Question about Amana NDE2335AY Electric Dryer
LEA30AW makes a humming sound when i hit start,
LEA30AW makes a humming sound when i hit start, does not turn the tumbler, and then the breaker pops off on dryer?
  • Anonymous Mar 13, 2014
    The dryer is making clicking sound as drum turns. As it hits on particular spot it clicks like it is hitting something. the inside is clear.
  • 351 Answers
Motor is most likely bad shorting out in the windings
Posted on Jun 26, 2009
Amana Dryer LEA30AW
usually the humming sound is coming from the motor,try this,open the door,turn the drum with one hand and hold the door switch in with your other hand and have someone else push the start button at the same time,this might help the motor turn on but if it does you need a new motor,if you can't turn the drum you could have something stuck in the blower wheel or something jammed in the motor like a broken belt but like i said a humming sound is usually the motor.
Feb 22, 2012 | Amana Dryers
I have a 115000 heater and when I turn on the switch the unit just hums and then it sounds like it blows an internal breaker and the humming stops
sounds like the motor start capacitor is bad causing the unit to stall and pop the internal circuit breaker...you will need to remove the cover and look for the silver can looking component that connects to the motor...you will then need to get a motor start capacitor to repair the problem ..these usually cost about 6-15 dollars at most appliance parts stores...or you can try a place like www.grainger.com
Jan 23, 2011 | Reddy R115DT Oil Filled Utility Heater
Dryer makes a humming sound and nothing else
Sounds like your tumbler motor is stuck. Try moving the inside of the dryer. Does it turn freely? If it does then the motor could be defective. If not the dryer tumbler could be jammed.
Dec 19, 2009 | Whirlpool Dryers
Kenmore Model 110 washer humming/popping breaker
Good day,
Anytime an appliance knocks a breaker down, the motor is the obvious culpret.
The first thing to do is remove the motor and take it to an appliance parts house for testing.
If the coupling broke, it is just sometimes just happenstance. In other cases it could be a transmission starting to lock up, which would overtax the motor, and eventually cause it to fail.
Lastley, most models are 2 or three speed. If the timer screws up and tries to run the motor on high and medium or low at the same time it will fry the motor.
Dec 10, 2009 | Kenmore Washing Machines
Frigidaire dryer hums when button is pushed in but won't start
ok can u turn the tumbler freely,
if no well there is something stuck in you blower like a sock or something
if the tumbler turns freely
keep the door open and hold the door switch
try pushing the start button
and tuning the tumbler, yes all three at the same time lol you may need a hand
try tuning the tumbler when you hear a hum
if it takes off bad news your start winding on the motor is bad or the capacitor depending on your model
if it does not turn, but the hum continues longer than 1-2 minutes it could be just a belt
Oct 19, 2009 | Frigidaire Electric Dryer
Amana dryer not working and just humming
you need to replace the belt, it is slipping
Aug 07, 2009 | Amana NDE2335AY Electric Dryer
Garbage disposal hum
Hi, Hit the reset again. It sounds like the cutter is lacked up some way. Try using a long wooden spoon ar something simular and see if you ca free up the cutter. If the cutter is free and it still will not work, you will probably need a new disposal. If you are getting no noise after you hit the reset, chack your breakers to make sure there is power to the unit. I hope this helps you. Please let me know if I can assist you further.
Thaks
Vic
May 14, 2009 | Kenmore Dishwashers
Humming oven clock
You'll need a new clock motor or clock unit. Once these units begin to hum, they must be replaced. Parts are available on the web, through supply stores or Sears Parts.
May 26, 2008 | Whirlpool Ovens
Amana NDE2335AY Electric Dryer Logo
432 people viewed this question
Top Amana Dryers Experts
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
