Question about Troy-Bilt® Briggs and Stratton Chipper
Describe your Troy Troy-Bilt® Briggs and Stratton Chipper Problem how to take impeller assemply off troy-bilt chipper model cs4210
I Have a MTB chipper shredder, model 24A-464B062 (sometime between 2000 and 2002), which appears to be a Lowes model. In my case, I left the shredded blade on and backed off the main bolt holding on the impeller so that about 1/4 of an inch of threads were showing. I then attached my harbor freight automotive pulley puller (Pittsburgh - item#66868), with its shaft pushing on the head of the main bolt and its arms hooked onto the shredder blade. I then torqued the puller hard until the shredder blade was bending pretty good. The impeller did not come off. I then used a cold chisel and a hammer to pound around the center cylinder of the impeller (there are two small spots where this can be reached). Still the impeller did not come off. I then used my plumbing torch (with MAPP gas), to heat up the center of the impeller, for about 5 minutes. Still the impeller did not come off. So I returned to the cold chisel and hammer, and after a few hits, the impeller popped loose. I removed the automotive pulley puller (be careful, it is hot), and then the main bolt, and the impeller came right off. After inspection, I noticed that there is no key and that the impeller is attached by a press fit taper. So it looks like what I did is most likely what everybody else would have to do for my model.
Posted on Jul 21, 2012
  • 181 Answers
There should be a set screw in the impeller holding it on the shaft.take the set screw out.then the impeller should come off.if it doesn't come off easily you need to heat the hub that the set screw was in.this expands the metal so that the impeller will come off..........there is no easy way to do this job........hope this helps,let me know..................
Posted on Jun 26, 2009
How to remove tire on Troy Bilt chipper shredder
there is either a clip or a cotter pin that needs removed , then slide the wheel off .
Nov 19, 2013 | Troy-Bilt® Briggs and Stratton Chipper
Where can I get an owner's manual for a Troy Bilt Super Tomahawk chipper
Here: http://www.brentchalmers.com/
Keep all of those fingers out of the shredder!
Hope this helps, if so pls leave feedback, if not let me know!
Jan 25, 2010 | Troy-Bilt® Briggs and Stratton Chipper
I need parts for chipper vac
parts are NLA Murray has gone bankrupt, assumed by Briggs & Stratton. Many Murray parts are NLA
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Nov 07, 2009 | Troy-Bilt® Briggs and Stratton Chipper
Misplaced operation manual for Troy-Bilt Briggs & Stratton Super Tomahawk Chipper/Shredder 8 HP Can it be downloaded? What kind of oil does the chipper use?
Straight 30w NOT 10w-30
prefer air-cooled engine oil from mower dealers or some auto supply stores have air cooled engine oil.
Oct 07, 2009 | Troy-Bilt® Briggs and Stratton Chipper
I need owner's manual for troy bilt chipper/vac model # 47291
you can try a MTD ride on mower dealer or steelfort Engenering web site or mtd web site.
Sep 05, 2009 | Troy-Bilt® Briggs and Stratton Chipper
Need set of 4 impeller vanes for Troybilt chipper model 47261
You can get the impeller parts at:
http://www.thefind.com/garden/browse-troy-bilt-chipper-vac-parts
Good luck,.,
I just purchased a used 47261 yesterday for $200 .. It is like new, but I may need a new bag from this site and I will need to find a manual somewhere.
MrBill
May 28, 2009 | Troy-Bilt Chipper Shredder
Troy-Bilt Chipper Shredder won't start
It takes good gas, good spark, and good air for a gasoline engine to run well. The next thing I would do is put a new air filter in it.
Apr 23, 2009 | Troy-Bilt® Briggs and Stratton Chipper
No where to go
Try ebay...I have found a lot of parts for my troy bilt chipper shredder on there. Sometimes you can also find a local dealer who might have parts laying around also.
Apr 20, 2009 | Troy-Bilt® Briggs and Stratton Chipper
Troy-Bilt® Briggs and Stratton Chipper  Logo
447 people viewed this question
Top Troy Heavy Machinery Experts
Matt Olenzek
Matt Olenzek
donald boissonneault
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Troy Heavy Machinery Expert? Answer questions, earn points and help others
