Question about Car Audio & Video
Factory 2003 ford f150 6 disc cd player will not eject cds, it trys, locks up and displays an error message. when i clear the message the cds will play. if i try to eject it goes through the same issues.
  • Marvin
    Marvin May 11, 2010
    all u can do is pull it out and have it repaired.
SOURCE: cd eject error
I've read that you can disconnect the battery and reset the unit. It might be worth a try.
Posted on Sep 14, 2008
SOURCE: 6 cd changer
try to reset the cars computer. i had the same problem and it fixed it. all you need to do is unplug the battery for about 10 minutes and it may work. Good luck!
Posted on Jun 15, 2009
SOURCE: ford 6006e cd changer with e 3 error keeps happening
The only way to do it is to remove the radio using DIN radio removal tool - then you will have easy acces to remove cd's if you do not have this tools try to use coat hanger (do small catss on the ends)
(you can try to hold eject button and swich off - swich on button - probably it will not work but try few times
Good luck,
Kamil
Posted on Jun 24, 2009
  • 108 Answers
SOURCE: My cds are stuck in the player. They won't play or
Hi Texasgirl826,
There is nothing I can tell you to do that won`t damage the player.
I have one sugestion, go to a shop that installs car stereo, don`t go into the store, go to the bay where the workshop is and ask one of the installers real nice like if he could take it out for you, I`m sure he would.
It is a bit tricky to do it, but it can be done, without having to remove the deck and taking it apart.
Good luck.
Posted on Dec 20, 2009
SOURCE: Hyundai CD player displays ''error'' for all functions
my cd player in my sonata keep eject the cd can anybody help
SOS
Posted on Jan 12, 2011
Cd player keeps going out when i try to play/load/reject get 'error' message
Take out #7 and #31 fuses. Start the vehicle, the radio/cd will not come on. Shut the vehicle off and replace the fuses. Start the vehicle again and you shoud hear the cd player cycling through the cds. Be patient and let it go through the process. Then play/eject/load cds. It worked for me.
Mar 03, 2010 | 2003 Ford Expedition
2007 Toyota Yaris Stereo Won't Eject CDs
you may have to use needle nose pliers to pull them out or remove the radio and open it up and remove them also take a look at the drive belt it may have broke, there are many electrionic places that will repair it if you remove it and take it to them, most of the one i run into broke a belt or 2cds were jamed inside it.
Mar 01, 2010 | 2007 Toyota Yaris
2003 ford expedition, 6-disc cd player, several cd's in player, getting a cd error message. won't eject or play.
try disconecting te battery that way the cd player would reset itself and probably eject the extra cd...
Feb 11, 2010 | 2003 Ford Expedition
Jammed cds in a 6 cd changer ford ranger 2002
sounds like the tray inside was misaligned when the cd went in. and it probally sent the disc into a occupied slot. you will have to remove radio and disassemble to repair. also try just unpluging radio and plug back in. sometimes it resets the radio and will start ejecting the cds
Feb 05, 2010 | OEM Systems Car Audio & Video
2003 Ford Expositi CD Player will not play or eject
Does the CD door open or is it stuck open? If it is open look to see if you have a jammed CD. This happened to me and this is what I did. A CD had gotten off track and jammed the CD changer turn table. I stuck a little key in the slot and was able to pull the CD out. This fixed my problem. Hope it helps.
Dec 21, 2009 | 2003 Ford Expedition
SOS
Dec 11, 2009 | Car Audio & Video
Cd player in ford expedition quit showing CD
If you can not eject cartridge
Press and HOLD eject button insert credit card or similar under cartridge.Push firmly in and move left to right untill it ejects,this will locate micro switch.
The fuse is located on the back of the stacker,this is ok because your head unit recognizes stacker.
Nov 14, 2009 | 2003 Ford Expedition
Cd error on my Ford 2004 expedition
I have seen this often..assuming there isn't a CD jambed in it....usually means you have to send it out for repair...its most of the time an internal problem.....you can try first is disconnect the plug at the back and reinstall them and turn it back on...If it still shows ERROR....replace the radio... If its a stuck CD...FORD radios DO NOT LIKE homemade CDs, they are to thick, and labels hang it up...If this is the problem use a "needle nose pliers" and extract it the best you can AND DON'T USE COPIED CD's....hope this helps you..GL
Jul 11, 2009 | 2004 Ford Expedition
Bose 6 cd changer factory installed will not function.
Some people with this issue have had some sucess disconnecting the negative battery cable for 10 minutes to reset the stereo. After re-connecting the battery, the stereo should reset and the error message should clear at which point the CD player should also function. Apart from this, a service call at a dealer or a car stereo repair specialist are the only alternatives. Best of luck.
Greg
Jun 14, 2009 | 2002 GMC Envoy
CD Player won't read disc's. ERROR message
Well if the unit came with car over 10 years old, u can't clean it might have to just replace. buying a new one will cost as much as trying to fix that one.
Apr 10, 2009 | 2003 Dodge Grand Caravan AWD
Car Audio & Video Logo
1,515 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
