Question about HP LaserJet 4L Printer
Paper won't pick up, printer makes grinding noise
  • HP Master
  • 1,684 Answers
The problem you are discribing is caused by a broken gear on the drive motor. The small gear cracks after years of printing and will jam the pickup assembly, the sound you hear is the motor trying to force the gear assembly to turn. We have a repair kit with the gear and instructions available for $12.95 including shipping if you want to do the repair yourself. The job should take about 30-45 minutes even if you are not a printer tech. I hope this helps.
Buddy@ccl-la.com
Corporate Computer
www.ccl-la.com
Over 21 years of PC and printer support/repair.
Posted on Jun 26, 2009
Copier will not copy feed paper oeven try-justs makes agrinding noise
Dear
Pl. do test as per following.
1- empty paper tray.
2- pull the toner cart. and close the door.
3- power ON the printer. Listen the sound of initial motor run,
(If smooth not grinding noise, check the toner cart OPC drum for jam. If yes check the fusser drive gear and fusser gear and assembly)
If all are ok.
4- Check the paper pick up roller shaft, (sometimes it takes a bunch of paper and jammed if you forcible pull the bunch in reverse direction the shaft may gets bend cause the grinding noise during paper pickup. in that case you have to replace the paper pickup shaft.
Thanks.
Mar 10, 2015 | Samsung SCX 4521F All-In-One Laser Printer
Hp officejet pro l7780 all in one printer, Cleaned the pick up roller still not picking up paper
The pick up roller may be worn and in need of replacement. The slight grinding noise is the pickup roller trying to work but slipping
Oct 30, 2012 | HP Office Equipment & Supplies
Will not grab paper. says out of paper when its not
You can try cleaning the rubber wheels with alcohol. Sometimes they become covered in dust and won't grab the paper.
Apr 08, 2012 | HP OfficeJet 7410 All-In-One InkJet...
Paper is not being picked up and fed through.
Make sure you inserting the paper not deep inside just insert and stop it when you feel any resistance .and try to print something. If it is print then well otherwise you have to show it service center.
Nov 20, 2009 | Canon PIXMA MP510 All-In-One InkJet...
HP Laserjet 1320 Series Printer-Grinding Noise Won't Pickup Paper
take the roller out again but this time make sure the paper sensor is in the proper place. it does go scew when putting a new roller in. It happened to me last month.
you dont need to get another printer.
Oct 09, 2009 | HP LaserJet 1320 Printer
Paper jam
Call HP and replace unit under warranty.
Jun 20, 2009 | HP Officejet Pro L7680 All-In-One Printer
My HP Laserjet 2430dn makes a grinding noise after power on.
CHECK RS PRINTER PARTS FOR HP LASERJET 2400 2420 2430 PRINTER GEAR KIT
Feb 26, 2009 | HP Office Equipment & Supplies
Paper transport does not work; terrible grinding noise
I took mine apart from the back and put it back together and it worked. It is probably due to moving it and the bottom paper tray alignment gets out of whack. I inspected all of the gear train and didn't find any worn or missing teeth. I suspect a paper jam started it and the user turned the printer around to open the back door. Since the handles are on the printer the tray doesn't move with it which allows it to separate and possibly jam a pickup drive gear.
Nov 08, 2007 | Dell 3000cn Color Laser Printer
HP LaserJet 4L Printer Logo
227 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
