Recommendations Aircondition is charged does this have a attermizer value that can get pluged and cause presure to rise
    President:
  • 3,433 Answers
Air conditionerhas a Thermostatic expnsion vale and they do plug causing high head pressue from moisture in the system. This problem can also be detected by vaccum on low pressure side. If unit was not evacuated this is highly probable. GLuck
Posted on Jun 26, 2009
My aircondition cuts power from time to time and the pipes won't sweat as well so it does not chill inside
I think you need to get a service tech out to check it out. It sounds like a charge problem or a compressor failing assuming the condenser fan is operating properly.
Mar 10, 2014 | Samsung AS-24UU 24BTU Split Air...
Aircondition not cold but rear aircondition seems cool only.
Check for the refrigerant charge. You may have a leaking system.
Oct 29, 2012 | 1992 Toyota Previa
Won't start-If I take the positive battery terminal loose and the bike stays running does it mean the charging system is working?
Yes but not recommended, as it may spike the regulator and cause it to stop charging.
Better to check battery voltage with a multi meter.
around 12v engine stopped , and will rise when engine is started and revved to 13 or14v
Aug 12, 2011 | Suzuki Boulevard C50T Motorcycles
Why would aircondition condinsation leak on the inside of the truck
There is a tube to exhaust the coninsation to the outside that runs along the trans hump on the passanger side... make sure it is pluged into the hole in the floor (someonme may have kicked it free).
Sep 24, 2010 | Ford F-150 Cars & Trucks
710 d has problem in hydrolics ax like main pump is destroking to soon no power in all hydrolics. did presure test found low presure in charge circuit on test port on main pump .have checked or replaced...
hydraulic pump may be going out, you have to have a good working pump for your hydraulics to work right, there are also some check valves that could be leaking, this will also give you a low pressure reading, low pressure will also effect pto engagement
Oct 24, 2009 | John Deere 420,1020,2010,2020,2510,2520...
1986 sei 1200 goldwing It will start from ignition on,fuel pump runs for a few seconds,fuel light goes out,every thing normal-no LED diagnostic lights.When it starts it will run for about 3-5 seconds &...
check the fuel filter it sounds like it's pluged and causing too much back presure this is causing an over load in the fuel pump causing it to stop working or to presure lock
Aug 03, 2009 | 1986 Honda GL 1200 Aspencade Gold Wing
Tran charge pump presure low. changed pump volvo loader L70C
Stopped up suction screen can cause this. Also pressure regulator.
Jun 16, 2009 | Plumbing
1994 Toyota aircondition probelms
i think check for possible malfuntion of condenser fan
Apr 13, 2009 | 1995 Toyota Camry
Heating & Cooling Logo
37 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
