Question about Fantom Titanium Hard Drive
Fantom hard drive red light!
Hi,I have a Fantom Titanium 250GB; I was copying large files to the hard drive and midway through the red light came on and a message came up saying a file could not be copied because the drive was corrupt. It was working fine yesterday. I ran scan disk and it is unable to finish and the red light just stays constantly on. Help!
    Problem Solver:
  • 14 Answers
There are no drivers for this unit. It is a plug & play unit that is one of the worst Fantom has ever offered. Very unreliable and many power cord problems.
I tried for several weeks to find the drivers over the net and researched a ton before I called Fantom Tech Support. The number is posted on New Egg under the their Mfg contacts
Posted on Oct 17, 2009
  • 36 Answers
The problem may be your PC. It may not have an adequate processor/memory to transfer large amounts of data. This can corrupt the files being transferred and you'd get a "write error" or the system will freeze on you.
I would download the HDD's manufacturer software and reformat. If you still have that error after wards...it is most likely your PC doesn't have the capabilities to transfer large amounts of Data. You can either upgrade the memory, add a eSata card... in order to do large data transfers (obviously your external has to have eSata capabilities to use the eSata ports).
Posted on Jul 02, 2009
  • Craig Boyer May 22, 2014
    There are 2 formats FAT32 and NTFS. NTFS will be able to transfer larger packets of data. You have to chose between FAT32 or NTFS when you initially format your hard drive. Most externals will come with instructions to give you step by step instructions how to format your drive. Read the instructions weveral times before you you actually try to format the hard drive. Once you have data on the drive, you would need to back it up on another drive if you have to reformat the heard drive. You will lose all your data that is on the drive when you reformat it.
Fantom drive MDU1000 use to work, now when I plug into the computer, it says I need to format the drive, but I know there is almost a tb worth of data that I need to retrieve.
you may need a new case with new electronics
this happens when the drive either has a corrupted file or the controller electronics has failed.
Sep 07, 2011 | Fantom Titanium-II (TFD200U2) 200 GB IDE...
I have a Fantom Titanium II FireWire+USB 500 GB Hard Drive that needs a new casing (blue light / red light / drive not spinning). I do not know if the current drive is IDE or SATA or something else. I...
Yes it does make a large difference. I did a search on that drive and there a lot of people who had good luck getting a replacement from the manufacturer. As far as a case is concerned I recently purchased one off of amazon and it was very inexpensive. Just look up "drive enclosure" on amazon.
May 02, 2011 | Fantom Titanium II (TFD500C16) 500 GB USB...
I am using Fantom Titanium 250GB External (TFDU25072B) Hard Drive i am not able to formate it i am using Windows XP Sp2 its giving me error " unable to formate " even i am not able to formate it...
The disk-drive inside the enclosure is problematic.
Open the enclosure, to get the model-number and serial-number from the label on the disk-drive.
Then, access Fantom's web-site, to check the warranty-status of the drive. If the warranty still is valid, they will replace it, at minimal cost to you.
If the warranty has expired, purchase a new, compatible, disk-drive, and transplant it into the enclosure, to "resuscitate" your device.
Oct 30, 2010 | Fantom Titanium 250GB External...
I have Fantom Drives Titanium 250GB i am not able
Connect it to a different computer. If it still is not detected, then there is a hardware problem. Exercise the warranty to get it repaired/replaced.
I have a Fantom Titanium External Hard Drive that makes a clicking noise. The drive doesn't show up in windows. I have alot of files on this drive and would really like to recover them. What if anything...
Hello
OK, at the link below you will be directed to a tip i wrote on this exact error.
Click HERE.
Feel free to let me know if you have any further questions.
Kind regards
Andrea
Oct 03, 2010 | Fantom Titanium Hard Drive
Drive not connecting to computer
1. Try connecting it to another computer.
2. Try a different USB cable.
3. Disassemble the unit, to find two parts:
* the USB-to-disk-drive adapter,
* the disk-drive
4. Connect the disk-drive as a "slave" in a desktop computer, and see if the disk-drive is "detected", and if you can retrieve your files.
5. Google-search for a "commercial data recovery service" -- you ship the disk-drive to them, they fix it, just long-enough to copy your files to DVD-writables, and they charge you a _lot_ of money.
Apr 16, 2010 | Fantom Titanium II (TFD500C16) 500 GB USB...
Fantom titanium external light turns red on connecting
Red is a failure warning but if it only hasppens with the usb plugged in it's mostly likey a failure in the IDE/SATA to USB conversion board.
Take the drive to your local PC shop, ask the techs there to pull the hard drive out of your phantom and test it in a new enclosure. If it works there, buy the enclosure, if it doesn't reply back and let me kow your Country, State and City and I can recommend a pro to look at the actual harddrive if you need files recovered from it.
Hope this helps FixYa
Sep 03, 2009 | Fantom Titanium Hard Drive
MY fantom drive TFDU20072 200 gb has worked for years, but today when I turned it on it doesn't show up on the hard drive of my mac. the light is constantly red with a blue flash every second or so. it...
Try the basics first. Unplug and let sit for a while before rebooting the drive. Then if nothing, get a copy of Disk Warrior and you may be able to regain access to the drive in order to save your data.
Aug 15, 2009 | Fantom Titanium Hard Drive
My pc and mac computer do not recorgnise my fantom drives
Hi, Mac uses a certain file system that windows does recognize the best thing i would suggest is mount it back to you mac and copy all the date to your mac then format the hard disk with windows ntfs files system. now u will be able to use it on both.
Cheers
Apr 27, 2009 | Fantom Titanium Hard Drive
Fantom Titanium Hard Drive Logo
701 people viewed this question
Top Fantom Computers & Internet Experts
Mohammed Ebrahim M
Mohammed Ebrahim M
Lyle Siemens
Lyle Siemens
Are you a Fantom Computer and Internet Expert? Answer questions, earn points and help others
