Question about Compaq Presario 5000 PC Desktop
Opening the Case
I have a Compaq Presario PRE S5400NX DM175A desk computer. How do I open the case to add memory? And how do I add memory? Will I need tools? Thank you.
  • 433 Answers
Go to Compaq website for support. They explain everything.
http://h10025.www1.hp.com/ewfrf/wc/prodinfoCategory?lc=en&dlc=en&cc=us&product=374513
Hank
Posted on Jun 26, 2009
How to add or change DDR2 Memory Compaq Presario SR5110 desktop computer
Just remove the power cord, open the case, turn the computer on it's side and you will see the memory sitting in the slots. Push down on the latches on both ends of the memory slot and then you can pull the memory out.
Be sure to replace it with compatible memory or it will not boot up. Also it you install more than your system will hold, it will not register the excess.
Try 4 All Memory website. It will tell the type, how many slots you have and the maximum amount of memory it can hold.
http://www.4allmemory.com
It looks like your system uses DDR2-PC2-5300 Memory. It has 2 slots and a total capacity of 4GB which means each slot can hold a 2GB chip.
http://www.4allmemory.com/memory/compaq-hp-presario-sr5110nx/
Jun 03, 2012 | Computers & Internet
How do I open the case on a compaq presario 7478
you can browse to the internet for dismanteling manual for you compaq.
Jun 30, 2011 | Compaq Computers & Internet
HOW TO OPEN THE TOWER CASE OF THE COMPAQ PRESARIO SR2170NX TO ADD MORE MEMORY
This is how to open the tower case of the Compaq Presario SR2170NX:
John
Jun 26, 2010 | Compaq Computers & Internet
How do you open a compaq presario sr1630nx computer to install memory upgrades
Viewing the back of your computer, you will see a large thumb screw, on the right side of the computer case.
It's to the right of that round ventilation opening. (Round shape with multiple holes in it)
Unscrew the thumb screw to the Left, to loosen it.
The side panel that the thumb screw is in, pulls back towards the rear of the computer.
If you look, there is a place to put your fingers at the end of the side panel.
(Raised 'Hump' in the sheet metal of the panel)
Hold the top of the computer case with one hand, pull the side panel back with the other hand.
NOTE*
The computer MUST be unplugged from power before proceeding!
Not only is there a possible issue for Your safety, but also the computer's!
You will fry out the Ram Memory stick/s if you remove, or install with the computer plugged into power.
Also,......there is an Anti-Static issue that needs to be addressed, BEFORE you reach inside your computer
Your body carries Static electricity.
Static will fry out the hardware components inside a computer.
(In a Flash!)
Work on a table. Computer unplugged from power, computer case open. TOUCH the metal frame of the computer case BEFORE you reach inside.
TOUCH the metal frame Before, you take those ram sticks out of their protective antistatic bags.
Should you get up for any reason, walk away, then return, Touch the metal frame again.
Refrain from touching the gold plated contact pins, on the bottom of the ram stick.
You can handle the ram stick anywhere, but on those contact pins.
The ram stick is coated with a see-through plastic.
The contact pins are not.
Should you need advice on how to remove, and install ram memory, please state so in a comment. (Top right of page)
This is HP Support, and the download page for the -
Upgrading and Servicing Guide, for the Compaq Presario SR1630NX,
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&lang=en&product=1122478&
On this page scroll down to - Upgrading and Servicing Guide.
Left-click right on the name.
This is a PDF file download. Give it a few seconds.
After you see the first page, you will note there is a download progress bar.
Let the file download all the way Before looking through it.
Should you wish to save this file to your computer, please come back, and state so in a comment.
The Upgrading and Servicing Guide has illustrations, and instructions for;
1) Opening the computer case. (Side panel)
2) Removing the Front Panel
3) Locating hardware components inside the computer
4) Removing and Adding a Drive. (Harddrive and Optical Drive)
5) Adding Memory
And a host of other information you may find useful.
Jan 06, 2010 | HP Compaq Presario SR1630NX PC Desktop
Trying to get inside my Presario S5400NX. How do I take the cover off?
well if u cant start a car! and you asked your friend to start it.....do u think you will be able to drive it?!!!!!
...and if you do.....you will need your friend always by your side, cz you will have more and more questions!!!!!!
so what is the solution for your problem?
.....site in the car and try to start it alone, it will take a bit of ur time, **** it will give you much more then that! ;)
gd luck...and i hope that was usefull enough to get you started :)
Oct 24, 2009 | Compaq Presario S5400NX (DM175AR) PC...
Need to upgrade RAM
hi..ya you can upgrade the ram in your compaq
presario 5000.
check this out..
thank u..
kindly rate my response..
Jun 09, 2009 | Compaq Presario 5000 PC Desktop
Is there any way that i can replace my tower case on my Compaq Presario sr1520nx?
Compaq tends to be rather proprietary in their designs, usually a Compaq motherboard will only fit in a Compaq case, a Compaq power supply will only fit a Compaq case. That said there are exceptions such as hard drives, memory, etc.. If your present case is damaged you would do best to find another of the same model that isn't working and transfer your components.
Jun 07, 2009 | Compaq Computers & Internet
Opening the Desktop
Are you simply trying to open the case?
If so, do the following:
1) Perform a system Shut Down
2) Unplug the power cable
3) On the Rear of the case, look for a Scrow to the right edge (center), Unscrew it.
4) Slide the side panel toward the rear of case and it will come off.
Feb 14, 2009 | HP Compaq Presario SR1430NX (PS566AA) PC...
Opening up the case
hi dude., download the manual from the below link., its from hp official site., u wil find the solution to openup ur case... good luck
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&product=94494&lc=en&jumpid=reg_R1002_USEN
Jun 16, 2008 | Compaq Presario 7478 PC Desktop
Compaq Presario 5000 PC Desktop Logo
223 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
