Question about Microwave Ovens
Matag under oven microwave
We removed a GE under counter microwave and we are trying to replace it with a matag which is the same size. There is ia frame behind the microwave but the matag will not fit, what should we do ?
  • Microwave Ovens Master
  • 9,098 Answers
You'll have to remove and/or modify the frame & existing mounting plate as required, which may require some amount of cutting and drilling too.
The dimensions of the mount that the new one needs will be detailed in your installation instructions.
If for some reason you don't have yours, you can download Maytag (made for Whirlpool by L.G.) owner's manuals and installation instructions here.
Posted on Jun 28, 2009
Need to replace both might lights under microwave.
Remove the screw from the lens cover and open lens. Turn light bulb counter clockwise and remove. Repeat this on other side. The bulbs or 40W appliance bulbs. Take the old one with you to hardware store to match it up. Reverse your steps to put new ones in.
Jun 18, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
It is behaving as if there is no power to the plug. There ias power i checked it.
If the microwave control panel doesn't light up, then your fuse is blown. unplug the microwave. unscrew the vent grill, (2) screws at the top of the microwave. then you should see 1 screw holding the control panel. after removing that screw, gently push up then out. there should be a metal plate on top of the control panel. remove that plate and the fuse will be in that opening. remove the fuse and check for continuity across the fuse. Replace fuse and microwave should start working again
Feb 10, 2011 | GE JE1860 Microwave Oven
What type of replacement quartz bulbs for the under counter lights?
could be 10watt or 20 watt i for under counter lighting. If too high could burn out low voltage transformer assuming its low voltage....12 volt...
Apr 08, 2010 | GE JVM2070 Microwave Oven
Turntable not working & keys "stick"
8 years old, huh? In my experience, once faulty, may keep on doing so even after fix. So if it were me & I could afford it, I would get a new one with a warranty.
Feb 26, 2010 | Microwave Ovens
Matag Dryer sounds like it has a tennis shoe in it.
Bad rollers or blower wheel is worn out.
Nov 15, 2009 | Microwave Ovens
My Matag Microwave needs a turntable shaft
Fixya does not sell replacement turntable shafts and knows of no sources.
Aug 11, 2017 | Microwave Ovens
Need a slim over the range microwave
matag can sell you one call them and give them your size....
Jul 25, 2009 | Sharp R-1480 Microwave Oven
GE Spacemaker JVM1631BB005 making noise
Many thanks to e3enigma above! I removed the synch motor under the turntable; all other microwave functions work fine and the grinding noise is gone, hooray! A trip to the appliance parts store tomorrow for a replacement synchronous motor and all should be well. Thanks again!
Jan 06, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Matag Microwave MMV5100AAB
There is a short either in the keypad or the power board.  Unfortunately parts for this one are not available anymore.  If you could get the parts it would cost you well over $100 and would be a better idea to replace the microwave.  If this only happens when you add time then I would just use the microwave without using that option.  Would appreciate a solved rating for expert advice.
Oct 26, 2007 | Maytag MMV5207A Microwave Oven
Microwave Ovens Logo
56 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
