Rank: Apprentice
Rating: 81%, 4 votes
hi
robbinbryson, how are you, if you haven;t solved your problem as yet i think i can be of assistance. your printer is much the same as the hp photosmart 4280 that i have.
1. you got to pull the front folded panel down from the face of the printer.
2. lay the paper down on the flat surface of the panel you just pulled down.
3. gently slide the paper to the back, until it stops
4.then you can now print your documents.
5. the paper will come out of the upper section of that same tray and land on top, the rest is easy.
hope this helps, if it did please rate it and write back to let me know how it turned out. bye
