Question about Acer Aspire One PC Notebook
Battery won't charge?
My Acer Aspire is less than one year from purchase (March 2009) but battery does not seem to charge. I left it plugged in overnight. Battery light continuously blinked while plugged in, but did not charge. Could the battery be ''dead'' this quickly????
  • maryl_aldric Jun 26, 2009
    Thanks so much!
    Maryl
  • 1,684 Answers
A blinking battery light usually means the battery will not take a charge from the system. When this happens the most likely cause is a shorted cell in the battery. Since it is under Acer warranty contact tech support and they will send you a replacement battery. Batteries normally last 2-3 years but you could have a factory defect in yours that just showed up after a little bit of use.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of PC and printer support/repair
Posted on Jun 26, 2009
Replaced the power board on acer aspire battery will charge to 28% overnight but charge nlight doesnt lightup
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Aug 22, 2012 | Acer Aspire 4720 Notebook
Battery not charging, how to I reset it?
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Apr 25, 2012 | Acer Aspire 5741-6073 Intel I5 2.27ghz...
Not charging Acer Aspire 5732z, now won't turn on!
If it does not work with the Charger while the battery is out then I would say either your charger is bad, the dc power jack where the charger plugs into the laptop is bad or you've got motherboard issues. Does the charger have a light on it to indicate that it is on when plugged in the wall? Do you see any lights when you plug the charger into the laptop?
Take an ink pen and see if the little pin inside the computer where the charger plugs is loose and moves a bit. If so that is probably your problem. If the pin is tight and the charger works, then you've got motherboard issues.
Mar 29, 2012 | Acer Aspire Computers & Internet
Acer aspire battery critically low but not using battery, it shuts off anyhow
Mar 04, 2012 | Acer Aspire 3610 Notebook
ACER ASPIRE ONE D255E POWER CORD WON'T CHARGE BATTERY PLUGGED IN THE POWER CORD WON'T CHARGE THE BATTERY ALL THE TIME ...
Hi: Acer chargers have a very short life time, in the past 2 years I had bought 2. Just buy a new one from amazon they're very inexpensive. Here's the link: http://www.amazon.com/Laptop-Adapter-Aspire-AOA110-AOA150/dp/B0028LK6IU/ref=pd_bxgy_e_text_b
Regards,
Sep 25, 2011 | Acer Computers & Internet
I have acer aspire 4741z, when I plug the battery charger, it says plugged in, not charging (6% available). how can I fix this problem? thanks a lot
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jul 07, 2011 | Acer Aspire 4730-4947 Notebook
Aspire one netbook 3 cell battery 8 months old only will charge to 80%
Contact Acer and they will replace it free providing you can produce a proof of purchase less than one year old. Those netbooks have one year parts and labour warranty on them and Acer is very good about replacements like this.It shouldn't be a problem.
Hope this helps!
Regards,
Joe
Jan 17, 2011 | Acer Aspire One Netbook 8.9" Notebook
Acer aspire notebook 5810tz. battery charging light stays on blue. battery will not charge has less than 20% computer will shut down when power cord is detached
Sorry to say but it sounds as if your battery is nearing the end of it's life. How long have you had this problem for? and how long have you had your laptop? Battery's let alone computer's don't have much more than a 5 year life span, that is if there maintained properly. My HP Pavilion is starting to slow after having it to 2 years, and battery life seems to have shorten by 30min. Well I hope this isn't the case as battery's are quite costy. But if this helps in any way, best of luck!
Nov 27, 2010 | Acer Aspire 4530-5889 Notebook PC
I purchased an acer aspire one with qvc last year in dec the
Hello, Adonis.
Depending on its use, a battery lasting 2.5 hours after one year is not terrible. Over time, the battery loses power.
If the battery were totally dead in less that one year, I'd suggest contacting Acer, since it's still under warranty.
Hope this helps.
Oct 17, 2009 | Acer Computers & Internet
Acer Aspire battery shutting off with no warning.
Karen,
I am not familiar with this particular model but deal daily with this same issue on the Lenovo Thinkpads...it is the battery. They can just go bad. Had one yesterday that was fine the day before, now won't hold a charge. It was also less than two years old. They seem to have a shelf life. I would check with ACER to make sure they agree, then order a new battery.
To extend battery life, you need to use the battery up on a regular basis, then recharge all the way. Leaving it plugged in all the time with the battery in shortens battery life.
Jul 31, 2009 | Acer Aspire 5920 AS5920 Notebook
Acer Aspire One  PC Notebook Logo
241 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
