Question about Biostar P4VMA-M Motherboard
Memory upgrade - P4M80-M4
I tried to boost my RAM from (1) 256 DDR 184pin stick, to (2) 1GB DDR's. When I power up, my machine won't boot past the graphic display page. Graphic appears grainy and won't load BIOS or CMOS. Everything runs fine with (1) 1GB stick or (1) 1GB and (1) 256MB stick. But not with (2) 1GB. My manual says I can run up to 2GB, 1GB per DIMM.
Do I have to change settings anywhere in BIOS or clock settings?
  • Revy Nov 06, 2007
    I know the RAM is compatible as each stick works individually and with smaller. They just don't work as a pair. I'm thinking there's a power setting or something of that nature in the bios that could be changed. Anyone ever have this problem before?
Maybe your RAM is not compatible with the motherboard just refer to instruction manual...
Posted on Nov 06, 2007
What kind of memfory do I need for a P4M80-M4 Motherboard? I want to install another card.
Here is the specs of the memory that you can use for this motherboard.
2 x 184-pin DDR SDRAM
Maximum 2GB
Jan 03, 2011 | Biostar P4M80-M4 Motherboard
Just replaced my Biostar P4M80-M4 mother board with a new one and I now have no screen. Power supply on, fans running, appears all is well but no screen?
Try replace the Memory module (DDR2 RAM) with new ones.That's should fix it!!
If still won't come out, replace the power supply unit.
Dec 09, 2009 | Biostar P4M80-M4 Motherboard
Please identify RAM upgrade options for Asus PSCH-L motherboard. Thank you.
From the Asus spec site: Memory Memory Type dtrquestion.gif DDR SDRAM Number of Memory Slots 4 x 184 Pin DIMMs Supported RAM speeds 400 MHz • 333 MHz • 266 MHz Max Supported RAM dtrquestion.gif 4 GB
Memory Memory Type dtrquestion.gif DDR SDRAM Number of Memory Slots 4 x 184 Pin DIMMs Supported RAM speeds 400 MHz • 333 MHz • 266 MHz Max Supported RAM dtrquestion.gif 4 GB DDR SDRAM 400; 333; 266mhz
4 GB max 4x1024 184pin
Hope this helps.
Aug 26, 2009 | ASUS PSCH-L Motherboard
DDR 266 is DDR, not DDR 2 . The 266 is the frequency value in Mhz.
Try having the memory refunded or resell it on Ebay, so that you do not lose your money.
Here is supported memory, many older motherboards do not accept modules of over 512Mb each, ask to the seller:
PC2100 Memory DDR266 DDR-266 184-Pin Upgrade (266MHz) Memory Upgrades
Aug 22, 2009 | Computers & Internet
Can the memory be upgraded (increased) from the basic (factory installed) 512mb on the Sony PCV-W300G?
Hi there.
As far as i know you can upgrade the RAM to 2GB, 2x1GB 184pin PC2100 DDR DIMM Desktop RAM modules is what it can take.
Thanks for choosing FixYa!!
May 28, 2009 | Sony VAIO PCV-W300G PC Desktop
I want Upgrade my computer memory
You need DDR PC 2700 184pin memory. Your machine will support upto 2g.
You can buy this memory from anywhere at cheap prices.
Hope this helps
Oct 16, 2008 | Compaq Presario 5000 PC Desktop
Will not POST with 2g of kingston hyperX ram inside
If you are going to call. The question I would ask (Very important), will the board run with CL2 = 2.5v & or CL3 = 2.6 to 2.65volt memory.
This site is Kingston memory setter. Type in the board & it show's the type of memory the board can use. (Click on this link). As you look at the link this is for you're P4M80-M4 board.
This should help. I did not see a bios upgrade for this board that had anything to do with memory. The USA Biostar link is lacking opposed to the global link. The global manual give far more information (In depth), for bios instructions.
Global link:
I'm sure the Kingston link will more than help you the_OCer.
May 21, 2008 | Biostar P4M80-M4 Motherboard
Computer will not boot with 2 gigs of ram.
yaa viz eagle is right, its really seems like frequency mismatch. The both RAM must of same size, same type, and same frequency.
Mar 24, 2008 | Biostar P4M80-M4 Motherboard
High density memory
need low densisty on ebay 35 buck eash 1 gb ok works on picky mobos way better
Feb 07, 2008 | Dell (E210882) Motherboard
Biostar P4VMA-M Motherboard Logo
211 people viewed this question
Top Biostar Computers & Internet Experts
Jerry Umali
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
