Question about Homelite Mighty Lite Lawn Trimmer
Mighty lite 26ss starts fine, but needs half choke for a long time. Runs for 10-15 mins. and seems to starve out. Acts like an air leak at carb or downstream. Any ideas?
  • 1 more comment
  • leejam Jun 28, 2009
    Gas cap is OK. I have the carb off and ready to clean. I'm going to replace all hoses & the fuel filter. Do you know where I can get the tool to adjust mixture screws? Or how to make one?
    Thanks
    On this model the carb casting completely shrouds the H & L adjustment screws, only open from the top. The screws are round and smooth except for a single spline indent. Looks like they don't want the local rif-raf messin' with it.
  • leejam Jun 30, 2009
    I replaced fuel lines and filter, and cleaned carb. Same results. I made a tool to turn the H&L adjustment screws, measured the turns to stop, then removed them and shot carb cleaner into the seats. Returned the screws to the original settings, started the engine, and tuned the H &L settings. Runs great now. thanks
  • 4 Answers
I fixed one of these with the same problem yesterday. Theonly thing I've found wrong with this little saw is the carbs are terriblyadjusted from the factory and the mixture screws have a 'proprietary' head.they're a flat-topped cylinder with a notch in the side.
fortunately, there is a way to turn them. The insulation on a blue solderlesselectrical terminal will grip the outside of the mixture screws enough to movethem. you use the big end of the insulation you stick the wire into. doesn'tmatter what kind of terminal it is. splices work the best because theinsulation is long enough that you can grab on to it, but I just pulled theinsulation off a spade terminal and used pliers to turn it, as I didn't haveany splices.
I pulled both mixture screws out and cut a slot across the top with a smallfile so I can turn them with a flat head screwdriver. if you do this, only pullout one at a time, they need to go back in the respective seat they came fromor they won't seat properly.
I also took a file and cut an access notch in the air cleaner housing so Icould adjust the high mix while the trimmer was running. takes 10 seconds witha coarse round file, but a chainsaw file takes forever.
To set your mixtures, screw both mixture screws all the way in until theylightly seat. DON'T tighten them way down, just lightly seated.
now, look at where the notch is pointed and turn them out 1 1/4 turns. turningthem out (counterclockwise) makes the mixture richer. turning them in(clockwise) makes the mixture leaner.
now, screw the idle in a full turn so it idles very high (you'll turn this backout later, but this takes some of the frustration out of tuning the carb). You maywant to take the string head off, as it will 'run' at idle now.prime the trimmer (10 pushes if you haven't tried to startit earlier, 2-3 if you did. you can't over-prime, though, you're just removingair bubbles from the fuel pump)
put it on full choke, grab the throttle with your left hand and pull the recoiluntil it tries to start. if this takes 10+ pulls, turn the low speed jetout(richer, counterclockwise) 1/16 to 1/8 turn. you want to work in smallincrements, or you'll waste a bunch of time overshooting where you want to be.
once you get it to bump over full choke, back the choke off a bit. if you'requick you can usually do this while thetrimmer is trying to run fully choked. most likely you're still going to belean on the high mixture, so having the throttle pulled may kill the saw. if itseems like it's dying when the throttle is pulled, but not at idle, then you needto turn out the high speed mixture screw.Concentrate on getting the low speed jet set so it will idlewith the choke off and the throttle off first. Once you get it so it will idle unattended, you can startbacking the idle speed down. From there, you can adjust the low speed jet whilethe saw is idling. Start by turning it leaner in small 1/16 turn incrementsuntil the speed picks up. If this kills the saw before the idle picks up, youhad it a bit too lean to start. if you get the idle to pick up, richen up themixture 1/16 turn. You want to be just richer than where the speed picks up. Ifthe saw died before it picked up, richen it up 1/2 a turn and start it again. Leanit out as before until the speed picks up, then richen it up a bit. This may sound time consuming, but you can stick ascrewdriver on the idle screw and gently turn it in continuously, so itactually goes pretty quickly once you get the saw to idle.Now that you have it idling nicely, you can adjust the highspeed jet. Start by 'blipping' the throttle. If the trimmer bogs down, richenthe high mixture. Now, if you're WAY rich, it will behave similarly, but with thistrimmer, that's pretty unlikely if you're starting at 1 1/4 turns. One way youcan tell if you're way lean or way rich is with the choke. If it will run fullthrottle with the choke part way on or if it picks up faster with the choke partway on, you know it's too lean. The choke richens the mixture up to compensatefor the gas condensating in the throttle bore when the saw is cold. If thechoke kills it, you're too rich.if it will run, then you can adjust the high speed similarlyto the idle. A leaner mixture will have more power and spin a higher RPM to apoint, but it will also run MUCH hotter and an excessively lean mixture willseize the piston. So, you're going to want to err on the rich side. You'lldefinitely be able to hear the rpm change, a way rich mixture will be almost 1/2the speed of the proper mixture, and a too lean mixture will sound like thetrimmer is going to fly apart at the seams. Once you get the high mixture to the point that you can grabthe throttle and the saw will pick up to max speed in less than a second, thenyou're ready to cut something. You may need to adjust the mixture leaner for abit more power if it bogs down in normal grass trimming, or if it is running througheverything including big weeds without changing speed, you should probablyrichen it up. This is NOT a big trimmer, it SHOULD bog down a bit if you loadit up.A final note about this trimmer, I never could get it to acceleratesmoothly from idle to high speed. It lags for about 1/4 second just above idlethen it picks up as it should. It runs fine once it gets past that hesitation,you can vary the throttle to be delicate around things, ect, but if you let itidle, it does hesitate when you pull the throttle again.I was pretty surprised how well it ran once I tuned itthough, this one is my boss's and he's got a 3-blade cutting head on it that'sa lot heavier than the string head and it will spin it just fine. It will cutdown saplings to maybe 5/8".Good luck!
Posted on May 15, 2012
  • 1,041 Answers
The gas cap may be clogged.
The next time you run the trimmer and it starts to die, loosen the gas cap. If it starts running again, then you know that it's a clogged gas cap.
You may also check the air breather, it may be dirty as well.
If you need further assistance, just let me know.
Jim
Posted on Jun 28, 2009
  • 1 more comment
  • Jim Parker
    Jim Parker Jun 28, 2009
    No, you can't adjust them with your fingers?
    Here is a tip on carb. cleaning.
    You will need to disassemble the carburetor and spray with carb.cleaner.
    Make sure the small screen is free of debris. (Should be able to see
    daylight through it.)
    Use a Den Tek Brush, (http://www.drugstore.com/products/prod.a...),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
    Jim
  • Jim Parker
    Thanks for the rating.
    If you should have any questions about
    "Drywall Finishing/Patching", or know someone who does, put your
    questions to Category:"Tools- Building & Power- HAND TOOLS" at
    FixYa.com
    Thanks Again,
    Jim
  • Jim Parker
    I hear that, isn't it the truth. If you haven't moved them, then you should be o.k.
    Just do the carb. cleaning that I had mentioned before. That should solve the problem.
    Jim
I need to know where the fuel filter and air filter is on Mighty lite 26ss Model # 21546
Your fuel filter is INSIDE the fuel tank at the end of the fuel line that flows gas to the carburetor. The air filter is behind a snap on plastic cover over the side of the carburetor. There may be a plastic lever there which is the "choke" lever which is to be used when the engine is cold to aid in starting.
May 12, 2011 | Homelite Mighty Lite Lawn Trimmer
Hard to start my homelite mighty lite, any clues please
Remove the air filter. Get some carburetor/choke aerosol spray at the auto parts store. Open the throttle wide open on the machine while spraying cleaner into the carb throat. A couple short bursts is all you need. Then try to start . If the engine runs till the cleaner burn off, that is a start. Do this a few more times and then try to start the machine normally. If it doesn't start, then it probably needs some type of fuel system maintenance done (filter, gas lines, carb gaskets and diaphragms, carb cleaning etc.).
Jan 18, 2011 | Homelite Mighty Lite Lawn Trimmer
My home lite start when on half choke but shuts off in a few seconds to a min. or if i put it on run it immediately stalls
Your trimmer is starving for fuel. If it is less than 18 months old, my guess is that it just needs a carburetor adjustment. If it is older than 18 months, it should have the carb cleaned and rebuilt, or replaced. Check with homelite.com for the cost of a replacement carb, sometimes they are less expensive than having the old one repaired. If it just needs an adjustment, find a local repair to do it for you. Homelite requires a special tool to adjust the carb, and won't sell the tool directly to consumers. Some shops will sell the adjustment tool. No special tools are required to replace the carb, just basic tools.
Sep 09, 2010 | Homelite Mighty Lite Lawn Trimmer
Homelite mighty lite wont stay running
the problem is in the carburetor most likely, it may be cleaned and adjusted, if not it will likely need a new carb
May 31, 2010 | Homelite Mighty Lite Lawn Trimmer
It won't run prorerly
I had the same problem. I took it to the dumpster and used my old echo that I purchased in 1986. The Homelite was 2 years old. My sugesstion is to dump it.
Apr 06, 2010 | Homelite Mighty Lite Lawn Trimmer
1985 dodge ramcharger, carburetor issues
Sounds like a problem I had with my '85 Dodge D150 Ram Prospector. In my case, the automatic choke was broken and it was starved for air during acceleration because the choke was always closed. It ran fine at idle or very slow acceleration. I wired the choke open and it runs much better, although it is much more difficult to start as the fuel mix is lean due to the extra air. Once it gets warmed up, though, it runs fine. I hear that the barrel carb on mine often has problems.
Jan 29, 2010 | 1985 Dodge Ramcharger
Trimmer won't stay running
Most likely needs the carb rebuilt.
First check the prime bulb and fuel lines for cracks. Check the spark arrestor for carbon buildup.
Another problem could be a stuck piston ring, but try rebuilding the carb first as it is usually the source of the problem.
Aug 02, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite gas trimmer will not run without half choke and throttle
You need to disassemble the carb. and spray with carb. cleaner. If you need tips on how to do this, just let me know. You may need a new carb. kit as well, but we won't know that until you first perform the first step, or if the carb. parts are more than 3 years old. If they are, then go ahead and buy the carb. kit and replace the parts.
Jim
Jun 01, 2009 | Homelite Mighty Lite Lawn Trimmer
Engine run @ half choke but will not run in run position
It's starving for fuel. What is it? Sounds like the jets are plugged in the carb. or possibly water in the gas. Remove carb., disassemble, clean and put back together. You should get a rebuild kit for it first so you have new gaskets, etc. when you reassemble. It's a little more complex than I can put in words for you here.
Also empty and clean fuel tank too and start with fresh, clean fuel.
Mar 11, 2009 | Homelite Mighty Lite Lawn Trimmer
Engine dies when excelerating - more gas
check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. if that doesn't work have the carb repaired at a service center or replaced.
Nov 17, 2008 | Homelite Mighty Lite Lawn Trimmer
Homelite Mighty Lite Lawn Trimmer  Logo
1,571 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
