Question about Electronics - Others
Sony VAIO USB2.0, 400GB (Memory Stick) Removable data storage
I've got two flash memory (Sony Vaio 400 GB) and when i put my data on it all data damaged . it put the name of the directory right but the data inside all directories were damaged. i tried several times to remove the directories and retreive the data but didn't permit this step.How can I solve this problem? Also I have another one i put a lot of data on it then the cmputer cant read from this one!! my name is Hoda Computer Accessories, Removable media, Sony VAIO, USB2.0, 400GB Hoda.elshennawy@gmail.com
  • 374 Answers
First of all...R u really sure that u r using a Genuine Sony Flash Drive????? Because if u r...there's no way u will lose ur DATA.Now there r a lot of Chinese stuff in the Market...that's what usually happens when u use chinese cheap stuff.
Posted on Jun 26, 2009
I have a vaio sony 4 GB flash disk when i try to put pics and song and videos in it it works for some min and in the same computer but when i try to put it to another pc after playing the video it says can...
Hello
theres a few things you can do, when you do format your memory stick make sure you format it to the default settings.
Also make sure everytime you put files onto your memory stick that you remove the memory stick safely you can do this by right clicking the memory stick and pressing eject.
However the problem could be that your memory stick is corrupt.
Jul 13, 2011 | Sony Micro Vault Classic 4GB USB 2.0 Flash...
Sony vaio does not read a 2GB memory stick. any solution how to fix? thanks
Depends on how old the Vaio computer is. If the computer is over 5 years old, they won't read anything above 1GB. I have the same problem and the only "possible" sollution is to buy a new, external card reader and see if the solves the problem. I have yet to try this myself.
Feb 09, 2011 | Sony 4GB Memory Stick PRO Duo Memory Card
Data and bad sector Recovery software for 8 GB SAndisk
you can try some data recovery software. You can see
Recover data from memory card
It tells the steps how to perform data recovery.
If above does not work, you may have to format the memory card (use quick format), and then use above mentioned software to scan again the memory card and recover your files.
Jan 27, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
My Sony Vaio Laptop computer doesn't acknowledge when I insert the Sony Memory Stick Pro duo with the correct adapter in the slot. I used to be able to used this on my laptop; what happened? I can still...
regarding with the issue that you are having with your sony vaio card reader here are some things you can do
- try to perform a system restore and try to restore the computer to a date that the computer is working fine
- try to reinstall the driver for the memory stick pro card reader
- the website for the driver is www.esupport.sony.com
- as far as i understand your issue you are using the card reader port for the memory stick pro
Dec 12, 2010 | Sony 2GB Memory Stick PRO Duo Memory Card
My laptop cannot read memory stick pro duo 2gb
same problem here The driver is recognized but not opened
Mar 14, 2010 | Sony 2GB Memory Stick PRO Duo Memory Card
My sony vaoi vgn a217m will not boot from memory stick. Even when i put the "removable drive" as no 1 in the boot sequence in the bios
Hi:
There is a good chance your memory stick isn't bootable. You can go to my computer, select the memory stick, format it, and check the box to make start up disk.
Dec 11, 2009 | Sony VAIO VGN-T350 Notebook
I want to upgrade my ram what type of ram should i use and how what is the maximum amount of ram i can upgrade to?
Memory Upgrade for Sony VAIO PCG-K35 Laptop, the Sony VAIO PCG-K35 Laptop takes the PC2100 DDR SDRAM SODIMMs Memory Type, and comes installed with 512 MB = 256 MB (removable) + 256 MB (removable) of Memory. You can upgrade your Sony VAIO PCG-K35 Laptop to up to a maximum of 1.0 GB Memory, the system has 2 sockets to install Memory, already with 512 MB = 256 MB (removable) + 256 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Regards
Jun 29, 2009 | Sony VAIO PCG-K35 Notebook
I Need Windows XP Drivers for Sony VAIO VGN-NS10L/S Laptop
Good day!!! I know the link for the VGN series for windows XP drivers you can download the drivers there ( http://www.getpcmemory.com/drivers/download-sony-vaio-vgn-series-notebooks-windows-xp-drivers/ ) hope this one can solve your problem.Cheers and God Bless.
Jun 23, 2009 | HP LaserJet P2015 Printer
Electronics - Others Logo
1,244 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
