SOURCE: After defrosting the freezer the whole fridge doesn't work (is warm!)
sounds like the compressor is locked up or the relay on the compressor is bad. whats happening is its drawing too much current and cutting out from the overlaod relay. that may be a bad compressor or the start relay. both the overload and the relay are under the black box on the front of the compressor. you will need to check the relay to make sure its good, and also the compressor. there should be a wiring diagram on the back that will tell you how many ohms from terminal to terminal on the compressor. hope it helped if its a newer unit the relays are electronic and if you shake it and hear like little sand pebbles in it most likley its bad and thats why it wont run.
SOURCE: have a diplomat fridge/freezer - the freezer is
check the air damper from the freezer to the fridge. most likely blocked with ice.
