Question about Insignia NS-DV2G MP3 Player
What does "hold" mean?
When I turn device on, display reads "hold" and freezes there.
I leaned against control panel and now it reads 0 FF
Samsung Refrigerator OF OF Code On Display - How To Clear ...
https://removeandreplace.com/.../samsung-refrigerator-of-of-code-on-display-how-to-...
Oct 6, 2016 - When your Samsung refrigerator shows the OF OF or OFF code, here is how to reset it... 1 - Press the POWER FREEZE and the FREEZER buttons at same time. 2 - Hold the 2 buttons for 3 to 5 seconds. 3 - This will reset the refrigerator back to normal and the fridge will begin cooling again.
How to Turn Cooling Off Mode On/Off (RF4287) - Samsung
https://www.samsung.com/us/support/answer/ANS00048861/ To disable Cooling Off mode, touch and hold the Energy Saver and Power Freeze on the display panel simultaneously. Continue holding until you hear a distinctive chime sound and both temperatures for the freezer and fridge are displayed.
Apr 22, 2018 | Computers & Internet
Kindle froze
Perhaps the wrong format pf ebook?
May 04, 2014 | Amazon Kindle Wireless Reading Device
Blackberry freezes and doesnt recieve all messages
Try this steps to perform soft reset
1)Press and hold down the ALT key on the smartphone.
2) While holding down the ALT key, press and hold down the right-hand CAP key.
3) With both of those buttons still pressed, press the DELETE key. The display on the BlackBerry smartphone will turn off to indicate that the reset has started, and the keys can now be released
Still if you face same issue Download and install the latest BlackBerry Device Software, which is available from the BlackBerry.com
Hope this is helpfull for you
Nov 09, 2009 | RIM BlackBerry Curve 8310 Smartphone
PS3 Freezes after 20 mins of gameplay
PS3 is one of the most amazing gaming device but like other competitorgaming devices (Xbox and Wii) It also has some problems like Freezingup. You may check out the informative Article at ezinearticles. Remedy for PS3 Freezing up.
Jan 15, 2009 | Sony Playstation 3 (PS3) Console
Freezes on wait
1. slide the [HOLD>] to ON
2. turn the unit ON (press the play button)
3.while the "HOLD" screen is displayed press the the keys in following order:
[MODE] , [ - ] , [ + ] , [ - ] , [ + ] , [MODE]
Note:
  1. You should press this keys as fast as you can without delay.
  2. All settings return to the factory preset. All recorded tracks are erased.
  3. Do not remove the battery during resetting. Doing so may cause the unit to malfunction.
Aug 19, 2008 | Panasonic SV-MP020 MP3 Player
Memory Full - Garmin nuvi 200
Turn off the device, push and hold in right-down corner on the display, and turn on the device. Hold your finger on the display, until you see "Do you really want to erase all user data?" message. Then click "Yes"...
Hint:
All private data will be erased. The user POI's too. You can backup the file G:\Garmin\gpx\current.gpx before erasing procedure.
Mar 23, 2008 | Garmin Nuvi 660 GPS Receiver
Help
You will need to reset your device and also get a firmware upgrade on your device.....To reset the device when it freezes just hold the power button down for 15-20 seconds or until it resets....the latest firmware for the device resolved much of the freezing issues....also there are two modes for you to use the device the msc and mtp.....try deleting in mtp mode.
Jan 03, 2008 | SanDisk Sansa e250 MP3 Player
It freezes up and wont read
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
-Tha Mp3 Doctor
Dec 28, 2007 | Philips SA5125/37 MP3 Player
Sansa e250 freezes while I put music on it with Windows Media player
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://rapidshare.com/files/67740173/e200fw01.00.12.exe____
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Please RATE my solution at the bottom.
Nov 22, 2007 | SanDisk Sansa e260 MP3 Player
Insignia NS-DV2G MP3 Player Logo
48 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
Steve Allison
Steve Allison
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
