Question about Whirlpool Duet GHW9150P Front Load Washer
Control lock light on
The control lock light is on and the washer will not do anything.
  • 1,800 Answers
Hello.
  • Check that the washer is plugged in securely
  • Check the circuit breaker or fuse box
  • Test the outlet for current
  • Check that the water supply valves are turned on
  • Inspect the filter screens
  • Test for overheating
  • Test the water level switch
  • Test the timer control
  • Test the lid switch
  • Test the water inlet valve
  • Inspect the water pump
  • Test the centrifugal switch
  • Test the motor.
  • Plz give a good feedback.
    Posted on Jun 26, 2009
    5 Suggested Answers
    aborcass
    • 2651 Answers
    SOURCE: control locked light
    check your panel closly the lower right hand button is marked"control lock" hold for 3 secs and youll release the control lock
    Posted on Dec 21, 2008
    jsrock516
    • 5911 Answers
    SOURCE: "control locked" light is on washer
    The Control Lock is a safety feature that allows the consumer to lock the control panel to prevent small children from manipulating the controls and accidentally starting the appliance. This can usually be reset and does not require a technician.
    With the lock on, the control panel is disabled and you cannot use any of the controls, except the button to unlock it. It can inadvertently be set following a power outage, leaning against the control panel, or pressing and holding the wrong button. This is usually not an indication of a malfunction.
    If this is a Whirlpool manufactured appliance (such as Kenmore Elite or Whirlpool Duet), the following link explains how to lock/unlock this feature:
    http://www.fixya.com/support/r3608801-control_panel_lock
    These instructions are also printed on the front panel of the appliance and in the owner's manual.
    If this does not correct your problem, then you may have a more serious problem than a simple operator control button issue (such as an operator console problem or main control board issue). Please post back and let me know if you need further assistance.
    Posted on May 16, 2010
    • 662 Answers
    SOURCE: Duet GHW9150P Front Load Washer: control locked light stays on ,wont let you do any...
    Press and hold "end of cycle" button for 3 seconds, on the right side of panel. This is the child lock feature, do it again & it locks.
    If helped, pl rate me good!!
    Posted on May 19, 2010
    • 662 Answers
    SOURCE: Duet GHW9150P Front Load Washer: The control lock light is on so I can't do anythin...
    Depress the "end of cycle" button on your panel for 3 seconds, wait for 2 minutes, try the door. This is the child lock feature, do it again and it locks.
    Posted on May 22, 2010
    May 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    May 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Washer locked. door lock light blinking. start button light on. won't do anything.
    IT IS POSSIBLE YOU HAVE A DEFECTIVE DOOR LOCK OR CONTROL BOARD. CHECK YOU OWNERS MANUAL TOO SEE IF YOUR WASHER HAS A MANUAL RELEASE SO YOU CAN OPEN YOUR DOOR. USUALLY YOU CAN ACCESS A MANUAL RELEASE BY REMOVING THE FRONT BOTTOM PANEL AND REACHING UP UNDER THE DOOR LOCK AND FINDING A PLASTIC PULL PIECE WHICH YOU CALL PULL AND UNLOCK THE DOOR. MAKE SURE YOU UNPLUG THE WASHER FIRST. CHECK THE DOOR LOCK MECHANISMS TO SEE IF ANYTHING IS BROKEN AFTER YOU GET THE DOOR OPEN.
    Feb 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Control locked light on
    Try holding down the end of cycle button for at least 3 seconds.
    Jun 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    The control lock will not go off.
    Press & hold down 'end of cycle' button for 3 seconds, the lock will come off.
    Apr 03, 2009 | Whirlpool LHW0050PQ Front Load Washer
    Whirlpool duet 9400 Washer won't do anything?
    Hi.
    Please read the Fixya article below explaining how to fix the problems related to control lock on Whirlpool dryers and washers.
    The front light lit on my Whirlpool.
    Regards.
    Dec 27, 2008 | Whirlpool GHW9400 Front Load Washer
    Dec 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Control Locked
    you have to push a button on right side which tells you to hold down this button for control lock
    Sep 14, 2007 | Whirlpool GHW9400 Front Load Washer
    Whirlpool Duet GHW9150P Front Load Washer Logo
    102 people viewed this question
    Sal De
    Gerry Harvey
    Gerry Harvey
