I brought a used A/C pgb030075-1 from Goodman but it doesn't have the instructions to connected and it seems that is missing a connector. Where can I get the diagram, on line, to see the right way to connected
  • 66 Answers
Schematic is usually on the backside of the cover
Posted on Jun 30, 2009
I tried to connect my Canoscan lide 90: when I try to scan: my computer doesn t seem to connect to the scanner: try the cable, connection and turn the scanner on. The connections seem to work... how do I...
Hi ,
The driver is probably missing . You can download and install it from here :http://www.usa.canon.com/cusa/support/consumer/scanners/canoscan_series/canoscan_lide90#DriversAndSoftware
Best regards .
Aug 04, 2014 | Canon CanoScan LiDE 90 Flatbed Scanner
Goodman GDS80703AXBC Flashing 6 times. Replaced Limit, Flame Roll Out, Flame sensor, Ckecked Flue. Furnace used to ignite then shut down flashing 6 times. Used central air over summer just fine. Now...
Per Goodman installation manual:
Misaligned burners, blocked flue, induced draft motor failure. I'd check the inducer first. Up top you'll see a small motor. Near it youll see a small ruber like hose. That hose goes to a round safety called an air proving switch. The end of the hose that connects to the metal, remove it and make sure the metal hole is not stopped up. Make sure the hose is clear and not kinked. Make sure the induced draft motor is working, should be the first action in a series of operation during heat. The air proving switch should close during normal operation, has 2 wires that are connected. Check all wires for loose connections, while the furnace is unplugged and no power present. Make sure everything is put back where it belongs and try it again. Most of these issues are IDM related but I have seen the rollouts open due to burners firing towards the wall of the unit, instead of into the opening of the heat exchanger. Work safe and I hope this helps!
Sep 30, 2017 | Goodman Heating & Cooling
I've just bought a second hand ASUS P4S800MX motherboard and the installation appeared to work just fine but when it booted up, all USB ports and the audio outlets are not working. Am using windows XP....
Here is the link, some of the text is in Danish, but just press the download tab, and all of the useful text is in english.http://www.asus.dk/Motherboards/Intel_Socket_478/P4S800MX/#downloadGlobal
If you already have tried this download, are you sure this isn't the se version of the motherboard?
Regarding the usb and sound; first of all have you installed al the drivers supplied with the motherboard? If you have, then have you connected the internal usb pins to the external ports and tried every usb port including those on the back?
Unfortunately that is what I can suggest at this point... If that doesn't work, and updating the bios doesn't work, then I suggest resetting the motherboard.
Hope this helps
Sep 20, 2011 | ASUS P4S800-MX Motherboard
I just got a ipod 30gb,when i connect it to my laptop it says usb device not recognized but when i connect anotther mp3 it works it also charges on my ps3 somebody help me wtf
If you are using the same usb cable and did try another mp3 player then it works,it seems charging terminal of you ipod doesn't responding,it might be corroded or might some charging pins are missing,broken or not align located at the bottom.
Please Do this basic steps.
* Clean the charging slot with the use of dry toothbrush,gently brush the entire area of the connector so this will contact the both interface. never use wet toothbrush cause might got short circuit.
* Check all pins in the slot if it is complete or intact. if one or two pins are missing or broken, it takes malfunction to system and connection. You can use magnifying lens to be able to see all pins clearly.
* If the charging slot is totally broken,just advising you to bring it to the apple service center near you for the parts replacement.
Hope this simple guide will help you... Thanks for visiting Fixya.
Jul 06, 2011 | Apple iPod MA446LL/A MP3 Player
How do i increase my graphics card performance?
Instruction:
To troubleshoot video issues, follow these steps and test your video after performing each one:
  1. Check the video signal cable connector for bent or missing pins. Check the cable for cuts.
  2. Check to see if moving the monitor connections slightly causes color changes. Tighten loose connections.
  3. In the case of systems with multiple video output connections, verify that the correct connection is being used.Some systems ship with two video connectors on the back, however only one is enabled.
Feb 25, 2011 | Computers & Internet
Blower fan
you could use only 2 wires, R and G terms all you would get is blower fan. so on stat make sure you connect to R and G also. also did it have a fresh air return and you miss hooking up those wires, i have seen that before.
Dec 15, 2008 | Goodman GMS90703BXA Heater
Which 1 to use
If it is a RJ-45 connector yes you can use it, The landline uses a RJ11. If the cale fits in the connector then it is a RJ45 connector and you can use this connection. If it works with your internet connection take the netwotk card you bought back. Hope this helps.
Jan 10, 2008 | Packard Bell 1580509280 Network Adapter
Blank pages printing on ImageClass D680
Greeting IceCreamMan, It sounds like you?ve eliminated the toner cartridge as the culprit. I suspect that when you did the disassembly and connector was missed or an electrical connection fault developed. Look for the electrical contacts that connect to the toner cartridge, they may not be making contact. Make sure the spring contacts on the printer are connecting to the cartridge and that they are clean. If that?s not it then check: -all connectors to make sure they are plugged in and oriented correctly -for missing or incorrectly aligned top or side panels (sometimes they are linked to switches) -all wires (for damage) and secure connections Let us know how it goes and don?t forget to rate the posting.
Jan 04, 2007 | Canon imageCLASS D880 All-In-One Laser...
Heating & Cooling Logo
153 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
