Question about Kenmore 3.2 cu. ft. Plus Top Load Washer
The washer stopped in the spin dry cycle. It will not do anything now no matter the dial setting.
  • 1,800 Answers
Hello.
  • Check the drain control lever
  • Test the drain control coils
  • Check the cam bar
  • Test the timer control
  • Posted on Jun 26, 2009
    Washer enters spin cycle but does not advance past the spin cycle
    William, do you mean it does not stop after spin? Usually spin is the last cycle. If it stops but does not switch after some time and the settings dial does not move, its a different story.
    Aug 19, 2013 | Washing Machines
    Hello The washing machine is not going through
    The lid switch has failed. It will not spin because it is a safety device.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
    Sep 09, 2010 | Kenmore 22422 Top Load Washer
    Washer stopped at the drain cycle Model LSR8233JQ1
    Could be either a bad lid switch or a bad water valve.
    Set the timer dial to SPIN and turn the machine on.
    If it spins the lid switch is OK. If it does not spin the lid switch must be replaced.
    Next,set the timer dial on a wash cycle and set the water temperature knob to COLD water. If it fills,the lid switch is bad. If it does not fill the water valve is bad or the cold screen filter is clogged.
    If the COLD does not fill,turn off the cold water faucet. Remove the cold water hose from the machine water valve and check for a clooged screen.
    If it does not fill with COLD water and the screen is clear,replace the water valve.
    Oct 27, 2009 | Whirlpool LSR5132PQ Top Load Washer
    Frigidare washer hums loudly and doesn't fill with water
    I figured out what was wrong with it. We narrowed it down to the pump or the timer. We determined that since the machine was spinning when the lid was down and it was spinning no matter where the dial was set, we figured it had to be the timer.
    We did have one issue getting the dial off the washer. The trick to it was to remove the pin from the middle of the timer and the dial just came right off.
    It was an easy fix really and the timer cost us $95.00 Hope this helps someone else in the future.
    Jan 05, 2009 | Washing Machines
    My Maytag Washer
    Hello
    Welcome to fixya.
    I'm Huuum and happy to assist you,
    The washer is equipped with a lid switch failure detector. If the lid switch
    should malfunction, the detector will stop operations for your safety.
    Read below
    First,turn the control dial to proper cycle and pull dial out to start the washer. If
    equipped with buttons, be sure they are fully depressed.
    Close lid and pull dial out to start the washer. For your safety, washer will
    not agitate or spin unless the lid is closed.
    should malfunction, the detector will stop operations for your safety. Call for
    service.
    Pauses are normal. Wait and see if the washer will start again.
    Please remember to leave a rating before you go!
    Thank you
    Sep 16, 2008 | Maytag Atlantis MAV6000 Top Load Washer
    Hoover washer dryer saver 1300
    I have inherited a hoover saver 1300 in new flat, the dials have worn away and it goes onto drying mode after wash, how can i have it on wash and spin only - NO DRYING? Thanks
    Apr 12, 2008 | Hoover H120M Front Load Washer / Dryer
    Kenmore 3.2 cu. ft. Plus Top Load Washer Logo
    80 people viewed this question
    Sal De
    fordexpert
    Jim Goldsmith
    Jim Goldsmith
