Question about Ricoh 4506 Copier
Ricoh MP 5000, says it has a paper jam, but I can't phyicial see a jam, wont print, scan, copy, or fax
  • Anonymous Mar 21, 2014
    You can print but you can't make a copy or scan a document. Only the copy button stays lit.
  • 541 Answers
Youmust make sure the paper drawers are open. the reset all the covers like the display says. i have had many machines only pull the paper out a little and say a jam but you can not see it. if this clears the jam make sure the paper size in the tray matches the size shown in the display , if they are differnt correct it. this will cause alot of paper jams.
Posted on Oct 11, 2009
  • 313 Answers
If the jam still shows when you turn the machine off and on then you will have to look first to see which tray you were using at the time take the tray out and look inside the frame to see if paper has stuck by the feed rollers then open the side paper path guide to check non is on teh way up from there the next is reg transfer and fuser sections also pull the duplex out to make sure its not under the travel plateand last is to check betweent ehfuser exit and finisher opent he dooor on finisher if you have one and lift the plate at top right had the paper can sometimes be hidden there... failing that the sensor for the paper exit from fuser to duplex can sometimes jam a small bit there...if you know how to get into the sp modes you can go to data log 1 there you have the jam counters and jam history look at latest and the area will show up where it could be last. good luck A..
Posted on Jun 26, 2009
What could the Grinding noise be that is coming from Ricoh Aficio MP C2550 for each page copied/printed?
Check for:
-broken plastic gear on right side of copier
-paper or foreign object in paper path
-paper or foreign object near fuser
Oct 15, 2014 | Ricoh Aficio Mp C2550 Copier With Feed,...
How to clear memory in a mp c5000 macine
There are many counters in this machine. Jam, Error, Feed, All, Memory, Service Codes etc, that are located in the service software of the machine. If you don't know what each one does you can end up doing more harm than good by wiping out the wrong ones. Best to call a trained tech.
Aug 14, 2014 | Ricoh Aficio Mp C5000 Color Copier - 129k...
Out of focus
Out of focus - Ricoh Aficio MP C4500 Copier with Print, Scan, Fax, Finisher
Jan 29, 2014 | Ricoh Aficio MP C4500 Copier with Print,...
The document wont print and we keep openeing and there is no documnet jammed
You may have a broken switch or paper sensor, that may have happened when the original paper jam was removed
Mar 25, 2010 | Ricoh Aficio MP 2000 Black and White...
Ricoh fax error #400
Possibly the fax line is open (busy). Try ringing the fax number, see what you get. Try unplugging the fax and plug a normal analogue handset into the line. See if you are getting a dial tone.
If not, then the cabling or line are faulty. Talk to your carrier. If yes then replace the cable on the fax (if possible) or have it looked at.
Mar 03, 2009 | Ricoh Office Equipment & Supplies
Ricoh 4506 Copier Logo
1,241 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
