Question about Jenn-Air Kitchen Ranges
We purchased an older house that has a Jenn Air D120 Electric Range but no manual to tell me how to use it. Where can I find one? Headquarters called me this morning and said this modle was discontinued in 1994 or 1995 and they no longer have manuals for this range. Can you helpme? Thanks
I have a manual I can scan if you haven't found one yet. Just post here and I'll keep an eye on the forum.
Dennis
Posted on Jul 08, 2009
We purchased an older house that has a Jenn Air D120 Electric Range but no manual to tell me how to use it. Does anyone have one they could scan and send me?
Hello Barbara,
Simple search online will get you to jennair.com
or
You can search within
Guides & Manuals, or call a Customer Care Specialist at 1-800-JENN-AIR (536-6247).
or
kitchen.manualsonline.com
Good luck and all the best in your new home.
Nov 14, 2015 | Jenn Air Kitchen Ranges
Need an owners manual for model d120
I would suggest going to http://www.jennair.com/flash.cmd?/ and looking under their Customer Care menu option.
I could not find a range with model number d120 in their lists. Under Customer Care select Find Model Number and then select Ranges from the list. The site will then show a number of pictures of different models and where the model number is located on those ranges.
Once you have that go back to the home page and under Customer Care select Find Guides And Manuals. Select the Consumer option in the first form field and input the model number into the second form field.
Jul 03, 2012 | Jenn-Air Kitchen Ranges
I purchased a house w/ a Jenn-air elect. drop-in range. The Model # is 87946 or 87847. I believe the range was originally purchased in 1975. I am in need of an instruction manual .
Neither of these are a typical Jenn-Air model number. http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=JA_EN_US suggests that the model number is on the back wall under the burner on the right side of a drop-in cooktop. For a range the model number is often on the frame inside the oven door, below the vent or on the back of the top of the range.
87946 or 87847 are the part numbers for the cartridges (the elements or the surrounding housing).
Look at the model number locations at the "Help me find my model number" link and try to locate a model number on your range. Then enter that model into the search box. The manual is probably available with the correct part number. Most Jenn-air electric cooktops start with JEC in their model number.
I hope this helps you locate the manual.
(I did try JEC87847 just in case you left off the leading alphabetical characters.)
May 08, 2011 | Jenn-Air Microwave Ovens
Heating element in my electric Jenn-air oven
This is one of the most simple repairs you can make on your range. And it's so affordable that you shouldn't think about replacing it!!
Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
with your complete model number and we provide part removal/installation instructions for you when you purchase your parts through us.
We want to get you cooking again soon, so call us asap.
We look forward to working with you! Thanks, Ella
Jan 07, 2010 | Jenn-Air SVE47100 Slide-In Electric...
Have a slide in Gas Jenn Air model JGS8860BDP, but no manual. Ho
Google your range (i.e. Jenn Air JGS8860BDP). You will be brought to Adobe Reader which will have a copy of the User Guide for your range. Doenload it to your computer, or print it directly.
Nov 11, 2008 | Jenn-Air JES9860 Electric Kitchen Range
Vent duct
Problem solved. Looked up installation manual and it showed proper placement and installation. Thanks
Nov 04, 2008 | Jenn-Air JDR8895AA Dual Fuel (Electric and...
Jenn air 88370
I have a similar Jenn Air oven approximate date 1982. It has a catalytic liner (colored a kind of dark charcoal  with paler flecks), so it is a continuous clean oven during normal cooking.  However, it also has the Accel Clean setting on the control knob. This increases the oven temperature to maximum and also runs the convection fan to burn off cooking residues. This allows the catalytic lining work at high efficiency, and burn off stubborn residues that are not removed at normal cooking temperature. The oven may emit smoke through the top door vents as the food residues burn off, so watch that you do not set off your smoke detector. I switch on the cooker hood fan and also put a fan in the kitchen window (blowing air out of the kitchen), to avoid setting off my kitchen smoke detector if I use Accel Clean.
Jul 28, 2008 | Kitchen Ranges
Jenn-air electric range
does the unit have a lever or does it lock automatically from inside the panel?
Jan 03, 2008 | Maytag MER5775Q Electric Kitchen Range
Kitchen Ranges Logo
292 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
