Question about RCA DIRECTV Satellite Remote Control
Direct TV Remote Satellite Won't Receive Signal
My Satellite or receiver is not receiving signal even though i have the signal electronic finder. Worked just fine 30 miles north of here. Decatur Texas.76234 zip code
  • Anonymous Jun 06, 2008
    tv says searching for signal. Went to dish aiming, says off 3 degrees have moved dish , aligned with a compass and an elevation degree leveler still says searching . Installed a new lmd, same thing,both recievers say same thing. Direct says 3 degres only means dish not aligned
What is the AUX Fisher brand code for an RCA remote control model# RCR160SBM1
Posted on Dec 29, 2007
Is there a difference between a satellite receiver and a cable receiver?
Bunches. Cable boxes don't receive per se. They unscramble a TV signal that the cable company puts on the cable. A satellite receiver takes a hi frequency RF signal that it recovers from the antenna(dish and electronics) converts it to a lower frequency. It then demodulates the signal and processes the audio and video components so you can see and hear the program.
Nov 24, 2013 | Motorola Televison & Video
Why does my Trutech say NO SIGNAL no matter what I do?
Video processor section should be checked. Contact any technician.
Jun 13, 2012 | Televison & Video
I need the wireing to hookup to a tv.
Hi, it depends on the kind of TV your using...
How to Hook Up a Receiver to an HDTV
Though it utilizes the most sophisticated technology on the plant, an HDTV is extremely easy to hook up to a receiver. Home entertainment systems are designed for compatibility, whether it is a cable or satellite receiver, a DVD player or a stereo sound system.
Instructions
things you'll need:
* HD television
* HD satellite or cable receiver
* DVD player
* Stereo receiver
* AV cables
* Cable connector
* HDMI cables
Examine the back of your HDTV. You will see a series of input jacks for AV cables, (typically color-coded white and red for audio and yellow for video), as well as an antenna input and one or more HDMI input jacks. There will likely be a number of them, but each one should be distinguished with a label ("video," "cable" or something similar).
Attach the cable connector from the cable or satellite receiver to the antenna input on the back of the TV.
Connect the AV cables to the DVD player, VCR, stereo receiver or whichever other component you wish to connect to the television. The cables should line up by color: place the white cable in the white input jack, the red cable in the red input jack and the yellow cable in the yellow input jack. All three cables from each component need to go into the same label input jacks. Usually, they will all line up in a vertical row.
Find the HDMI output jack on your receiver or DVD player (some receivers will not have them--they are necessary to receive a high definition signal--but can still play on the TV through the cable connector or AV cables). Attach one end of an HDMI cable to the output jack of the receiver and the other end into the input jack on the HDTV.
Turn on the TV. Access the menu with your remote, and follow any instructions it gives you. Your HDTV may require a few additional steps to complete the hookup of the receiver (though not all of them will).
Access the "input" button on your TV remote. This will allow you to switch the TV signal to one of the cable connections you have just made. For example, if you attached the HDMI cable to the first of two HDMI input jacks, the TV will flash "HDMI 1" on the screen to tell you that is where it is receiving its signal.
Tips & Warnings
Not everything that can be hooked up to an HDTV is capable of playing in high definition. The signal needs to be HD as well, which means that only HD broadcasts, HD DVDs and Blu-Ray DVDs can play in full high definition (though "upgrade" DVD players will allow normal DVDs to play at an enhanced picture). You can still hook receivers up to an HDTV, and it will still play broadcasts from them as clearly as the signal permits.
Mar 15, 2011 | Audio Players & Recorders
I am trying to hook my tv up....what settings do I need to watch direct tv???
If you have a Sanyo TV with out audio/video connections, you will be using an RF connection cord between your TV and the satellite receiver. You will operate your TV on channel 3 or 4, match this with the channel 3 or 4 on the receiver box.If your TV has audio/video input connections, you will need to purchase rca connectors. They will have a red connection for right audio, white connection for left audio, and yellow is your video connection. The color codes will be on the input connections on the TV and the satellite receiver as well. You will than program the TV to input one or two, of the TV to receive the signal from the receiver. Use the satellite remote to control channels on the receiver box. When you are through watching TV, be sure to shut off your TV as well. Thanks for asking and show a few hands of support!
Feb 19, 2011 | Sansui Televison & Video
Lost the direct TV signal to the TV when nephew pushed a button on the remote (he doesn't remember which button) The other TVs in the house receive signals per usual.
Your nephew must have pushed the "Input" button on the remote. The TV is now looking for signal at a different input.
On the remote, press the input button until the TV switches back to the correct input. Make sure the satellite receiver is turned on so when the TV lands on the correct input, you will know it.
Dec 17, 2009 | Cars & Trucks
Direct tv came with apartment. has never worked says NO Signal on the screen I had cable put in but why pay for somethiing that is already included? I have tried everything but since it is not in my...
Try calibrating the antenna to the nearest satellite. The DirecTV box has in the installation menu instructions on how to do this. You'll need some tools like a socket wrench to unlock and adjust the antenna. Put in the menu your global position or your city and select the transponder that gives better signal. If all satellites are out of signal, move the dish until you receive at least one.
To calibrate the dish from the ceiling or wherever it's installed, put the TV volume up until you hear the short "BOOP" sound from the dish location. When you get signal, the "BOOP" will turn to a continuous "beep" with a higher pitch when higher the signal you're receiving. After getting the best signal, switch transponders to see if there's another with better signal, after that, lock the antenna and try watching a channel.
Nov 04, 2009 | Philips DIRECTV H20 DTV Receiver
My television don't receive any signal from my satellite cable
Frist u have to make sure there is no break in the anternna cable, then see to it that there is no dry joint in the tuner p
Aug 29, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
MENU PICTURE ON TV BUT NO CHANNELS
This is a problem with weak signal strength, You will need to find a better place to put your television so it can receive enough signal to operate correctly. If this does not solve the problem, you will need to check the satellite box for problems with receiving the signal from the satellite. You may need help from the satellite company to check the signal strength output and input levels to make sure its working properly. I hope this information helps you solve you problem with the loss of satellite signal in your television. Thank you for using FixYa and have a nice day!
Jun 18, 2009 | RCA DIRECTV Satellite Remote Control
N2750W PROBLEMS WITH DIRECT TV
just press the "PIP" button on the remote it happened to me and i just thought that it looked familiar and i pressed it and it worked hope it helps :)
Nov 19, 2008 | ViewSonic N2750w 27 in. HD-Ready LCD...
Combining output from dish home distribution with ota antenna
You should have your system setup in the following manner below:
You also will only be able to receive the HD locals with a HD OTA antenna. It is possible that you will need to turn the satellite off in this room to view the OTA's effectively.
Also you should use a splitter as depicted in the picture by the red boxes to combine signals of this frequency. The blue box is the diplexer on the incoming satellite feed and the black box is the seperator that most dual tuners use. If yours does not utilize this device you will have another cable coming from the outside of the house to the back of the receiver. The location of the ports on the back of the receiver in my diagram may differ in position on your receiver so obviously connect them to the proper port. I hope this ressolves the issue and there is no need to seperaate the signal at the remote tv as it will only be a duplicate of the same signal you have connected already as OTA and the TV2 backfeed are of the same frequency range.
Sep 18, 2008 | DISH Network Televison & Video
RCA DIRECTV Satellite Remote Control Logo
853 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
