Question about Tomtom One XL GPS Receiver
I have a Tomtom XL and lately its taken forever to find gps signal, i tried everything like resetting it which works for a bit but then has that problem again. Can someone help. thanks in advance
  • 3 Answers
I work as a truck driver on a small fleet of 7 vehicles in the midlands UK
3 of us have Tom Toms, the others have medion, navman or garmin.
ALL the tom tom users have been experiencing GPS problems this week ( june 21 onwards ) whilst the rest of us have seen no change in GPS satelite availability.
In addition, a friend who uses a TOM TOM One XL in another part of the UK has also had same problems.
Its a TOM TOM problem generally it seems, and NOT your particular piece of kit.
Posted on Jun 28, 2009
    Problem Solver:
  • 9 Answers
Hi, have you updated the unit yet? An update will likely solve your problems
Posted on Jun 26, 2009
How to regain my gps signal?
The problem can be fixed by resetting the tomtom one xl gps receiver. Tomtom one xl gps receiver is common with this problem, after resetting it, it is most likely it will happen again. So be ready to keep resetting over time.
It most like is as a result of bad strength to search and detect the satellite. So you have to adjust the antenna also to a area where it can pick signals easily. This is quite uneasy because the areas to locate the satellite varies in terms of the location you are.
Software update will not fix this problem as well as the quickgpsfix, so the bes solution is for you to keep resetting it.
Hope this info helped. Thank you for using fixya.
Jan 21, 2011 | Tomtom One XL GPS Receiver
NO GPS SIGNAL
Dec 22, 2010 | Tomtom One XL GPS Receiver
MY TOMTOM ONE XL 4S00.000 WHEN U PUSH THE BOTTON
hi try to reset go tomtom.com sel support, search reset, select soft reset, sel. device do as told. make sure batt. is full
Feb 14, 2010 | Tomtom One XL GPS Receiver
Tomtom one xl V3 - cannot get a GPS signal i've tried all the 'proposed' solutions i've seen on the internet so far... resetting, upgraded s/w etc... no luck when connected thru my PC, it works fine, i.e....
I had the same problem on with my XL 340.s...it was taking 3-4 minutes to locate satellites. I found a solution and it works:
Delete the contents of the ephem folder on your unit using Explorer. Also delete the subfolders in the ephemeris folder on your computer found here:
C:\Documents and Settings\yourname\My Documents\TomTom\HOME\Downloads\complete\ephemeris
Now, connect to Home and try the update again. I now connect to the satellites in 2-3 seconds.
Sep 01, 2009 | Tomtom One XL GPS Receiver
Can't get a GPS signal for last 24 hrs
I had a similar problem and did solve it with the soft reset (pressing reset button). I have a One XL and there is a small reset button that you push with a paper clip. On the XL 330 you press and hold the on/off button for 15 seconds and the unit should reset.
My symptoms: Would not find a GPS signal. When I looked at the GPS Satellite status (press on the GPS signal strength bars, again on the GPS/battery status) you can see it locking on up to 8 satellites but would still not show a gps signal lock. Normally it only takes 4 satellites to get a gps lock. My other sympton was that when I attached the GPS unit to the computer and operated it with TomTom Home, it worked fine and locked on to the gps signal quickly (even inside my home). But it would never (at least for 30 minute trips) lock on to a gps signal. After doing a reset it began working normally and locked on to a gps signal after finding 4 or more satellite signals.
Aug 06, 2009 | Tomtom XL 330 Car GPS Receiver
Need to up date tomtom xl less then 1 yr old?
download tomtom home from www.tomtom.com install your cradle after the download then your tomtom and with a bit of luck, the update section will automatically select the updates you need. good luck
Aug 04, 2009 | Tomtom XL 330 Car GPS Receiver
No gignal on tomtom one xl
take it to the seller to have it reinstalled
Jul 04, 2009 | Tomtom One XL GPS Receiver
Waiting for valid gps signal
The GPS needs at least 3 satellite signals to operate.You are probably in a bad reception area. Move around a bit and try again until you see a signal array of 3 or more!
Jun 30, 2009 | Tomtom One XL GPS Receiver
Go to TomTom Home on your computer and do a update for your unit. In the update list you should see a GPS quick fix which helps the TomTom's aquire a signal faster. Hope this helps.
May 21, 2009 | Tomtom One XL GPS Receiver
Tomtom One XL GPS Receiver Logo
436 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
