Question about Lello Ariete 45900
Lelloe Ariete 1375 Filter assembly needed
Where can I acquire a part?
Email: Lelloappliances@aol.com        Ask for an order form, or tell them what you need. Parts are available. When I sent in my warranty form they sent me a parts order form.
Lello Appliances Corporation 355 Murray Hill PKWY #202 East Rutherford, NJ 07073 201-939-2555
Hope this helps.
Posted on Aug 03, 2009
  • 4 Answers
lelloappliances@aol.com will send you a PDF ordering form
Posted on Jul 22, 2009
I have an Ariete Retro Coffee machine that is not filtering out the coffee grains properly when making a cup of coffee...
I notice that the filter get obcluse very easily, try to clean it in hot flush water and in the meantime use your hand palm with a push-and-pull movement over the edge of the filter, doing so you will see a spray of water coming out from the central little hole situated on the bottom of the filter, is the problem persist put ONLY THE FILTER, and not the handle into the dish washer, then it supposed to work. In certain case it is possible than the problem remain, try as a last chance to put some salt into the filter and thight the handle into the coffee machine, warm up and start the pump(do not put coffee, only salt) it works!
Feb 04, 2014 | Ariete Cafe Retro Espresso Machine
I have A ARIETE MODEL 305, What's the easest way to change the head seal
there is either a screw in the middle which needs to come out first then porta filter screen and then pop seal out.
or just to get in there with a small flat screwdriver and gently pry it loose if it doesnt have a screw holding it.
Jan 09, 2013 | Ariete Cafe Retro Espresso Machine
How to install 2gb ram in acer aspire one D270-1375
Turn off power and remove battery pack and make sure it is not plugged in. Remove screws from back panel exposing RAM ports. There will be two spring clips that can pushed out to release the ram modules. Remove the old RAM modules and insert the new Ram modules in reverse order and assemble netbook. Power Up and enjoy.
Oct 19, 2012 | Acer Aspire One D270-1375 Atom N2600 1
Manual Lello 1375
We received this solution from one of our users.
"This espresso machine is also made by Sunbeam and called Café Crema™ EM4800C.
Here is the link for the manual
http://www.sunbeam.com.au/Pages/Browse/ProductDetail.aspx?pid=1129
You are welcome"
Dec 30, 2008 | Lello Ariete 45900
Lello 1375
The tube which feeds the siphon pump cand be swithced to port two . when you remove hose it can be force feed with a turkey baster filled with water. once its primed the first time it should be fine. also if its exposed to cold weather when shipped or in starage it need to be broght to room temperature before priming .
Oct 07, 2008 | Lello Ariete 45900
Lello Ariete 45900 Logo
713 people viewed this question
Top Lello Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Lello Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
