Question about Sony KV-32S26 32" TV
Tv screen has slight hourglass shape
32 inch RCA flat screen has slight hour glass shape picture is drawn in 1/2 inch on sides i purchased this from friend??? do i return or is it an easy fix???
  • Anonymous May 21, 2009
    same problem can it be fixed
  • Sony Master
  • 1,689 Answers
A common fault are some of the electrolytic capacitors failing in the pin cushoning amp section, and probably in part of the scan amplifiers.
To service this will require the proper training and set-up to troubleshoot the set.
Take the set to a service center for an estimate. The cost can be at least an hour or two for the labour, and then the cost of the parts on top.
Jerry G.
Posted on Apr 12, 2008
Hourglass picture. Panasonic CT-35G30T The picture is hour glassing from the sides. Starts to flicker back to normal after 1 to 2 hours. Getting progressively worse. Takes longer time to reach normal...
This is caused by bad solder connections in what's called the pincushion correction circuit. Some of the transistors get quite hot, and over time the solder connections to the TV circuit board become intermittent. When you tap the set, it causes them to make contact again so the picture is normal, but then it goes funny again. Resoldering the connections would take care of this problem. I would suggest calling a professional in to make the repair, which would cost far less than a replacement TV.
Hope this has been helpful, and thanks for using Fixya!
Feb 01, 2010 | Panasonic Televison & Video
TV comes on but after a while there becomes a hourglass shape on screen. It is drawn in 1/2 inch on the sides. Can this be fixed cheap?
yes. has a pincushion circuit problem. since tv works and then starts to bow, its a bad solder connection. when tv warms up the metal expands and looses connection. when cold, the solder constricts and unit works fine. just solder deflection area. you can probably tap on board and locally find area to solder.
Nov 15, 2009 | Sony KV-32S26 32" TV
Have you ever had this problem?
Sorry Ginko, but a convergence problem would have the curves down from the top and up from the bottom. The hourglass shape is a pincushion problem. This can be as simple as a bad capacitor in the pincushion circuit.
Could you please confirm the model number so I can look up the probable part?
Jan 08, 2009 | RCA F32632SB 32" TV
Vertical hold
If the picture is in an hourglass shape this has nothing to do with vertical hold. Besides, on all these sets, the hold and parameters are all uPC controled through a firmware routine that is burned in to an EPROM.
It is obvious that there is a failed component somewhere because of the hour glass shape. The area of failure is most likely in the pin amp section. If the hourglass is from the sides, it would be horizontal pin. If it is top and bottom, the fault is in the vertical pin section.
A common cause is from a capacitor that has failed in the mentioned area. Sometimes it can be an IC or other type of component in the pin amp area, but not as often as failed capacitors.
You can take the set in to service the fault. I don't think you can fix this yourself unless you are trained in TV service and have the experience and setup to troubleshoot for the bad parts, and do this type of service.
Jerry G.
Apr 19, 2008 | Panasonic CT-32HX40 32" TV
Picture problem
sounds like a bad tube or projector (depending on the type of TV)
best off at this point to get a professional
Mar 08, 2008 | Televison & Video
Hourglass shape on screen
you might tyr adjusting the eprom setting to correct the e/w pincushion fault,or call for service to adjust.
Nov 06, 2007 | RCA 32F531T 32" TV
RCA 32V432T picture problem
Sounds like the Filter Cap is shorting.
Sep 08, 2007 | Televison & Video
Tv picture shaped like hour glass
The link you posted has been deleted, so I cannot see the picture you posted. If the sides bow in like an hourglass and the red, green and blue colors are still aligned then there is a horizontal width or pincussion problem, but if the sides bow in and the 3 colors have separated and are no longer anywhere near aligned then you have a convergence problem, both of which should be serviced by someone with experience in servicing projection TV's.
Jul 03, 2007 | Akai PT4298HD Rear Projection Television
Picture is hourglassed shaped
your unit has a problem in horizontal circuit particularly deflection and pincunshion circuit. pls have it check by a qualified service technician.
Jan 15, 2007 | Emerson EWC27T3 27 in. TV/VCR/DVD Combo
The picture is convexed,or hour glass.
Sounds like problem in B+ voltage line to horizontal output transistor. Possible bad filter capacitor or leaky diode in power supply.
Dec 22, 2006 | RCA F32672SB 32" TV
Sony KV-32S26 32" TV Logo
466 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
