Question about Refrigerators
Refrigerator i have a maytag top freezer the evaporator fan went out ,On the upper right side 2 wires are hanging one one bluish gray .One is for the light where does the other go and which one is witch. thamk you MTG2156geq
  • 420 Answers
If you look on the back of the fridge there is a wiring diagram.
Posted on Jun 26, 2009
Maytag 27.3 cu ft model #MSD2756GEW freezer freezing refrigerator side not cooling
Check the air damper if it opens as you adjust the temperature control. If yes then check the freezer fan motor. First, disconnect the unit from the power source then remove the freezer shelving.
Loosen the two top screws and remove the two bottom evaporator cover mounting screws then grasp the bottom of the cover then carefully pull it forward and down to clear the upper flange.
Disconnect the evaporator fan motor leads. The wire leads are self-locking and it is important to squeeze the clip before pulling the leads off the terminals.
Remove the evaporator fan motor assembly and place it on a work surface. Connect the motor terminals to a service cord and plug the cord into the 120 VAC power source. If the motor fails to operate, it is defective and must be replaced.
Here's the service manual for further troubleshooting.
Jul 06, 2010 | Refrigerators
I assume if my maytag msd2554dr has water coming out of freezer side I have a clogged drain. I have ice build up on bottom of inside freezer What causes the drain to get clogged in the first place?
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Sep 11, 2009 | Maytag MSD2756G Side by Side Refrigerator
I have a 10 yr old Maytag side-by-side. Came home the other night and the Freezer was at 40F. What is the most likely problem
to start: make sure refrig is turned on and running.
1.do you hear the fan blowing inside the frzr compartment?
2.pull refrig out and listen for compressor running. is compressor running/humming away or are you hearing a humming sound followed by a clicking sound?if you hearing a clicking sound than mostly
is your relay on the compressor that went out. look for a smal device on the side of compressor w/two or three wires. part# 12002794 $32.00
also make sure there's no frost build on frzr rear wall.that's another problem
Jul 15, 2009 | Maytag MSD2758GEW
REFRIGERATOR AND FREEZER UPPER HALF NOT COLD
If you live in a humid area, I'll bet ice buildup is screwing with the air flow. I have a similar, but less intense problem. So in my case, simply unplugging the fridge and letting all the hidden internal ice melt solves it for several months. GE sells a "moisture kit" which I refuse to buy, since it's $340! Plus, I doubt it will fix anything. Good luck!
Apr 15, 2009 | Refrigerators
MSD2756GEB (Side By Side) Runs All the time
I went to the Maytag site and found a similar QA area and found a short article that talked about frost build up and/or blockage of any sort preventing airflow from the freezer compartment to the refrigerator compartment. They said this would impact proper operation of the refrigerator.
I emptied out the freezer after I inspected and found significant frost/ice in the upper right hand corner around the "scoop" that directs airflow into the refrigerator compartment. I took that off and removed all the ice build up (almost 1/2 blockage). I then removed the entire back panel and noticed that my refrigeration unit was completely iced up with significant build up around all the wires and thermostat.
I defrosted the entire unit with the aid of a hairdryer (at a safe distance so not to over heat anything) and then made sure my evaporator coils were all clean in the back and turned the refrigerator back on. (I unplugged it during the defrost operation.) I made sure that the fans worked both above the interior refrigeration unit and at the evaporator unit. Then I waited for the compressor to kick on.
Wallah! Everything so far was working so I put the rear panel back together in the freezer section, closed her up and waited to see what would happen. So far I've had to turn down the refrigerator section to around 5 and the freezer to about 4. The unit now seems to run correctly, shutting off after it runs for a while.
So I guess I'll wait and see how long this defrosting step works. Maybe the self defrost switch or something is not working and the problem will return in a month or so. We'll see..............
Feb 13, 2009 | Maytag MSD2756G Side by Side Refrigerator
Maytag side by side slowly getting warmer
YOU ARE BE GETTING A WEEK COMPRESSOR.
Jun 09, 2008 | Refrigerators
Refer
Most likely the heater is bad. It is located under the evaporator inside the freezer rear wall . Look for a long glass tube about half inch in diameter with a long coil of wire inside. That is the heater . It can be unplugged easily.
Jan 21, 2008 | Maytag PTB2154G Top Freezer Refrigerator
Maytag refrigerator Model MZD2766GEW
Check the evaporator fan motor located abocve teh cooling coils in the freezer side.
Jun 05, 2007 | Maytag MZD2766GES Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
