Question about Friedrich QuietMaster SM18L30 Air Conditioner
Cleaning filter for quietmaster SM18L30
How do you clean the filter? Do you just wash it with water and let dry?
  • 83 Answers
yes basically you wash with soap and water and let it dry you can also blow dry the filter.
i hope this helps.
Posted on Jun 26, 2009
How do you clean filters
What filters are you cleaning. If it's electrostatic air filters, these can be soaked in a plastic tub full of warm water and a small amount of dish soap. I also use about a half cup of bleach per 5 gallons water. Soak for 5-10 mins then rinse with water hose. Allow them to completely dry before reinstalling. If you are cleaning a washable air filter, clean with you water hose, spraying the direction opposite the normal air flow. Should be a arrow showing wash direction. Not sure of what you want to clean but I hope this helps.
Aug 19, 2017 | Heating & Cooling
Can the filter be cleaned or does it have to be replaced. If it can be cleaned; how do I clean it?
Foam or cloth filters can be washed. I wash by hand with hot water and dish washing liquid, rinse with clean water, thoroughly dry and refit. Has always worked for me. The paper filters obviously can't be washed, but if you have access to a compressor you can blow them cleaner. Be careful as they do rip easily and this method only partially unclogs them. Replacement is the best way.
Apr 18, 2016 | Filter Vacuums
The clean light came on and I cannot find my manual to find out how to clen it. Plaeas help
Always turn coffeemaker OFF and remove the plug from the electrical outlet before cleaning. Lift up the reservoir cover. Remove and discard the paper filter and ground coffee. The filter basket can be washed in warm, soapy water and rinsed thoroughly, or cleaned in the upper rack of the dishwasher. Dry all parts after use. Do not put any water in the unit once the filter basket has been removed. Wipe the area under the filter basket with a damp cloth. Remove the carafe from the heating plate. Discard any remaining coffee. The carafe and lid can be washed in warm, soapy water and rinsed thoroughly, or placed in a dishwasher. The carafe and carafe lid should be placed on the upper rack only. Do not use any scouring agents or harsh cleansers on any part of the coffeemaker. Never immerse base unit in water or other liquid. To clean base, simply wipe with a clean, damp cloth and dry before storing. Fingerprints and other blemishes on the stainless steel housing can be washed off with soap and water or a nonabrasive cleaning solution. Wipe warming plate with a clean, damp cloth. Never use rough, abrasive materials or cleansers to clean the warming plate. Do not dry the inside of the water reservoir with a cloth, as lint may remain.
You can print the manual on this link:
http://www.cuisinart.com/share/pdf/manuals/dcc-1200.pdf
Feb 15, 2011 | Cuisinart DCC-1200 Coffee Maker
Can the air filter be washed in soap and water
TURPENTINE CLEANS IT BETTER IF YOU DO SOAP AND WATER MAKE SHUR ITS DRY AND THEN RE OIL FILTER
Jan 23, 2011 | Husqvarna 450 e-series 18" Chain Saw
Routine cleaning Mabis XP.
If your unit is the one pictured, he cup with the medication can be taken apart to be cleaned... the top unscrews and the nebulizer comes out....and should be done so after every use. Do not use house hold chemicals to clean the unit. Use a water/distilled vinegar mixture to clean, then rinse with clean water.
Apr 07, 2009 | Mabis Neb Xp Portable Handheld Cmpressor...
Bissel Vaccum giving a foul odour
Hi - here are a few tips!
If the filters are washable they have to be dried completely before putting back into the machine, otherwise you're damaging your vacuum by putting in damp filters which won't do much but put back the stale smell into the home. Generally washing filters should be done with a little washing up liquid, washed out, rinsed, drip dry and dried over 24 hours to room temperature naturally (not on a radiator or heater).
Faster drying should employ the use of a low temperature tumble dryer with the filters placed in a pillow case with a towel added to prevent banging off the sides of the electric dryer when in operation.
Also, whilst the filters are drying take off the main hose of the Clearview and wash it out with washing powder with the hose laid in the bath. Alternatively put wet wipes or cleaning wet wipes down the hose with a stick to get out all matter of dirt - clearview hoses are the worst for stinking especially if you have pets. That should improve the general way of your vacuum and giving it a more neutral smell. Also when everything is dried out inclduing the hose, sprinkle some bicarbonate of soda around so that the vacuum picks it up and neutralises previous odours that the vacuum had from the beater bar/floor head.
Mar 28, 2009 | Bissell 3576 CleanView II Bagless Upright...
Clean LG WF-T652a Top Loader Washing Machine
I have this problem too and I solved it easily !!!!
I hypothesised that something was blocked by dried up lint/silt. So I filled the machine with very hot water and also poured hot water down the lint filter outlets. I left it for 5 minutes and then started a wash cycle - and the water now comes out of the lint filter ducts. ! :-)
Jan 13, 2009 | LG WFT1071TP Top Load Washer
Leaking water
water leakage from indoor unit
1.clean cooling coil
2. wash air filter
3. check drain tray.if it block then clean it
4. check drain pipe U band.
5.check indoor unit water tray.if damage change by new one or repair it
Sep 04, 2007 | Friedrich QuietMaster RS10J10 Air...
Friedrich QuietMaster SM18L30 Air Conditioner Logo
236 people viewed this question
Top Friedrich Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Tim Whalen
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
