Question about Konica Minolta Office Equipment & Supplies
C0070 still appears
After removing toner, turning mahcine off/on and runing thru a few test papges without toner cartridge in place, replaced toner cartridge and closed copier door - Copier makes a ''clicking/grinding noise for about 5 seconds then error c0070 re-appears on panel.
  • 32 Answers
The toner housing sounds like its been turned by hand when the toner has been replaced, it is possible that the drive gears in the unit have been stripped(worst) or could be that the rotation locking mechanism has been dislodged and just needs repositioning
Posted on Jun 26, 2009
What causes error code c0070 on konica 7118
Remove the toner bottle. power off the machine, leave the bottle out turn on the machine let it goes thru normal op, when asking for toner install properly
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jun 12, 2014 | Konica Minolta Copier Tnr,...
Tip
Konica Minolta Copier service code C0070 C-0070
This service code C0070 is a universal code used by Konica Minolta to indicate a toner bottle rotation failure. These machines add toner by rotating the toner bottle that you install in the machine. Most of the time this code is caused by a toner cartridge that has been installed incorrectly or has become dislodged from it's holder. To clear the code open the front door or toner door and remove the toner cartridge/bottle from the machine. Close the toner door and if needed open then close the front door to reset the code. Let the machine run. This may take several minutes and will allow the machine to bring the toner bottle receptacle into it's home position. Once the machine stops running completely, then you can re-install the toner cartridge. If the code does not come back you are ready to go. If the code came back after removing the toner but before you re-installed it then you have either a dirty rotation sensor or a bad toner drive motor and will need service.
If the code comes back after the cartridge is re-installed then there is either a priblem with the cartridge or with the toner bottle drive.
Most of the time though the problem will be resolved by the outlined procedure.
on Jan 04, 2010 | Office Equipment & Supplies
Minolta Di250 copier malfunction C0070; please help me my boss wont buy a new and i need it to make my application; please help me
Re: Error Code c0070
If the machine is throwing the C0070 code without the bottle being inserted than likely the worm gear of the little drive motor of the toner bottle holder is damaged.
If C0070 is only coming up with the bottle inserted, than the bottle may be wrong or damaged from previous attempts.
To reach the toner bottle holder ("hopper") mechanism you have to remove the rear cover.
Apr 02, 2014 | Minolta Office Equipment & Supplies
Toner exhausted and replace toner how can solve this error without replace new cartridge
When the toner cartridge is exhausted or empty then the printerwill not be able to print further documents or the prints will be very faint. You may be able to print a few more pages by removing thetoner cartridge and shaking the toner cartridge in a horizontal position a fewtimes and then placing it back into the printer. This will give you an opportunity to print a few more pages and giveyou time to purchase a new toner cartridge for your printer. A cheaperalternative is to purchase a re-manufactured toner cartridge for your modelprinter. A re-manufactured printer cartridge also replaces worn partsas well as refilling with toner powder.
Jul 15, 2011 | Samsung SCX-4300 Monochrome Laser...
C0070 machine trouble
Good Luck and Thank You for using Fixya.
Jan 08, 2011 | Minolta EP4000/5000 CS/PRO Copier
It doesnt print the first page and its a minolta cspro 3000 and the error code is c0070
This service code C0070 is a universal code used by Konica Minolta to indicate a toner bottle rotation failure. These machines add toner by rotating the toner bottle that you install in the machine. Most of the time this code is caused by a toner cartridge that has been installed incorrectly or has become dislodged from it's holder. To clear the code open the front door or toner door and remove the toner cartridge/bottle from the machine. Close the toner door and turn the machine off then on to reset the code. Let the machine run. This may take several minutes and will allow the machine to bring the toner bottle receptacle into it's home position. Once the machine stops running completely, then you can re-install the toner cartridge. If the code does not come back you are ready to go. If the code came back after removing the toner but before you re-installed it then you have either a dirty rotation sensor or a bad toner drive motor and will need service.
Sep 29, 2010 | Minolta Office Equipment & Supplies
Minolta di250 error code c0070 this error code
This service code C0070 is a universal code used by Konica Minolta to indicate a toner bottle rotation failure. These machines add toner by rotating the toner bottle that you install in the machine. Most of the time this code is caused by a toner cartridge that has been installed incorrectly or has become dislodged from it's holder. To clear the code open the toner door and remove the toner cartridge/bottle from the machine. Close the toner door and turn the machine off then on to reset the code. Let the machine run. This may take several minutes and will allow the machine to bring the toner bottle receptacle into it's home position. Once the machine stops running completely, then you can re-install the toner cartridge. If the code does not come back you are ready to go. If the code came back after removing the toner but before you re-installed it then you have either a dirty rotation sensor or a bad toner drive motor and will need service.
Sep 28, 2010 | Minolta DiALTA Di250 All-In-One Laser...
How to fix problem code 0070
C0070 indicates that the toner bottle is not rotating as it should.
Open the toner door and see if the "UP" label on the toner bottle is on top of the bottle. You should be able to see it as soon as you open the door. If it is not then turn the machine off then on again to reset the C0070 and try and get the bottle to it's home position.
If it is visable, remove the bottle carefully so as not to spill the toner. Set the bottle aside and close the toner door, turn off the machine for 10 seconds then turn it back on. Allow the machine to run for as long as it needs to and see if the code comes back. 1 of 3 things should happen. 1) The machine will warm up as normal and come to the "ready to copy" state and you can make a copy. 2) The machine will run for quite some time, then shut down and say replenish toner.
3) The C0070 comes back even with the bottle removed. In this instance you may need a service technician as there is a drive problem with the bottle rotation system.
If 1 or 2 are true then try re-installing the toner cartridge if and only if all machine noise/running has stopped. Then run copies and see if the code comes back. If it does then you most likely have stripped the toner bottle drive gear and it will have to be replaced.
Sep 23, 2010 | Minolta DiALTA Di350 Laser Printer
Code error c0070, Minolta EP2050 Copier
C0070 means that your toner bottle is not rotating properly. First thing is to remove the toner bottle from the machine. Close the front door and let the machine run. This may take several minutes maybe even 10. If the code does not come back and once the machine has stopped then re-install the cartridge and let the machine add toner. If no code comes back you are fine. If it comes back after re-installing the cartridge you have a small plastic drive coupler in the hopper that has cracked or there is toner on the rotation sensor. Kind of a common problem on these models. If this happens just reply with a comment and I will point you to the parts you might need.
Most of the time tho this code is a result of an improperly installed cartridge or a cartridge from the wrong model. Should be 201A toner.
Good Luck
Jan 02, 2010 | Office Equipment & Supplies
Minolta CS Pro Error Code C0070
Turn on and off WITHOUT toner bottle inserted to reset to home position. If message comes back, the toner motor/drive gears are busted. Time consuming repair, be warned!
Dec 07, 2007 | Minolta Di3510f Bizhub Copier
239 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
