I have a Mitsubishi WD57 and the remote stop working
I have a Mitsubishi WD57 and the remote control suddenly stop working. I did the reset system and remote and still not working any thoughts?
  • 767 Answers
Point it at your digital camera or camcorder
if you see a bright blush blinking light looking
threw camera its working. then the problem
may be the mode sw on the remote got
changed or the sensor on the set is out
Posted on Jun 26, 2009
Suddenly the tv box mk4 en remote stop working.
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
Try a hard reset or a factory reset too; if the remote control is OK.
There are two methods to reset. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked above.
Jun 04, 2016 | Televison & Video
Why did the remote suddenly stop working?
Try disconnecting power at the source, not a switch. Wait for a minute or so and turn on the power again. This action may "reset" the receiver. You also may find that remote control is restored after a power outage. Finally, if nothing else works, you may have to install a replacement Lutron receiver.
Aug 16, 2015 | Lutron Electronics MIR-ITFS-LF-WH...
I bought a keyin remote and it actually worked but the thing is i accidentally pressed the PRESET button and suddenly all the channels stopped working. what should i do?
I think you succeeded in resetting the remote. However, no harm has been done, either you select SET and see if you can configure it to work with your gadget or better still you go back to where u purchased the remote and lodge your problem so to assit you. good luck.
Apr 17, 2014 | Universal Remote Control Remote Control
Mitsubishi WD-60735 Control issues
This set has aside from the recessed front reset two more done with the Mitsubishi remote.
The soft reset "should" be with set on Menu, 1,2,3, enter
The hard reset requires a 4 digit number code and is based on model number and also done with the Mitsubishi remote--try to see if soft reset works at all on this model.
Mar 31, 2012 | Mitsubishi WD-60735 Projection Television
My WR7 univ. remote control suddenly stopped working for th cable box, but still works on the t.v.
This is because the remote may got resetted which have been programmed with the cable box.
So please reprogramme the remote with the cable box.It will work.
Thanx
Jul 29, 2010 | Universal Remote Control WR7 Remote...
Mitsubishi 65807 won't power on
hello it's possible the glass fuse may blown inside the tv take the back off and check but make sure the power's off
shaun
Oct 12, 2009 | Mitsubishi WS-65807 65" Rear Projection...
Mitsubishi 1080 rear proj. tv
I can help you unlock your Mitsubishi HDTV V-Chip, but you will need an 'original' Mitsubishi remote control for the fix to work.
Please follow these steps to bypass the vchip or reset the V Chip password.
I hope that helps.
_______________________________________________
Reset Mitsubishi HDTV VChip Password
Bypass Mitsubishi HDTV Front Panel Lock
Feb 18, 2009 | Mitsubishi WS-65515 65" TV
My Sharp Remote Control Is Suddenly Stop Working
Ok I just dealt with the Sharp customer support for this problem.
1) You need to unplug the TV for 1 full minute and remove the batteries from your remote aswell (this will reset the system)
2) Hold the power button on the remote for 30 seconds with the batteries still out of the remote and the TV still unplugged
3) After the 30 seconds replace batteries then press every button on the remote beginning with the power button in order from left to right and top to bottom (same way you read)
4) Then plug your tv back in and try the remote again.... and the remote and TV should be back in sync.
Aug 03, 2008 | Televison & Video
Wii Remotes
Could it be an issue with your sensor bar on top of the TV? That could explain why you'd be having the issue with more than one remote all of a sudden.
Jun 29, 2008 | Nintendo Wii Console
Televison & Video Logo
78 people viewed this question
Top Televison & Video Experts
