your RAM here:
you will find the price for your HDD here:
you will find the price for your HDD caddy here:
-> the rest is up to you
plz let me know how you are going regards /Teis
Jan 11, 2009 | Dell Inspiron 2650 Notebook
Removing the hdd in my toshiba 1135-s125
OK, This is a big undertaking if you are completely new.
1st, if you can get a static guard wrist band - great!
2nd You will be dealing with plenty of screws so keep track
In Toshiba notebooks most screws are marked. Here are some examples:
F4 - flat-head screw 4mm long
B6 - button-head screw 6mm long
F16 - flat-head screw 16mm long
B8 - button-head screw 8mm long
I have .a Toshiba Satellite 1135-S155. It should be a similar configuration, same family/1135-S1xx series.
You will have to remove a total of 9 Phillips screws.
Place the underside of the PC up.
Disconnect all power, cables and Battery from Laptop
The first screw is located just under the Toshiba Serial Number / Bar codes, just above where the DVD/CD-ROM combo drive is located.
Mine is labeled (F5). Unscrew it and place in a safe place.
Pull DVD/CD-ROM combo drive out it is an assembly.
The Hard Drive is located under the DVD/CD-ROM combo drive.
The Hard Disk Drive (HDD) is enclosed within a caddy containing the remaining eight screws.
There are four screws holding the caddy rails to the Laptop and four screws holding the rails, caddy and Hard Drive as an assembly.
Unscrew and place in a safe place/ container they are small. Disassemble the HDD from caddy assembly; place your HD in the caddy and reassembly.
Here is another Toshiba HDD access that is slightly more
straightforward than my 1135 series
So you get an idea of where a HDD is visually:
Above is a photo of the Battery sliding out
Below is the Hard Drive Removal
I hope this gives you an idea of how to go about it for your
particular Laptop
If you need further assistance, let me know
Feb 21, 2008 | Toshiba Satellite 1135-S125 Notebook
Not recognizing a hard drive
if u know to use soldering iron then try to resolder the connecter of HDD on the mother board...dont forget to remove the processor before do any thing...thats all....
Dec 21, 2007 | Acer Aspire 1690 Notebook
2nd hdd
both hard drives will need to be jumpered to a master and a slave or both have to be jumpered to cable select. normally the jumper setting are either on the label of the drives or are marked on the bottom of the drives near the jumper drives. if the setting are not shown find the drive type, model and capacity then do a google search for the drive "select the factory manufacture link" and search their site for the jumper setting of the type drive you have.
Dec 05, 2007 | IBM ThinkPad T21 Notebook
IBM ThinkPad A31 Notebook Logo
135 people viewed this question
Top IBM PC Laptops Experts
John mullen
 Mike M
Mike M
Level 1 Expert
Are you an IBM PC Laptop Expert? Answer questions, earn points and help others
