Question about Maytage MSD2652KE 26 cu. ft. Side-By-Side Refrigerator w/ Electronic Ice/Water Dispenser & AdjustiTe...
It is not cooling, like the fan is not running, but you can hear it. When you put your hand up by the blower, there is no flow there. We removed a blockage of ice from the freezer side, but it is only keeping it at about 60 degrees. Not sure of the model number.
  • Maytag Master
  • 4,655 Answers
We will need the model number to give you the correct answers to solveIt is not cooling. - 2f300b8.gif this.
Posted on Jun 26, 2009
My heat kicks on, I can hear it and feel heat when placing hand on vents. However,Nothing blows out.
Blower is not running ? Or is ?if the blower fans not working check fuses or replace motor , if your heat cycles and your blower blows cool air , its likely a heater core issue
Nov 09, 2015 | 2007 Ford Freestyle Limited
Why are my cooling fans for radiator running constantly?
The cooling fans are supposed to run any time the a/c is on in order to keep air flowing across the condenser. Your a/c will not work properly at idle if they quit.
Jul 27, 2015 | 2010 Ford Escape
Replace fan motor
Hello Theresa;
My name is Peter. I am a retired field service refrigeration technician.
You did not provide a model number which is located on a label on the upper liner side wall in your fresh food section. So, I do not know what you have.
There are several reasons your fresh food section is not cooling:
1.) Cooling air vent from freezer to fresh food section. Find the air vent, put your hand in front of it, do you feel any air flow? This vent may be iced up or closed.
2.) Freezer cooling coils iced up - Look at the back wall of your freezer, is there frost or ice on the wall? You may have a bad defrost heater.
3.) Cooling coil fan - Open the freezer door do you hear the fan? Push in on the light switch, do you hear the fan?
Get back to me.
Peter Goodwin
Glen Burnie, MD
Jun 10, 2015 | Samsung Refrigerators
How to replace blower belt on whirlpool cabrio dryer model wed7800xw0
first put pulley onto blower fan housing i think you have to counter clock turn to put the pulley by hand. put you one hand inside the blower housing and hold the fan then use pliers and tight the pulley. now put belt on motor pulley first then put belt on blower's pulley it is hart to put on so little belt on pulley and use other hand and turn fan from inside so blower's pulley turn and belt get to pulley. last tight the pulley again. turn fan by hand to make sure belt run ok. hope it will help you.
Dec 21, 2013 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Heater gets warm the goes Luke warm when blower is turned on
when you put the heater on hot and the blower on full and the car is running at idle, the coolant in the heater matrix is cooled quickly,as when the radiator fan comes on to cool the engine, have you tried raising the revs and checking the heater to see if it gets hotter. If this does not happen you could have air lock in the cooling system and may need bleeding properly.
Mar 23, 2012 | Ford Focus Cars & Trucks
I have a Bryant Model 340MAV and the airconditioning fan is loud when running but seems to operating fine otherwise..fan is running and cooling great..the oustide coil was replaced in April. Please advise
Sounds like the motor is going bad in the air handler/furnace now...
Open up the blower compartment and spin the blower by hand with the power off...you should be able to hear if the bearings are rough or if the blower is hitting something... then you will know what you need to fix...
heatman101
Aug 29, 2011 | Heating & Cooling
Refridgerator is not cooling. I hear the fan but there is no air flow
Ok when you say you hear the fan and no air flow, am I to understrand if you put your hands in front of the vents in your freezer no air comes out ?
The noise you are probably hearing is the compressor motor running (a humming sound) - you may have a bad evap fan - you will need to have your system checked and check the evaporator fan motor - if this is not working there will not be any cooling and air flow. they might also want to check your control board.
Aug 23, 2009 | Whirlpool GS2SHEXN Side by Side...
Fan is so low, no water in roof, cool but not cold
clean the coils with acid [foamagator] oil the fan motor. click the fan and pay close attn to see if it changes. the blower switch may be bad. if you here it change speeds , you may need to put freon in it....good luck sawdust46
Jul 25, 2009 | Dometic 57915531 Air Conditioner
Aprilaire 600 humidity level too low
you may try running your blower 100% of the time.this should allow the humidifier to stay on even when your not heating. once the humidity level gets to where you want it, you may be able to put the fan selector back to auto. also you mentioned you have a variable blower. this is great if it is set up to run at approx. 20% fan speed when it is not heating or cooling. at 20% you can circulate enough air through the house to humidify without being able to hear the noise of the blower. it will really increase the comfort level of the house if you tend to have hot and cool spots. if it was not set up this way, contact the installer and ask if they can do this for you.
Jan 26, 2009 | Humidifiers
Blower problem bmw 318i 1996
sounds like the resistor in the side of the blower unit has failed. try replacing that.
Aug 11, 2008 | 1993 BMW 3 Series
Maytage MSD2652KE 26 cu. ft. Side-By-Side Refrigerator w/ Electronic Ice/Water Dispenser & AdjustiTe... Logo
105 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
