Question about Panasonic KX-T7630 Corded Phone
I have Panasonic KX-T7633 phones and on one of them when the message button is pushed it dials another employees extension. Any suggestions? Thanks!
  • 749 Answers
Hi, you need to reset the phone to its default settings, scroll in the menue's and try to find it, if not then simply unplug it (take out any battery's if there are any) for 30mins, this should remove any stored numbers in the message button.
Posted on Jun 26, 2009
On the Panasonic KX-T7633, how can you answer a call on extension 101 that is actually ringing/incoming on extension 103?
A couple of ways, the easiest is to dial *41103 on the intercom. *40 may also work, but it picks up any ringing outside line.
Carl
Jul 20, 2011 | Panasonic KX-T7633 Corded Phone
Even once I've listened to and deleted my voice mails, the red light will not go off. Any suggestions?
press the MESSAGE button and look at the display. It can be lit from any other station, and in fact, will be lit if someone dials your extension and presses MESSAGE or dials a "4".
The display tells you where the message came from and one of the soft keys will let you delete it.
Carl
Sep 07, 2010 | Panasonic KX-T7633 Corded Phone
Panasonic KX-T7633 Notification Light will not turn off
The red light is MESSAGE WAITING. It is not necessarily VM notification. Press the MESSAGE button and look at the display. One of the soft keys will let you CLEAR the message and it will tell you where it came from. It's set by anybody calling your phone, and randomly, it is set by dialing your extension plus "4". Oops. It's a Pana mystery :-)
Carl
Jul 07, 2010 | Panasonic KX-T7633 Corded Phone
I have inherited a KX-T7633 and cannot access voice mail. the previous employee left the company. Can you help?
It depends on what you mean by "can't access". The Panasonic voice mail system is accessed by dialing the VM access code, sometimes 500 or 165, from the phone you want to use. If you, for example, are extension 105, and it has a voice mail box, the lady will either tell you how many messages you have, or ask for a password. If that's how you can't access VM because you don't have a password, then the password can be reset from mailbox 999, the system administrator's mailbox.
There are two passwords YOU ABSOLUTELY HAVE TO HAVE. If you don't know the passwords to 998 and 999, then you will have to get them from the original installer, or call your Panasonic dealer. Alternatively, if you have the VM maintenance console password, you can reset 998 and 999's password.
Carl
Jan 27, 2010 | Panasonic KX-T7633 Corded Phone
Cannot get the correct time set on the phone. Panasonic kx-t7633
Try this....
For Panasonic system (especially for KX-T7633), you have to make changes from extension 101.
1. leave handset in the cradle then press "program".
2. Dial *# then "SP-PHONE" button until you see something like time set something something
3. manually input correct date then time then press "auto dial/store" button.
4. pick up the handset then hang up to save.
Aug 24, 2009 | Panasonic KX-T7633 Corded Phone
Changing the names fixed to internal extension numbers
If you can not log into the programing tool to change it that way then you will still need the Installer password. However from the main ext typically the first ext or 101
hit the Program soft key just below the LCD
push * then #
password
004
ext number you wish to change
type in new name
ENTER
END
Apr 14, 2009 | Panasonic KX-T7633 Corded Phone
Remote message retrieval
If you have a Panasonic brand voice mail, you press #6 * and your extension, then the password.
Carl
Dec 20, 2008 | Panasonic KX-T7633 Corded Phone
Re: Question
Your phone can have 3 options, Ring all the time, Switch between Voice and Ring, or Voice all the time.
From your phone(s) press PROG 21 and press the ENTER soft key (3rd key). Now press the SEL (3rd key) until it says VOICE CALL then press ENTER and EXIT. If you set it to this mode, the AUTO ANS button won't work.
If you select TONE, the Auto Answe button will work, making the phone VOICE CALL when lit and ring when not.
If you select VOICE CALL DENY, the AUTO ANS button still won't work and ...you get the pattern.
Carl
Oct 22, 2008 | Panasonic KX-T7633 Corded Phone
Digital panasonic kx-t7633
The 7633 has a FWD/DND button. Is it blinking, lit solid or dark? It's designed to be pressed 3 times for FWD DND or OFF....It's programmed as follows, assuming that 500 is your voice mail access code:
From the intercom dial *7101. That sets DND. Dial 710x 500 # to set call forwarding where x-2 for all calls 3 for BUSY for for NO ANS 5 for BSY/NA. 7&8 are FOLOW ME commands and they have a different set of instructions ie Dial *7107 plus your extension to have calls come to the phone you're at and *7108 plus your extension to cancel it. I have never seen it used. *7100 cancels all forward and DND arrangements from your phone..
This is just hte command set for ALL CALLS. You can also set up forwarding for Outside Calls and Inside calls seperately and you can program buttons to do the forwarding.
Your Panasonic dealer has 2 manuals that you would find interesting, one is the TDA Operating Manual and the PTPM Manual. The operating manual has a complete set of programming instructions for the manager and users of TDA systems, the PTPM has a complete set of programming features that can be performed from a Panasonic 76XX display phone.
THe pdf's aren't huge and they can be sent to your email address if you provide one under the Ask Me button.
Carl
Oct 01, 2008 | Panasonic KX-T7633 Corded Phone
Time and date
Mar 30, 2008 | Panasonic KX-T7633 Corded Phone
Panasonic KX-T7630 Corded Phone Logo
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
