Question about Canon imageCLASS 2300 All-In-One Laser Printer
IC2300 DISPLAYING "CHECK PRINTER COVER"
NEED HELP RESOLVING THIS PROBLEM, ANY IDEAS?
Resolving error 5C00
If a Pixma go here
PIXMA Printer Error Codes and Error Messages
5C00 - Orange and green blinking 4 times Description:
A service error has occurred.
Resolution:
  1. Turn off the printer.
  2. Disconnect the power cable.
  3. Open the printer cover.
  4. Check for any orange protective tape or white polystyrene and remove if necessary.
  5. Check that there are no foreign objects in the printer (such as a paper clip) and remove if necessary.
  6. Close the cover.
  7. Reconnect and turn on.
If the above solution has not resolved your error, please contact your nearest Canon authorised service facility using the link at the top of the page.
Sep 09, 2014 | Office Equipment & Supplies
How to open front cover for ricoh aficio c820dn printer as it is displaying message " open the front cover to check the paper jam"
Hi there !
You have to open the front cover means that you have to oper the toner compartment and check for the paper jammed inside.
Did it helps your or you find the paper jammed.
Jan 29, 2011 | Ricoh Aficio SP C820DN Laser Printer
I have a Canon MP610 printer and am getting an error message 6A00. I have tried moving the carriage but nothing seems to help. Any suggestions?
2. Open cover
3. Print head and cartridges manually move to the left
4. on the extreme right is a white plastic cover is visible, which is attached to a spring
5. Clean the cover carefully (no chemicals, not wet) and gently push it back (it clicks) and remove any impurities -> the black collecting sponges for the storage of the print head can see
6. Print head and cartridges manually back to the right move
7. Turn on printer
If the above steps does not fix the problem, Click on the link below to check the forum for more details on resolving the issue.
Canon Mp610 Error 6A00
Regards,
Shawn
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Jan 05, 2011 | Canon MP610 Photo All-In-One Printer
Screen is displaying Add toner. I have followed
please try to open the cover while the machine is on and close it back or remove the toner and putt it back sometimes the machine not register the new toner good, so you need to do this two or three times if this not help call a technician
Dec 23, 2009 | Ricoh Aficio 1013 All-In-One Laser Printer
The control panel display is blank on my lexmark x6570 printer
If the LCD on the operator panel constantly displays black bars/boxes or other unusual characters, take the following steps:
1. Disconnect the power supply from the printer.
2. Wait for about one minute, then reconnect the power supply and check the LCD display.
3. If black boxes/bars or unusual characters are still displaying constantly, move the power supply to a different power outlet.
4. If the black boxes/bars or unusual characters are still displaying, the scanner ribbon cable may need to be reseated. Do the following:
1. Lift the scanner flatbed. (Open the printer as if attempting to install cartridges.)
2. Look in the back right corner of the 6150/70 for an access cover.
3. Press firmly on the front right corner of the access cover to reseat the scanner ribbon cable that is located underneath the access panel.
Oct 01, 2009 | Lexmark X6570 InkJet Printer
My printer will not print any documents.
my printer is turning on. Please help me in resolving this.Thanks for your help.
Jun 09, 2009 | Brother MFC 420CN All-In-One InkJet...
Unable to print and copy
pls check the trigger switch of the back cover
Oct 16, 2008 | Brother MFC-7420 Printer
Hardware Error 0502 displaying on the LCD of my Lexmark X5150
The 0502 error can have any of four possible causes:
- A faulty black/photo cartridge
- A faulty color photo cartridge
- A dirty encoder strip
- The encoder strip being out of position
There is a very good walkthrough on resolving these issues:
http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:133:0:0&framed=&docid=ENUS22800&relevance=1
May 26, 2008 | Lexmark X5150 All-In-One InkJet Printer
Canon imageCLASS 2300 All-In-One Laser Printer Logo
116 people viewed this question
old marine
old marine
