Question about Samsung SGH-i640 Cellular Phone
Cannot install java on samsung i640
Cannot install java apps on samsung i640
  • fatabaash101 Jul 01, 2009
    thanks a lot.... i finally got jbed on my cell, installing it from a memory card a friend of mine had, and using a software already on the fone... file viewer.
    Now i got a new problem... how do you uninstall jbed? i cant delete it, form my cell, not even via usb link....
    President:
  • 1,462 Answers
Im very sorry Dude
  • It is NOT officially possible to install java MIDlets on samsung handsets (excluding smartphones) via bluetooth, IrDa, USB cable or serial cable. MIDlets can only be downloaded by Over-The-Air (OTA) via a download server
  • There is currently no method for installing MIDlets on other platforms other than by OTA/GPRS via a download server.
BUT THERE ARE SOME UNOFFICIAL METHOD PLEASE TRY THIS BUT RISK IS WITH U.
Install JAVA games on your Samsung via a USB cable, BT or even an IR port
The method here is rather straightforward. It has been tested on my two D500 phones without a single problem cannot install java on samsung i640 - biggrin.gif
1. Download and install Softick PPP from here. The software is designed for Palm users, so if you receive any error messages such as unable to locate USBPORT.dll, just ignore them.
2. Active your IR connection or hook your USB cable into the phone.
For IR users, you need to active the IR connection on both of your laptop and D500, and approach the laptop with your D500 to let it find the phone prior to any transferring.
For USB connection, the one I tested is from fonefunshop
3. Start Softick PPP, and check if it has your connection in its 'Settings->Bluetooth/Serial'. Active it if done.
4. Run 'Uploader.exe' program and add a jad file.
5. Enable Serial Java download - #*536963#.
6. Enter Serial Java menu #*5737425#, and choose USB from "1 PPP UP'. Please bear in mind, just do it once for each switch on/off!
Select second option - "2.Serial Download"
7. Let upload and softick PPP access the net if you installed a firewall.
-More details--------------------------------------------------------
If you are using a USB cable, please take the following steps:
1. deactive Softick PPP, and exit it.
2. connect the cable,
3. run Samsung's PIM & File Manager to make sure that you get connected. If not, please switch off and on your mobile and try it again.
4. run Softick PPP
5. go to it's 'Settings->Bluetooth/Serial' to check if it has a connection such as COM7 Devicess_mdm0. If so, select it, otherwise exit the Softick PPP and go back to the first step. (you may find the proper COM setting from the windows device manager->modems->Samsung Mobile USB modem)
6. active Softick PPP.
7. run Uploader.exe
8. ......
For IR users,
2. active your IR connection。
3. approach your phone to the laptop, and make sure there displays an icon in your tray area and it gives a message 'there is a device around....'
4. run Samsung's PIM & File Manager to make sure that you get connected via IR. If not, please switch off and on your mobile and try it again.
5. run Softick PPP.
6. enable IRDA interface support in 'Settings->Options'
7. go to it's 'Settings->Bluetooth/Serial' to check if it includes a connection such as 'COM4 Device
Posted on Jun 26, 2009
The phones goes loading when i installed java games and apps
Hi Sanjaybasnet,
Incompatibility.............................
regards,
nuwan.
Jan 20, 2014 | Samsung Cell Phones
How to install third party java apps on my SAMSUNG GT5233A mobile phone??????????????? Is it really possible??? then, how??????????????
you can only install and play java games by downloading the java games from internet directly from your mobile's default browser. you can't install java apps from memory card or pc. but please don't forget to rating my solution.
Feb 01, 2011 | Samsung Star GT-S5233 Cell Phone
I cant install java games to my samsung champ phone........ what should i do? tried kies but not working. Also tried pc studio.
Just place a jar files(games or apps) on a memory card. Then just click on the apps or games it will install. Samsung champ will only install below 500 kb/apps or game, if you want to install higher than that just used this code by dialing *#52828378# you will go to Java Test Menu, then go to OTA test, change 500kb to 4000kb then save. You can now install as much higher than 500 kb but not more than 4 mb.
Oct 17, 2010 | Samsung Computers & Internet
I cannot install jar or jad java files samsung
for installing the java application in your samsung mobile phone. you have to access internet from your mobile then download the jad or jar file. then it will automatically install the java app. if u can't access the internet from your mobile then turn on the bluetooth then send the files from any other mobile to your :)
May 09, 2010 | Samsung Highlight Cell Phone
Promblem creating during installing games in samsung SGH-J800
No, usually Samsung phones doesn't allow to install java through PC.
You need to install it through Mobile Net (WAP)
And for samsung phone's java apps i always prefer http://www.wap.getjar.com
First select your Phone, then the type of app, and the most important thing is to check that specific app/game.. to be 100% tested under that phone . There will be a small tag with that app's discription, only try those with 100% Tested.
If I was helpful, kindly do Rate!
Jul 20, 2009 | Cell Phones
Cant upload java app on my s3310
I'm havn't tested it yet, but even though let me tell you, that samsung phones are not good at java apps.
First install Samsung PC Suite ( It will be in the installation CD provided with the phone, if you havn't got it, download it from samsung official site download center here)
Now the second most important thing is to get the proper fully supported application for your mobile, and the best site for it i will rate is This
Go there and select your phone/Model from the left habd side menu.
Now a list of apps / games will appear but in the corner of the description you will see a tag saying that this app have been tested on the phone. Only download that app / game which got 100% tested.
And try both .jad & .jar files.
Connect the phone with PC Suit and send those files.
Hopefully, you will succeed.
If i was helpful, kindly do Rate!
Jul 19, 2009 | Sony Ericsson G502 Cellular Phone
I have a samsung GT-S5233A,i can't install java applications
1) *#9998*5282#
2) *#9998*4678255#
3) *#9998*52824678255#
4) *#52828378#
Jul 17, 2009 | Samsung Cell Phones
A samsung GT-S5233A mobile-can't install java apps
There are several versions of java files. You got to install the correct version compatible for your phone.
they must be having .jar extension
Jun 20, 2009 | Cell Phones
Install java on mobile
I have SGH-J210
It seems that you can only download games from internet. As soon as you click on java app/game file link in the browser. The Java install options appears and the app/game is installed.
I tried all ways to install games from PC to cellphone. But so far I am unsuccessful.
Jun 19, 2008 | Motorola Mobility MOTORAZR maxx V6...
Samsung SGH-D600 "Install error"
you need to reset your phone, that might solve the problem. a full master reset should work.
Jun 07, 2008 | Samsung SGH-D600 Cellular Phone
Samsung SGH-i640 Cellular Phone Logo
347 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
