Question about Dell Dimension 3000 PC Desktop
Trouble booting computer have to boot several times to get to come up. it sometimes says ismi or idmp on a prompt
    Problem Solver:
  • 16 Answers
Before we get into any big details about your issue. Lets try something simple first. 1. Do you have your monitor on a surge protector? If so, replace your surge protector with another one, and see if things change. When a surge protector or wall outlet is going bad/or is bad it will not give off enough power to boot your pc correctly, causing it to shut down numerous times. This can be caused from wear and tear , black outs or brown outs , or lightning striking your house. If this does not work, we can go into other things.
Posted on Jun 26, 2009
    President:
  • Dell Master
  • 1,996 Answers
Well, to begin with, and FWIW, here's Dell's boot troubleshooter. A good place to start.
Leaving that behind, please see this article, and especially the 'supplemental reading" section. Also see here. and it's references.
I recommend you run chkdsk c: /f or /r (instructions here and here) to check your hard drive for corruption, and follow these steps (at least first 4) to scan for malware. That will establish a baseline for your system, and if you have further problems you can look toward hardware issues, driver conflicts and so forth. You may have some device that is sporadically failing and on its way out...
Also, if you haven't already done so, I highly recommend you install the xp recovery console (see here) before you have a situation where you really need it.
Finally, here's a somewhat dated but worthy boot troubleshooter that may help you diagnose the problem.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Free usb reboot
You might want to boot from a USB device, like an external hard drive or a flash drive, for many different reasons.
When you boot from a USB device, what you're actually doing is running your computer with the operating system that's installed on the USB device. When you start your computer normally, you're running with the operating system installed on your hard drive - Windows, Linux, etc.
How To Boot From a USB Device
Change the BIOS boot order so the USB device option is listed first. The BIOS is rarely setup this way by default.
If the USB boot option is not first in the boot order, your PC will start "normally" (i.e. boot from your hard drive) without even looking at any boot information that might be on your USB device.
Tip: The BIOS on most computers list the USB boot option as USB or Removable Devices but some confusingly list it as a Hard Drive option, so be sure to dig around if you're having trouble finding the right one to choose.
Note: After setting your USB device as the first boot device, your computer will check it for boot information each time your PC starts. Leaving your computer configured this way shouldn't cause problems unless you plan on leaving the bootable USB device attached all the time.
Attach the USB device to your computer via any available USB port.
Note: Creating a bootable flash drive or configuring an external hard drive as bootable is a task in itself. Chances are you made it to my instructions here because you know whatever USB device you have should be bootable after properly configuring BIOS.
  • Restart your computer.
  • Watch for a Press any key to boot from external device... message.
  • On some bootable devices, you may be prompted with a message to press a key before the computer will boot to the flash drive or other USB device.
  • If you do nothing, your computer will check for boot information on the next boot device in the list in BIOS (see Step 1) which will probably be your hard drive.
Note: Most of the time when trying to boot to a USB device there is no key-press prompt. The USB boot process usually starts immediately.
  • Your computer should now boot from the flash drive or USB based external hard drive.
Jan 02, 2015 | Computers & Internet
Start my pc on safemode
Windows 2000 and XP users Tip: If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 and XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers, if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally. Click here to get additional information about getting out of Safe mode.
loading the last known good configuration.To get into the Windows Vista and Windows 7 Safe Mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Safe mode - If after several attempts you are unable to get into Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Choose Advanced Options for: Microsoft Windows Vista
Safe Mode
Enable Boot Logging
Enable low-resolution video (640x480)
Last Known Good Configuration (advanced)
Debugging Mode
Disable automatic restart on system failure
Disable Driver Signature Enforcement
Description: Start Windows with only the core drivers and services. Use
when you cannot boot after installing a new device or driver. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally.
Aug 13, 2014 | Computers & Internet
My computer gives message "reboot and select proper boot device or insert boot media in selected boot device and press a key". I don't have a reboot disk.
That probably means the boot manager is missing or has an error. If the hdd is available in your bios, press F8 just before it would normally boot. There should be a menu that will allow you to repair windows.
Jul 24, 2014 | Computers & Internet
My computer fails to boot several times and when it does finally get to the desktop, it freezes and then goes off into power saver mode. how do I fix that?
Try running the Check Disk Utility.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
May 04, 2012 | Dell OptiPlex 360 Desktop Computer
How to put toshiba f20 into safe mode
when the computer first starts to boot up tap the f8 key this should bring up the options for booting into safe mode if not try f5.
May 02, 2011 | Computers & Internet
I have an acer aspire laptop with genuine vista os. i didnt operate for quit sometime and now, when i wanted to use it. it even didnt boot giving me a message. 'boot manager missing'. what is the problem...
If your Windows Vista computer has encountered the dreaded "BOOTMGR is missing" error, you aren't alone. If the problem isn't hardware related you can fix it with relative ease as long as you have a Windows Vista DVD handy.Boot off the Windows Vista DVD and then click Next at the first prompt:You should see a link in the lower left-hand side for "Repair your computer"The installation process will attempt to find your Vista installation directory. If there's more than one in the list, select the correct one and then use the Next button again.Click the first link for "Startup Repair".The installation process will repair the system, and then prompt for you to reboot.Alternatively you could have chosen the Command Prompt option instead, and use the following command to fix the boot options only:
bootrec /fixboot.
At this point you should be able to reboot your computer, remove the DVD and everything should be working.
Sep 19, 2010 | Acer Aspire 4730-4947 Notebook
"NTLDR" is missing"
Change your computer's boot sequence. Make sure that your computer's first boot sequence is the CD-ROM Drive.
1.Insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted.
2.When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
3.If you have a dual-boot or multiple-boot computer, select the installation that you must access from the Recovery Console.
4.When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
5.Enter in the following commands
COPY X:i386NTLDR C:
COPY X:i386NTDETECT.COM C:
[where X=CD ROM Drive]
Take out the CD ROM and type exit
Jun 13, 2009 | Asrock 775i65GV Motherboard
My Compaq PC says disk boot failure and asks to insert system disk. However, having had my pc for a few years, I have misplaced my sytem disk.
Check the bios to be sure that it sees the hard drive and if it does not then
Try (with the power off) unpluging the data cable from the hard drive and then pluging it back in then turn on the computer and see if it sees the hard drive. If it does and still no boot then its like the person said above and your boot sector is probably corrupt and you will need to boot with an xp cd to the recovery console and type this at the command prompt: FIXMBR and then type FIXBOOT then EXIT but try the unplugging the data cable and plugging it back in first..
Ive seen that problem several times and unpluging the cable and pluging it back in sometimes fixes it
Nov 23, 2008 | Computers & Internet
Boot up problem
you need to press f9 while its loading then go to command prompt, you want to then type in command bootrec.exe
then bootrec/fixboot and ten bootrec/fixmbr ....sometimes its just bootup and other times it will be drivers or dhll files causeing your computer to not want to boot, if you have vista you can press the f9 at startup and go throught the recovery wizard there are plenty of options there, i tend to have the same problems, but sometimes if i have something hooked into my usb ports it causes the boot up problem, so i unhook everything and reboot and it works.
if you need any more information you can message me at vmhreha@aol.com i have a ton more options you can do if this one i just gave you doesnt work.
May 15, 2008 | Toshiba Satellite A100-S2311TD Notebook
Boot-up
dot.gif How to load last known good configuration. Question: How to load last known good configuration.
Additional information: The "Last Known Good Configuration" option was first introduced in Microsoft Windows 2000 and is available in all later versions of Windows including Windows XP. This feature enables a user to load the last working version of Microsoft Windows. This is a great step to try when trying to fix issues with a computer not being able to load into Windows.
Note: Users able to open normal Windows XP mode and who wish to restore their version of Windows to an date before the last known good configuration may also wish to consider doing a system recovery in Windows. Additional information about how to do this can be found on document CH000589.
Answer: To load the last known good configuration in Windows 2000 / XP reboot the computer and as it's booting booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Last Known Good Configuration" and press your Enter key. Trouble Getting into Windows 2000 or Advanced Options menu - If after several attempts you are unable to get into Windows 2000 or Windows XP safe mode as the computer is booting into Windows turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the safe mode screen.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message as the computer is booting. If this occurs instead of pressing and holding the "F8 key" tap the "F8 key" continuously until you get the startup menu.
Please select an option: Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
As can be seen from the above example, you should be able to highlight and press enter to load the last known good configuration. Once completed the computer should restart and attempt to load into Windows. Will running the Last Known Good Configuration delete anything? No, running the last known good configuration will restore your last good system settings and will not delete anything. The only thing you may have to reinstall programs you have recently installed because the configuration for those programs may have been lost.
Dec 06, 2007 | Computers & Internet
Dell Dimension 3000 PC Desktop Logo
267 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
