Question about Hitachi 43F300 43" Rear Projection Television
Snap, crackle, and pop audio problem
The set has started to make a constant clicking sound. It happens on all channels. Any idea what to check or does it sound like it needs to be serviced?
  • 2,920 Answers
Re: snap, crackle, and pop audio problem - Hitachi 43F300 43" Rear Projection Television Projection Televisions
It needs to be serviced soon
Posted on Nov 05, 2008
0 characters
3 Points
My 50 inch dlp makes a crackling and popping sound, then starts to fade out and eventually makes a loud beeping sound. how do i fix this?
Look to see if this happens at all inputs--tuner and rear first.
This issue is not clear to me---sound is popping or you are hearing a sound from inside the set?
Jun 16, 2012 | Samsung SP50L6HX 50" DLP HDTV
Pt-50lc14 no sound on ch8, has sound on all others
The channel memorised on channel 8 is set to another AUDIO frequency or audio mode. You need to check the setting of the channel 7 to confirm and reset using the manual tuning to reset the audio mode.Since you have not mentioned the place of residence, say for instance PAL system has different audio modes.
Nov 29, 2011 | Panasonic Projection Televisions
Toshiba 42H81 speaker crackle
It could be the board or the speakers itself.
Check see if ur air tv have any crackles?
If not u can rule it out the speakers.
Tries it with diffrent cables,see what happen.
The prob.still there it ur electronic board.
Aug 27, 2009 | Toshiba 42H81 42" Rear Projection...
Picture snaps off, Sound still come through.
A crackling sound could mean that the flyback's insulation has failed and it is arcing inside. If that is the case then it may stop working entirely pretty soon. Take it to a tech as soon as you can, the flyback is a pretty expensive part, however if it blows it can break the set to the point that repairs will not be worth it.
Jun 20, 2009 | Mitsubishi WS-65413 65" Rear Projection...
Popping, snapping sound
Hello fulby2001,
Have the CRTs checked for grid to cathode shorts. The CRTs do this (pop and crack) when they have Grid Cathode shorts. I would advise having a qualified TV technician do this for you.
Thank you,
I hop this helps
Sep 07, 2008 | Philips Magnavox 51MP392H Rear Projection...
Tv making popping sound
Turn down the volume and see if you still hear it,a loud pop or snap could be high voltage call your servicer in your area ASAP
while its under warranty and have him check the high voltage circuits for a intermittenting pop or snap.And have the model # ready!! Good Luck!
Dec 08, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Snap, crackle, pop
no you need a qualified technician! you have defective power supply in oscillation circuit... and i think thats capacitor.
Oct 03, 2007 | Zenith R49W36 49" Rear Projection HDTV
Snap crackle pop
Check the Flyback, had same problem, replaced it and the unit worked good.
Oct 15, 2006 | RCA P46921 46" Rear Projection Television
Sound Problems
this set has a int/ext switch on back..and audio ic inside
Sep 11, 2006 | RCA D52W20 52" Rear Projection HDTV-Ready...
Hitachi 43F300 43" Rear Projection Television Logo
54 people viewed this question
Top Hitachi Projection Televisions Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Projection Television Expert? Answer questions, earn points and help others
